| Project UTV | |
+9TheRainbowBoxer CornishMorgan Chopperhed Doug truckin42 W1ldyOvvnZ muddstir dangeroustoys56 Jonny Briggs 13 posters | |
Jonny Briggs New Member
| Subject: Re: Project UTV Wed Feb 06, 2013 4:30 am | |
| What's a posi set up? The rear axle is solid but front will be left open to help with steering.
The central diff will help with tyre scrubbing.
The steering was a lucky eBay find, they were listed as small tractor PTO
Hoping to get the sprockets on this weekend.
Then make the Ragb for engine | |
| | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 5167 Posts : 745 Location : The Wyo-Braska Panhandle
| | | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5257 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Project UTV Wed Feb 06, 2013 12:53 pm | |
| - Jonny Briggs wrote:
- What's a posi set up? The rear axle is solid but front will be left open to help with steering.
Posi or Posi-traction, General motors term for limited slip differential. Dragracers on a budget using 9" ford diffs, would put stiff springs between the spider gears to create a limited slip. Yamaha Big Bear ATV use 2 small clutch discs | |
| Subject: Re: Project UTV Sun Feb 17, 2013 11:55 am | |
| Got a few updates on the UTV build. Got the steering sorted and sourced a peerless 5 speed gearbox. I have decided to use my 11hp b and s vertical shaft engine with the peerless gearbox as I cannot afford the torque converter and horizontal engine. This is the jackshaft that will split the power to the front and back axle. I am ordering the chain and sprockets so should have some progress on the drivetrain this week. | |
| | | THE MTD GUY Member
Age : 27 Join date : 2013-02-15 Points : 4373 Posts : 69
| Subject: Re: Project UTV Thu Feb 21, 2013 9:03 am | |
| that looks reall nice on what u got done so far. what are u going to name her? | |
| | | truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5506 Posts : 1070
| Subject: Re: Project UTV Thu Feb 21, 2013 9:12 am | |
| It looks like its coming together. | |
| Subject: Re: Project UTV Sat Feb 23, 2013 5:23 am | |
| I should be mounting the engine this weekend, then I can sort out the clutch and gearbox location. Then sort the chains and sprockets out. | |
| Subject: Re: Project UTV Wed May 15, 2013 5:10 pm | |
| Hows the project going I can't wait to see it? | |
| | | RuggBateman New Member
Join date : 2013-05-20 Points : 4219 Posts : 9 Location : Concord NH
| Subject: Re: Project UTV Wed Jun 12, 2013 11:26 pm | |
| anything happening? or did the project die? | |
| | | | | Project UTV | |
| Who is online? | In total there are 42 users online :: 1 Registered, 0 Hidden and 41 Guests RichieRichOverdriveMost users ever online was 412 on Sat Jan 07, 2023 6:59 am |
