 12.5hp briggs ic help
xxXMowerdudeXxx
gearheadmike
offroadredneck
mudmonkey06
9 posters
mudmonkey06
mudmonkey06
12.5hp briggs ic help Empty
PostSubject: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 1st 2013, 4:32 pm
my engine has been starting hard. and everytime i try to start it it gets harder to even turnover. its not the starter just rebuilt that. can someone help me figure out what is wrong with it i think it may be a valve.
i also,being stupid, forgot to check the oil so its been running bone dry
should i rebuild this engine or replace it
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 1st 2013, 4:46 pm
Run it till it blows!
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
mudmonkey06
mudmonkey06
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 1st 2013, 4:50 pm
i want to but it wont start keeps just turning over and over battery may ne too weak
offroadredneck
offroadredneck
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 4th 2013, 10:22 am
My engine takes a minimum of 350 amps to start with a new starter. Try jumping it.
gearheadmike
gearheadmike
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 4th 2013, 2:07 pm
if you ran it with out oil its most likly junk the cyl walls are prob all scored up
mudmonkey06
mudmonkey06
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 5th 2013, 12:16 pm
ya thats what i figured im replacing it now anyways i have a 14hp twin briggs that came off a 87 mongomery ward. im currently tearing the engine down and cleaning everything inside. but when i put it on i will need a new battery. i have a teeny one now and i dont thin that its enough for the 12.5 horse
xxXMowerdudeXxx
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 5th 2013, 12:19 pm
Im using a 230 cca battery for my mower, it starts *shurg*
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 5th 2013, 6:33 pm
I have a flathead 12.5hp, think my battery's a 230cca aswell. They like some juice!
Murray modder
Murray modder
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 5th 2013, 8:24 pm
Bad alternator, Might have trained the battery
Valves out of line, so the compression release isn't working. (If Applicable)
Ground may not have a good connection
Positive wire may not have a good connection
Im sure they are many more possibilities, but these are the only ones I though of so far....Instead of replacing it, I'd work on popping the head off and seeing if the cylinder walls are totaled, even if you have a spare engine.
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 5th 2013, 8:35 pm
I think I have the same motor only mines the iron sleeve. I don't think I have much oil at all. ita blak and low, half off it is on the side of the motor bc the dipstic seal is broken
mudmonkey06
mudmonkey06
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 5th 2013, 9:05 pm
thats what im going to do
mudmonkey06
mudmonkey06
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 17th 2013, 3:03 pm
another thing i noticed about the engine was that when i jump start it it starts tight up but with battery it doesnt. and it stalls whenever i put load on it like tryin to go forward.
any idea how to fix this
greener179
greener179
PostSubject: Re: 12.5hp briggs ic help   12.5hp briggs ic help Icon_minitimeApril 17th 2013, 5:09 pm
If you do get it running but it burnt oil use ome thicker oil and some stuff called motor honey works great
» How to: Hook up a Diesel tachometer to a Briggs Opposed Twin or any Briggs with AC out.
» Ran my briggs without oil!
» I need help with 14.5hp briggs OHV
» Ever wonder what to much oil does in a briggs
» New old briggs model 5s
