 Project Craftsman mud mower
mrpinhead11
Project Craftsman mud mower Empty
PostSubject: Project Craftsman mud mower   Project Craftsman mud mower Icon_minitimeFebruary 8th 2013, 11:08 pm
here is the crafsman mud mower project.
TO DO LIST:
1. Rear rack
2. tighten steering
3. bigger bumper
4. pulley swap
5. better tires
6. look tranny
here is the stock mower
Project Craftsman mud mower Tracto14[code]
here is the new bumper
Project Craftsman mud mower Tracto15
hahaha i almost flipped it
Project Craftsman mud mower Tracto16
here are the new tires
Project Craftsman mud mower Tracto17
PostSubject: Re: Project Craftsman mud mower   Project Craftsman mud mower Icon_minitimeFebruary 8th 2013, 11:28 pm
If the steering is similar to the one on my 99 weedeater - i swapped a steering setup off a 85LT 12 parts tractor - the 99 had some plastic parts and allowed the gears to slip when steering, the 85LT 12 setup was practically a bolt in affair.
I have pics if you want to see them.
mrpinhead11
PostSubject: Re: Project Craftsman mud mower   Project Craftsman mud mower Icon_minitimeFebruary 8th 2013, 11:31 pm
yeah theres worn out plastic bushings but im going to try to make my own bushings outa brass
PostSubject: Re: Project Craftsman mud mower   Project Craftsman mud mower Icon_minitimeFebruary 8th 2013, 11:40 pm
They make brass bushings, you may be able to just buy some at a hardware store.
mrpinhead11
PostSubject: Re: Project Craftsman mud mower   Project Craftsman mud mower Icon_minitimeFebruary 9th 2013, 12:01 pm
yeah thats probably what ill do Smile
PostSubject: Re: Project Craftsman mud mower   Project Craftsman mud mower Icon_minitimeFebruary 10th 2013, 6:54 pm
I used copper couplings in mine as a 'quick fix' - the setup was all worn, so i used a regular wood spade bit ( yes for cutting holes in wood) - just big enough to set the slightly cut down copper bushings tightly , greased it all up and put it back together - it helped alot for a few years, then just wore out again.
The steering shaft attaches to the top of the "t" with a bolt - you have to remove the main gear setup that comes from the steering arm to get to it. Was a serious pain for me to do, besides having to pull the motor to access the whole thing.
I had a spare parts LT12 craftsman , so i just swapped the whole thing over - was literally bolt in, with a few minor mods.
I have pics of the swap if you want to see them.
» Craftsman Rally Mower Project
» Project Parts Bin (Craftsman)
» An old Orange Craftsman Project
» New Craftsman Project
