| lifted craftsman | |
+27TheBeal muddstir Jerbear0612 cumminsbayou k2500life RCG genegillis5 LAWN MOWER MUDDER Doc Sprocket craftsmancole motorizedeverything MowBandit redlinemotorsportts greener179 mudmonkey06 Murray modder TheRainbowBoxer Thunderdivine Marines2621 dked41 matthew sidor xxXMowerdudeXxx Chopperhed Kel truckin42 Doug richie thomas 31 posters |
| Subject: Re: lifted craftsman April 24th 2013, 3:01 pm | |
| - richie thomas wrote:
- noit doesnt, and now im debating on lifting it lol, its a 77 sears
Yeah i would lift. But its up to you what you want to do with it. it will prolly get lifted, although i might make it a rat rod Rat rod racin mower. that would be my next build hands down and that would be a perfect candidate. | |
richie thomas Veteran Member
| Subject: Re: lifted craftsman April 24th 2013, 3:03 pm | |
Yeah i would lift. But its up to you what you want to do with it. it will prolly get lifted, although i might make it a rat rod Rat rod racin mower. that would be my next build hands down and that would be a perfect candidate. ill make up my mind......eventually lol i think ima work on the mini next | |
truckin42 Veteran Member
| Subject: Re: lifted craftsman April 24th 2013, 3:17 pm | |
Yeah i would lift. But its up to you what you want to do with it. it will prolly get lifted, although i might make it a rat rod Rat rod racin mower. that would be my next build hands down and that would be a perfect candidate. ill make up my mind......eventually lol i think ima work on the mini next Sounds good. | |
| Subject: Re: lifted craftsman April 24th 2013, 6:14 pm | |
| so, can anyone tell me why my motor wont run my lights? i have the kill wire wired up right, and the red wire has to e going to the battery cause of the 12v coil that leaves one wire, and it doesn't work my lights, i know the lights themselve work, caue if i touch the wire to the battery they come on | |
| Subject: Re: lifted craftsman April 24th 2013, 6:55 pm | |
| I'd get a meter to see if the motor is producing the power. Clean up the ground too. | |
| Subject: Re: lifted craftsman April 25th 2013, 9:07 pm | |
| well, good news and bad news, the good news, i got her running and pulled some trees out the ground, the bad news the heavy s.o.b. flipped backwards on me while pulling them up lol, then the shaft somehow got warped and broke the pillow block lol | |
| Subject: Re: lifted craftsman April 26th 2013, 6:57 am | |
- well, good news and bad news, the good news, i got her running and pulled some trees out the ground, the bad news the heavy s.o.b. flipped backwards on me while pulling them up lol, then the shaft somehow got warped and broke the pillow block lol
Wow did you get hurt? It sounds like it needs waight in the front end. | |
| Subject: Re: lifted craftsman April 26th 2013, 9:05 pm | |
| na im fine, and yea it needs more weight up front | |
| Subject: Re: lifted craftsman April 26th 2013, 9:07 pm | |
| I think you should hook lower on the machine but you do have that nice ball hitch on it haha | |
| Subject: Re: lifted craftsman April 26th 2013, 9:10 pm | |
| lol im contemplating lowering the hitch down now lol its fine pulling a heavy trailor, but it dont work pulling up trees | |
| Subject: Re: lifted craftsman April 26th 2013, 9:13 pm | |
| Yea all it wants to do is drive under you the whole time, I guess you found youre limit on pulling
| Subject: Re: lifted craftsman April 26th 2013, 9:21 pm | |
| yea, pull anything except a tree when its still in the ground, | |
| Subject: Re: lifted craftsman April 26th 2013, 9:25 pm | |
- yea, pull anything except a tree when its still in the ground,
Yeah does it pull a tree if its cut down? | |
Chopperhed Moderator
| Subject: Re: lifted craftsman April 26th 2013, 10:23 pm | |
| allow me to share an old trick
get yourself a barrel or drum or old tireérim, whatever, something round that you can run a chain or cable over.
tie of on the tree as low as possible, run the cableéchainéstrap over the round thing, and pull.
Pulling straight up, works much better than trying to pull sideways.
Just like pulling a weed
Old offroaders trick. works to lift big things out of a deep rut too. | |
| Subject: Re: lifted craftsman April 27th 2013, 2:14 am | |
| truckin, yea it will pull one easy if its already out, chopper, i will try that, but im not really to anxious to have the heavy sob flip on me again lol, after it flipped on me i turned around and hooked the chain to my front bumper, it pulled the other one up like that, and i didn't have to worry bout her flipping lol | |
greener179 Member
| Subject: Re: lifted craftsman April 27th 2013, 3:14 am | |
| Just think of the bright side atleast your didnt have your 29hp on there already. Lol | |
| Subject: Re: lifted craftsman April 27th 2013, 7:23 pm | |
| - greener179 wrote:
- Just think of the bright side atleast your didnt have your 29hp on there already. Lol
yea, thats a good point lol | |
| Subject: Re: lifted craftsman April 27th 2013, 7:40 pm | |
| got the stock head lights wired up today, the wire coming from the flywheel that powers the lights doesn't work, but the on that charges the baterry does work, so i wired it to the battery side of the solenoid | |
| Subject: Re: lifted craftsman April 27th 2013, 8:10 pm | |
- got the stock head lights wired up today, the wire coming from the flywheel that powers the lights doesn't work, but the on that charges the baterry does work, so i wired it to the battery side of the solenoid
Oh ok so now the lights work? | |
| Subject: Re: lifted craftsman April 27th 2013, 8:15 pm | |
| yea, the stock ones do, but im going to buy some big led's to mount on the bumper cause these aint bright enough | |
| Subject: Re: lifted craftsman April 27th 2013, 8:17 pm | |
- yea, the stock ones do, but im going to buy some big led's to mount on the bumper cause these aint bright enough
Yeah like what FF got but bigger? | |
| Subject: Re: lifted craftsman April 27th 2013, 8:22 pm | |
- yea, i found a set of 5" dia. round ones
Ya those would be perfect. | |
| Subject: Re: lifted craftsman April 27th 2013, 9:00 pm | |
| yea, i want to get a big led light bar to mount where the stock lights are | |
