| I need help with 14.5hp briggs OHV | |
dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5033 Posts : 306 Location : Silk Hope N.C.
| Subject: I need help with 14.5hp briggs OHV April 30th 2012, 11:51 pm | |
| I got a free 14.5 horse power briggs from a Sabre riding mower and I mounted it on my off road racing craftsman I cleaned out the cylinder and the carb but it didn't come with a spark plug so if any body could tell me what type/ model number spark plug to use also the is a electrical plug on the bottom of the carb and the plug is on the drain plug/ bowl nut but anyways does anyone know what that's for? | |
| | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4931 Posts : 208 Location : Tennessee
| Subject: Re: I need help with 14.5hp briggs OHV May 1st 2012, 12:06 am | |
| The spark plug should be a RC12YC (Champion #) The thing under the bowl is an anti-backfire solenoid. It needs 12V to operate; the engine won't run if it's not working. | |
Age : 49 Join date : 2012-04-05 Points : 5696 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: I need help with 14.5hp briggs OHV May 1st 2012, 6:54 am | |
| We have ran a couple of those engines. Removed the fuel soliniod and replaced with a plug, they tend to go bad. Also they would foul plugs, so got a hotter plug for it, parts store can tell you what plug is hotter. They will blow oil if you run high rpms. Strong motor, plenty of power. | |
| Subject: Thanks May 1st 2012, 5:35 pm | |
| Thanks for the help with this motor i will be posting my build on this site. but about the fuel solenoid, I couldnt find a plug that fit in there so either where could i get one or how should i hook 12 volts up to it for it to properly function? | |
| Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
