| lifted craftsman | |
+27TheBeal muddstir Jerbear0612 cumminsbayou k2500life RCG genegillis5 LAWN MOWER MUDDER Doc Sprocket craftsmancole motorizedeverything MowBandit redlinemotorsportts greener179 mudmonkey06 Murray modder TheRainbowBoxer Thunderdivine Marines2621 dked41 matthew sidor xxXMowerdudeXxx Chopperhed Kel truckin42 Doug richie thomas 31 posters |
richie thomas Veteran Member
truckin42 Veteran Member
| Subject: Re: lifted craftsman May 2nd 2013, 8:37 am | |
| Yeah it not real loud. Almost sounds like my mower. | |
| Subject: Re: lifted craftsman May 3rd 2013, 10:43 pm | |
| well, aint got much done lately, still waitnig on money to buy the coupler, got to put the bigger tires up front, if my rim is 6.5" how tall will a 20x10x8 tire be on it?
greener179 Member
| Subject: Re: lifted craftsman May 3rd 2013, 11:56 pm | |
| Every inch wider your tire is then yoir rim you will get 1/2inch of hieght. Roughly
| Subject: Re: lifted craftsman May 4th 2013, 5:36 pm | |
| alright, so they should be around 22", that works out nice, didnt get anything done today, been raining since last night. | |
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4698 Posts : 356
Thunderdivine Veteran Member
| Subject: Re: lifted craftsman May 6th 2013, 4:35 pm | |
| thanks guys those front tires are only 16"s lol but i am puting 20"s on the rims cause those are the ones that came off the mtd gt, the rims are 6.5 wid, the tires are 10" wide, so they should be 21.5" tires, wich should make the front 1/2 a inch lower than the back | |
| Subject: Re: lifted craftsman May 6th 2013, 9:47 pm | |
| well, my 20" tires wont hold air, so im going to use my 18" ones, proly wont get em on till later on in the week, got alot of crap to do this week | |
| Subject: Re: lifted craftsman May 6th 2013, 9:51 pm | |
| - richie thomas wrote:
- well, my 20" tires wont hold air, so im going to use my 18" ones, proly wont get em on till later on in the week, got alot of crap to do this week
dont we all | |
| Subject: Re: lifted craftsman May 6th 2013, 10:39 pm | |
| lol i have a oficer meeting tomorrow morning at 7:30, have to be at school till 7:00 p.m. for ag inspection for the classroom because the teacher is out of town, he asked me to do it, the i have to work the rst of the week and the weekend
| Subject: Re: lifted craftsman May 19th 2013, 10:35 pm | |
| small update, i got my 18 in tires on the front of dixie last week, hadn't thought about it to put it on here lol i did a cold start of dixie on video the other day, its the latest vid on my youtube and also the last one i posted on the mini chopper build, i got a application in with the boe and hopefully ill get that job, if i do i will buy the parts and get this and the ini done in about 1 1/2 week lol | |
MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4746 Posts : 477 Location : Haddock,Georgia
| Subject: Re: lifted craftsman May 20th 2013, 11:51 pm | |
| makg more progress then me lol i havent even started on my lift yet great work richie | |
| Subject: Re: lifted craftsman May 27th 2013, 12:02 am | |
| well, i have the money, now i got to find a 3 or 4 inch coupler for my shaft extension, any ideas?
Guest Guest
| Subject: Re: lifted craftsman May 27th 2013, 12:56 am | |
- well, i have the money, now i got to find a 3 or 4 inch coupler for my shaft extension, any ideas?
Check out RWD full size GM cars from the late 70's and early 80's. They used a longer coupler with a universal joint ( maybe 2, can't remember) on the underhood section of the steering column/shaft. Should be able to hold up well, assuming lubrication can be taken care of. Found that it'd fit an input shaft for a transaxle with a bit of bevel added to the shaft, and/or some building up of metal for the 'big' end. late 80's gm FWD cars had something similar in the tilt portion of the column, shorter and smaller but also less sturdy. |
| Subject: Re: lifted craftsman May 27th 2013, 2:39 pm | |
You could cut the center section out of your pully and weld it to the jack shaft setup. | |
| Subject: Re: lifted craftsman May 27th 2013, 9:31 pm | |
| tried that, but by the time i welded it solid to my liking, it had warped the metal lol, i found a 3 in one on line and ima order it either this week or next
xxXMowerdudeXxx Established Member
| Subject: Re: lifted craftsman May 27th 2013, 10:22 pm | |
| yea, exactly like that, that is from surplus center, might as well order it from their site, tomorow ima go look at a 5/8" u joint, and price it, idk if i want to spend the cash on one tho, | |
Age : 25 Join date : 2013-04-05 Points : 4959 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: tires May 28th 2013, 2:36 pm | |
| Subject: Re: lifted craftsman May 28th 2013, 3:53 pm | |
| - craftsmancole wrote:
- It needs front tires.
lol i know, it has 18" on the front now, but its fine like that, i like it leaning forward a little cause it likes to pop wheelies | |
| Subject: Re: lifted craftsman May 28th 2013, 4:05 pm | |
| lol i know, it has 18" on the front now, but its fine like that, i like it leaning forward a little cause it likes to pop wheelies[/quote]
So I'm not the only one with issues with the front poping off, lol
| Subject: Re: lifted craftsman May 28th 2013, 4:07 pm | |
| lol this damn thing can be going down the road in 1st and if you pop the clutch going to 2nd it will pop up lol
