| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
| Subject: Re: MTD off-road romper build. September 13th 2013, 9:55 pm | |
| Still working on the video for this thing. it will be like 14 min long or something, my editing software just sucks, works when it feels like it. | |
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4704 Posts : 356
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Re: MTD off-road romper build. September 20th 2013, 8:44 pm | |
| Working on some small things. the straps I have on top of the axle that hold it all together are just thin metal, so when I sinched them down they bent. Heres what they look like normally: (Holding the bolts together at the top of the axle) And this is a pic of when I took them off, straightened out one and the other is bent up. Now to modify.... Made some pins too so the axle wont slide back and fourth. I also tore the whole front end off while I was at it and prepping it for priming and paint, leafs individually. | |
Age : 23 Join date : 2013-04-08 Points : 5212 Posts : 913 Location : Central Pa
Age : 25 Join date : 2013-04-05 Points : 4965 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: MTD off-road romper build. September 25th 2013, 6:53 am | |
| - craftsmancole wrote:
- But it's a scratch on that awesome 'merican paint job....
It actually didn't scratch it, the seat pan is holding it up haha | |
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5024 Posts : 232 Location : fairhope Al.
| Subject: Re: MTD off-road romper build. September 26th 2013, 8:58 am | |
| [quote="redlinemotorsportts"]Parts mower stripped down more. Ready to go get a oppy sometime next week [/quote Your putting a oppy in this? What about the good ole flat head in er? | |
| Subject: Re: MTD off-road romper build. September 26th 2013, 9:01 am | |
| - cumminsbayou wrote:
- redlinemotorsportts wrote:
- Parts mower stripped down more. Ready to go get a oppy sometime next week
[/quote
Your putting a oppy in this? What about the good ole flat head in er? No I'm getting a oppy for my racer and this will be the transporter. | |
| Subject: Re: MTD off-road romper build. November 3rd 2013, 8:03 pm | |
| *900th post yay* lol Well ive been really busy with the racer, but this thing still works so i ride it sometimes. I want to so a fall romp at my friends, more or less just hang out. Anyways ive always had belt issues and i think i finally chased it down, 3 Kevlar belts later. I bought a 1/2" - 79" belt, put it on, and now it clutches great. as the belt stretches slightly, it gets better. i can push the clutch in and roll through the gears better than ever. i need to make belt retainers for the clutch pulleys and the rear pulley, like take off the rear fender, and i don't really wanna o that ATM lol. Picture from post-the test drive today Here are some jumping pics from what ive collected. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5704 Posts : 1091 Location : Galion, OH
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
| Subject: Re: MTD off-road romper build. November 4th 2013, 8:41 pm | |
| how loud is your stack? i like it.. as you already know. i am in the process of making one for the bolens
| Subject: Re: MTD off-road romper build. November 4th 2013, 9:18 pm | |
| - willis923 wrote:
- how loud is your stack? i like it.. as you already know. i am in the process of making one for the bolens
I'd like it a lot if my sweatshirt didn't smell like exhaust after a run. Kinda loud too. If I do this opposed swap I might do dual side pipes. | |
Age : 34 Join date : 2013-11-02 Points : 7172 Posts : 2910 Location : New Jersey USA
| Subject: Re: MTD off-road romper build. November 5th 2013, 11:18 pm | |
I'd like it a lot if my sweatshirt didn't smell like exhaust after a run. Kinda loud too. If I do this opposed swap I might do dual side pipes. i started mine tonight. i might add one of them in-line cylindrical mufflers like old tractors had | |
| Subject: Re: MTD off-road romper build. November 6th 2013, 8:56 am | |
I'd like it a lot if my sweatshirt didn't smell like exhaust after a run. Kinda loud too. If I do this opposed swap I might do dual side pipes. i started mine tonight. i might add one of them in-line cylindrical mufflers like old tractors had Sounds good. I hope you get some pics for your thread! | |
| Subject: Re: MTD off-road romper build. November 10th 2013, 9:03 pm | |
| Next big upgrade 820 time, well later on in winter/spring. My 930 works good, its just that the half shafts have worn the aluminum cases so much that the axles can move 1/4" up and down inside the case's ends. And sence i want to motor swap this for something better and get really agressive tires, why not get the junkyards last one before its to late? Some mounting nuts didnt come off so i justt took the whole tranny mounts off the chassis lol. Might just weld them right to my frame if it would work out. Well i wanted to crack this open to put new grease in it, and the two tranny mount bolts on the left side (odd?) were very seized in it. Ugh, steel bolts in a aluminum case. I was going to use a ratchet to twist them out but the head of the bolt was moving and the other end wasn't. so instead of breaking bolts, i took a hammer and beat the bolts down and out of there. used wd-40 and everything. The picture is becuse the axle kept moving when i was tring to break the bolts lose...LOL Opened the case and thats where i stopped for the night. | |
| Subject: Re: MTD off-road romper build. November 14th 2013, 10:13 pm | |
| - mr.modified wrote:
- I didn't read through every page of this but, is your differential locked?
Sure is. Great mod | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5704 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: MTD off-road romper build. November 16th 2013, 7:50 am | |
| Your engine is sideways! You will just go around in circles! Lol...
Nice fab work on the exhaust. Going to need a couple of braces for the long one. | |
