| drilling jets | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6394 Posts : 1434 Location : east dublin georgia
| Subject: drilling jets March 10th 2013, 1:24 am | |
| considering i have four spare carbs for my 2 opposed twins, would it be a good idea to try and drill out the jets a lil bit bigger on one? if so, how much would improve fuel flow, and how much would be to much?
| | | Marines2621 Member
Age : 27 Join date : 2012-12-31 Points : 4577 Posts : 215 Location : Mountainburg, Arkansas
| Subject: Re: drilling jets March 10th 2013, 11:59 pm | |
| I'd watch out how far u do this could have the engine to rich. Then the carb would be useless | |
| Subject: Re: drilling jets March 11th 2013, 12:17 am | |
| thats what i was thinking, but i would only go like a 16th bigger
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5248 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: drilling jets March 11th 2013, 12:52 am | |
| - richie thomas wrote:
- thats what i was thinking, but i would only go like a 16th bigger
I'd start with a 64th, A 16th is .0625 ", Thats a lot when it comes to jets If you care, .0625 is pretty much double the spark plug gap on an average engine | |
| Subject: Re: drilling jets March 11th 2013, 1:12 am | |
| thanks, give me some wood or metal i can bout build whatever you want, give me a motor and im as lost as a fat kid at fitness camp ima do it at school so should i get a drill bit that will almost fit in it or what?
| Subject: Re: drilling jets March 11th 2013, 9:34 am | |
| Find the biggest bit that will fit in the jet, then go to the next size up in the smallest increment possible. Usually 1/64:, unless there is a letter or number size that comes in between.
I use a pin vice, has bits so small I can't see them with out my glasses on. You can get them at welding supply stores. They are sold as torch tip cleaning drills. Hobby shops sell them too. | |
| Subject: Re: drilling jets March 11th 2013, 11:06 pm | |
| thanks chopper, i have a really reallly small set of round files, would these work?
| | | | Doc Sprocket Site VIP
| Subject: Re: drilling jets April 24th 2013, 11:23 am | |
| I use a pin vise and numbered bits to drill my jets, too. But nobody has yet mentioned this:
You gotta let your engine tell YOU what it needs. Read the plug. If the insulator (conical ceramic part that the center electrode sticks out of) is really light or even white, you're lean and would benefit from a larger jet. If the insulator is a medium tan to chocolate brown, don't mess with it. Your mixture is already where it needs to be. If the insulator is black, you're too rich and need a smaller jet.
Also- make sure everything else is okay. A carb gasket leak can make things rear too lean even if your jetting is correct. | |
| | | | | drilling jets | |
