 Project Big Cat
xxXMowerdudeXxx
Chopperhed
THE MTD GUY
CornishMorgan
crafsmankiller
W1ldyOvvnZ
Trikahilux
greener179
WellThatsSurprising
20 posters
Go to page : 1, 2, 3, 4, 5  Next
WellThatsSurprising
WellThatsSurprising
Project Big Cat Empty
PostSubject: Project Big Cat   Project Big Cat Icon_minitimeAugust 30th 2012, 7:58 pm
Tractor is originally a 1969 Sears suburban 12
Project Big Cat 1st10
New push-bar I made from bmx handlebars:
Project Big Cat 2012-011
Upgraded push-bar:
Project Big Cat 2012-012
Gas pedal/carb:
Project Big Cat 2012-013
Project Big Cat 2012-014
Headlights:
Project Big Cat 2012-015
Tail light:
Project Big Cat 2012-016
Relocating intake (In progress):
Project Big Cat 2012-017
What i'm going to do for it is weld a bushing to the outlet of the carb and and another to the air filter and run a rubber hose.
Difference between old front tires and new:
Project Big Cat 2012-018
Last edited by WellThatsSuprising on December 5th 2012, 4:34 pm; edited 1 time in total
greener179
greener179
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeAugust 30th 2012, 10:21 pm
what size diffrence are the new tires compared to the old
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeAugust 31st 2012, 1:39 pm
The old front tires were 15x6x6, The new ones are 22.5x7.50x12
greener179
greener179
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeAugust 31st 2012, 2:27 pm
lucky i been trying to fit 22s on the front of mine forever
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeNovember 24th 2012, 2:48 pm
Took it out for a ride in the fresh snow yesterday even though the belt that's on it is a few inches too long.
Project Big Cat 2012-110
Project Big Cat 2012-111
Project Big Cat 2012-112
Project Big Cat 2012-113
Trikahilux
Trikahilux
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeNovember 25th 2012, 6:32 pm
That cool man!
i wanna see that air intake finished, thinking about doing that myself.
i also used the same bike bars for the basic structure of my front bumper. Cool
keep the updates coming!
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeNovember 25th 2012, 8:50 pm
Will do!
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 6th 2013, 12:10 am
Another thing added to the list of stuff I need: New piston rings. That breather should not be throwing out that much.
Other than that, had a fun time whipping it around in front of my garage, will put chains on tomorrow.
Project Big Cat F110
Project Big Cat F210
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 6th 2013, 3:06 am
Ha, looks like fun. You should try that in my driveway, its so slick in some spots I can get the Jeep stuck in 4.
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 6th 2013, 5:22 pm
It probably doesnt have a replaceable breather assembly? If it does, id replace that first , another thing to try is some PB blaster in the combustion chamber to see if its just a sticky ring or two - the PB will free up a sticky ring.
Easier then tearing into the motor if it works.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 6th 2013, 6:40 pm
The breather is replaceable and it's only a $20 fix for rings. And i've had about 4 of these tractors with the same motor so I know all their problems.
In other news I got the tire chains on!
With a little modification...
Project Big Cat T110
But finally, on.
Project Big Cat T210
Then I was onto plowing through snow with the power of a thousand suns!
Project Big Cat T310
Project Big Cat T410
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 6th 2013, 7:31 pm
Chains are no fun. lol
I never noticed it, but I really like your tractors body design.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 6th 2013, 7:40 pm
Thanks, the whole things made up of 1/4 inch thick steel and aluminum.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 7th 2013, 1:05 am
Which makes it very heavy, I have to tow it back into my garage.
Project Big Cat 13575010
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 7th 2013, 1:17 am
Haha. Well, thats one use for a self-propelled snowblower. I rented one of those last year, nice machines.
What broke/ stopped working on it?
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 7th 2013, 1:21 am
It needs a new battery so I have to start it off a charger each time.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 11th 2013, 6:45 pm
Working on new modifications.
Project Big Cat 52610410
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 11th 2013, 7:21 pm
i like your welding cart:) what modification are you doing to it?
http://www.stat10.tk/
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 11th 2013, 7:42 pm
Haha, whatever works, works! Working on the intake.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 11th 2013, 10:40 pm
Ok, new plan! Considering the age of the engine (Was built in 1969 and still has all original parts) I shall be doing a complete rebuild instead of just rings. Exciting, yes? Also, on top of that I am going to be tearing down the frame completely and re-painting. So far my choices are pink and white or pink and black. Imagine the parts that are currently painted orange (minus the engine) pink and the rest white or black.
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 13th 2013, 6:59 pm
got that same welder man lol i really like mine how does yours work for you?
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 14th 2013, 12:25 am
It works alright for the price but i'm going to buy a nice TIG machine soon.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 14th 2013, 2:17 am
Now for something completly unheard of in this thread! Progress... Haha, just kidding.
Started on the tear-down tonight. Pictures are better than words.
Drained the oil... Ew.
Project Big Cat W111
Goodbye fuel tank and battery.
Project Big Cat W210
So much room
Project Big Cat W310
Up, up and away!
Project Big Cat W410
Well isn't that gross.
Project Big Cat W510
Project Big Cat W910
Away with the tank/battery holder!
Project Big Cat W710
Electrical systems are for wussies.
Project Big Cat W810
Motors are also for wussies.
Project Big Cat W1110
FLIP!
Project Big Cat W1210
Look at dat heavy duty.
Project Big Cat W1310
More heavy duty.
Project Big Cat W1410
OOPS. I BROKED IT. Just kidding, It's fine. More to come tomorrow!
Project Big Cat W1510
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 14th 2013, 2:25 am
Last I checked oil isnt supposed to be grey. Gross. And is that water in the head?
I like that body design more and more, its so unique. The way it splits in half is pretty cool.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Project Big Cat   Project Big Cat Icon_minitimeJanuary 14th 2013, 2:53 am
Yup, that's why the oil was colored too. It's ok though, I'm doing a complete rebuild with brand new parts. Well, not brand new. But newer.
Project Big Cat
Page 1 of 5Go to page : 1, 2, 3, 4, 5  Next
» New MTD project
» NEw project
» The mud bog project
» Got a new project…
» first project
