 Need some exaust ideas for off roading so water cant get in.
mudmonkey06
lane85
10 posters
lane85
lane85
Need some exaust ideas for off roading so water cant get in. Empty
PostSubject: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMarch 19th 2013, 4:06 pm
I would like to get a exaust for off roading it needs to be able to keep water out even on its lowest idol and not be in they way to hit rocks post picters of what your set up looks like! please
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMarch 19th 2013, 4:26 pm
I think you should make a shack then, just make shure its outta your face haha. I was thinking that if you took a heavy metal screen like thick chicken wire and weld it inside the pipe, you could make it a lot quitter, reduce loud cracks of backfires, and regain back pressure for performance.
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMarch 19th 2013, 4:28 pm
Running the pipe parallel along the side of the frame and then having it exit out high in the back would work great if you dont want a stack. As for muffler just check and see what Lowes/ Home Depot/ Hardware store/ Small engine shop has and fit it to your pipe.
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMarch 19th 2013, 7:06 pm
You could do a stack.
If you dont what it to be loud just add mufflers on top the stack.
mudmonkey06
mudmonkey06
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMarch 19th 2013, 7:18 pm
you could make a straight pipe and have the exhaust end point down
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeApril 23rd 2013, 12:13 pm
Look up, boat exhaust and even sub marine exhaust.
The tip is a gooseneck.
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeApril 23rd 2013, 4:29 pm
Like a peatrap on a sink, right?
Kel
Kel
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeApril 23rd 2013, 7:10 pm
What ThunderD said.... cheers
http://www.xtrememowermayhem.com
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeApril 23rd 2013, 7:23 pm
Yeah a boat exhaust would work good too.
mud 59
mud 59
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMay 24th 2013, 10:04 pm
i ran mine out the side and up
MowBandit
MowBandit
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMay 24th 2013, 10:45 pm
i would go with thunders idea
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMay 27th 2013, 8:59 pm
For what its worth- "back pressure" is a horribly misunderstood topic. Back pressure is bad. Period. Many people confuse back pressure with cylinder scavenging, which refers to the previous exhaust wave helping draw out the next wave. Back pressure refers to a restrictive condition and is never desirable. Try running to the store while breathing through a straw. Now kink the straw and try to run home. Make sure you have 911 programmed into your speed dial. On a 2 stroke, back pressure is also bad. The confusion there is caused by the tuned pipe. A tuned pipe does NOT create back pressure. It does do three things. It assists in cylinder scavenging, it assists in getting a full charge into the chamber for the next cycle, and it times a small reverse pulse back to the exhaust port so that the exhaust scavenging does not draw the fresh charge right out the exhaust.
The reason some people may think that back pressure is a good thing, is based on scavenging. A pipe that is too big or too short will not assist in scavenging, leading you to belive that a longer or smaller pipe's "back pressure" is helping. Not so.
PostSubject: Re: Need some exaust ideas for off roading so water cant get in.   Need some exaust ideas for off roading so water cant get in. Icon_minitimeMay 27th 2013, 9:23 pm
Certainly. Its bad to have no muffler (like you said scavenging) and valve warp. But you still want the engine to exert the exhaust. so, im not shure what he wants as far as a muffler so water can get in, but I still think a stack or thunders idea is the best.
» exaust ideas?
» F150 off-roading
» Off-roading pics new and old
» briggs and stratton v-twin need exaust idea and stator problems
» What's the best brand of tractor for off roading?
All-Terrain Lawn Tractor Forum :: Technical Forum :: Chassis Modification :: Exhaust-
