My shaft couplers showed up today while I was at work. Got home at 7:30pm, had some dinner, then went down to the shop to see what I can get done. I welded three of the shaft couplers together and slid them onto the existing axle shaft with keystock and set screws. Slid on the adapter plates and tube and bolted on the rim and tire. All the work of measuring worked out great. The tires are inline with the fronts. Now I just need to finish welding the first hub together and then weld the second one together. That will be tomorrow afternoon. I hope to go for a ride right after that!
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
Was out all day so didn't get started to till 7:00pm. Got one hub assembled and welded together. Going to finish the other tomorrow and take it out for a ride. Stay tuned for pictures and video once I get her out of the shop!
I ate breakfast this morning then went down to the shop and went gang busters at it. Got the rear hubs all welded up and mounted to the existing axles. Mounted the rear tires and rolled it off the lift. I had to grease the front bearings as they were new and I had put them on during fabrication for fit. Got those done and remounted then outside she went. The battery was weak from sitting all winter so I had to start it with the jump pack. She fired right up and runs great. It drives perfect and the shifter works good. The steering is surprisingly very easy. I am thrilled at the way it came out. Now to paint the metal I added, the rear-end and touch up anything else that needs it. Can't wait to bring it to the next tractor show!!!
No one around here that I know of lifts tractors. Many customize them and lower them. I'm from the old school of lifted trucks. In my teen years I built an 1982 Chevy Blazer with 2.5" of suspension and 2" body lift running 35" tires. Nothing crazy but made it look real good. This was like a trip down memory lane for me. Now lets see if I can leave well enough alone.
Went over to my friends house to paint the undercarriage. I ended up painting the transmission silver. I don't really like it and plan on changing it to something else. Everything else ended up black. Here's a picture after I finished.
Seeing as I have that extra pulley hanging down there I thought about running a 12 volt alternator or something off of it. Maybe fab up an old school roll bar with big lights on it! Who knows!
Age : 30 Join date : 2013-03-18 Points : 4922 Posts : 618 Location : loxahatchee, florida
Just and update. I didn't want to just trust the single set screw against the keystock to hold the hubs and tires onto the axle. So I drilled out one on the set screw holes in the hub that was located closer to the inner end of the axle. Then used a transfer punch to make a mark on the axle shaft. Removed the hub and drilled and tapped it for a 1/4-20 bolt. Now the hub is firmly bolted to the axle along with the original set screw and key stock.
Here are two more pictures of the finished project. The second one has me in it so you can see a size comparison. Don't know if this is a far as I am going to take it. I may opt for a paint job and maybe some type of roll bar so I can put some lights on top!
Doug Site Owner
Not really an update but I took the tractor to it's first show at the end of September and it was a huge hit. Most people around here had never seen anything like it before. I barely had time to sneak away and roam around the show because of all the interest and questions. I actually turned down an offer to buy it for a $700 from a guy who's kid really wanted it. I decided not to paint it and leave a stock theme to it.
Doc Sprocket Site VIP
Yeah the rubber bungee is holding the brake lever back. I haven't found the right spring yet or should I say I ran out of time before other projects called! I have to weld a nut on to the square tubing for the lift so I can attach the spring when I get it. I guess I got all winter to get that done!
Just a quick update and say hi. Haven't done much at all with my tractors this winter. I did manage to get rid of the bungee cord and replace it with a spring. Have a few ideas on some changes but I may just leave well enough alone. Still have to make a support for the upper part of my shifter extension so it won't flex as much. I may work on that this week.
