| ideas to add weight to the rear | |
+12MowKartEnvy xxXMowerdudeXxx mudmonkey06 Hillbilly Homer dylansrockinrigs richie thomas truckin42 Chopperhed Thunderdivine WellThatsSurprising Doug tman9114100 16 posters |
tman9114100 Member
Join date : 2013-03-17 Points : 4337 Posts : 45 Location : LaCrosse, WI
Doug Site Owner
WellThatsSurprising Member
Age : 27 Join date : 2012-04-30 Points : 5004 Posts : 407 Location : East Bethel, MN
Thunderdivine Veteran Member
| Subject: Re: ideas to add weight to the rear March 28th 2013, 7:18 pm | |
| Fill something a container you hang up, with water (easy to empty).
Or like someone said yesterday on the chat (Richie Thomas) fill it with sand.
Or use those (never used) workout manuals. | |
Chopperhed Moderator
| Subject: Re: ideas to add weight to the rear March 28th 2013, 7:31 pm | |
| I mounted a truck battery above the hitch, between the fenders
You can also add fluid to your tires, most use windsheild washer antifreeze | |
truckin42 Veteran Member
richie thomas Veteran Member
| Subject: Re: ideas to add weight to the rear March 28th 2013, 11:08 pm | |
| tanks for the credit thunder my fat but is over the rear of mine so its good, im adding weight to the front of mine, i built the front bumper out of 3"x4"x36" square tubing and filled it with sand so it wouldnt flip, you could always use wheel weights, or and chopperhead said add fluid. or build a bracket on the back where you could mount large diameter pvc pipe and fill that with sand or whatever, that way it could be emptied or used for storage | |
dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5035 Posts : 306 Location : Silk Hope N.C.
| Subject: Re: ideas to add weight to the rear March 31st 2013, 6:05 pm | |
| On my neighbors tractor we bolted about 100 pounds of old 5lb dumbbell's to the hitch plate so we could pop wheelies. You could bolt some under the frame or inside the frame | |
Hillbilly Homer Member
Join date : 2012-04-22 Points : 4837 Posts : 197 Location :
mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4591 Posts : 327 Location : Rindge, NH
xxXMowerdudeXxx Established Member
| Subject: Re: ideas to add weight to the rear April 6th 2013, 10:15 am | |
| - tman9114100 wrote:
- i need ideas to add weight to the rear to get more traction
dude, ur in laCrosse? i'm in sparta! you can weight it with anything, lol steel, whatever you think of | |
mudmonkey06 Member
MowKartEnvy New Member
| Subject: Re: ideas to add weight to the rear October 21st 2013, 8:40 pm | |
| A bit late to the party, but for future reference... My 26-12-12 ag lug rears are weighted and foam filled weighing in at 150# ea. These are on my Sears Suburban 12. I just(accidently) pulled a '94 Bronco in park almost 6ft. before I realized it wasn't in neutral. Oops! | |
tractor_guy Member
Join date : 2013-10-27 Points : 4156 Posts : 93 Location : ohio valley, west virginia
| Subject: Re: ideas to add weight to the rear November 12th 2013, 8:47 am | |
I filled my front tires with water to help it climb better, you could do the same with the rears. You could also add an extra feul cell to the rear using feul line cut offs n each tank so your rear is there if you need it but keepin weight on the tires till then. I put an atv rack on mine and put weight on it but bein so high up it counter acts the water filled fronts. Try to keep the weight low and centered over your transaxle. | |
willis923 Veteran Member
| Subject: Re: ideas to add weight to the rear November 12th 2013, 8:51 am | |
| if you live in a cold climate, use washer fluid so it wont freeze. thats what "Billstmaxx" on youtube puts in his John Deere 2720 and 110TLB backhoe | |
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5018 Posts : 232 Location : fairhope Al.
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
| Subject: Re: ideas to add weight to the rear November 12th 2013, 10:23 am | |
| I would either weld or bolt a pole to the rear and add dumbbell weights to it done it before works great | |
