| | How to swap engine pulley on a briggs? | |
+4dked41 thatrandomguy offroadredneck Mark288 8 posters | Author | Message |
Mark288 Member
![Mark288](https://2img.net/u/2812/37/66/46/avatars/595-62.jpg)
Age : 27 Join date : 2013-01-20 Points : 4325 Posts : 48 Location : Southern Wisconsin
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | Subject: How to swap engine pulley on a briggs? January 20th 2013, 11:06 am | |
| Hey guys, i have an mtd mower. 18 hp opposed twin cyllender. I did a rear pulley swap, with the 3 inch (steel) welded it to the shaft, becasue i had too many problems with the aluminum ones. Anyway, the pulley that comes off the crankshaft on the engine, how do you take that off? the stock is a 3.5 inch i think, thats too small for me. I took the bolt out and its like machine pressed in there and me or my dad coudnt get it off. Any of you guys know how to take that off? Any info is much appreciated. Thanks mark | |
| ![Go down](https://2img.net/i/empty.gif) | | offroadredneck Member
![offroadredneck](https://2img.net/u/2812/37/66/46/avatars/564-24.jpg)
Age : 26 Join date : 2013-01-03 Points : 4344 Posts : 64 Location : plantcity FL
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | thatrandomguy Member
![thatrandomguy](https://2img.net/u/2812/37/66/46/avatars/310-6.jpg)
Age : 27 Join date : 2012-03-28 Points : 4619 Posts : 56 Location : netherlands
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | Subject: Re: How to swap engine pulley on a briggs? January 20th 2013, 1:15 pm | |
| buy or make a puller. i couldnt get my pulley off last week so i made a puller myself out of flat stock and long bolts. if you dont know what these pullers look like here's a picture ![How to swap engine pulley on a briggs? Pullytrekker-3-arm-300240_zps9c956e71](https://2img.net/h/i1326.photobucket.com/albums/u641/thatrandomguy1997/pullytrekker-3-arm-300240_zps9c956e71.jpg) i made one with two arms. i can make a picture if you want? | |
| ![Go down](https://2img.net/i/empty.gif) | | dked41 Member
![dked41](https://2img.net/u/2812/37/66/46/avatars/265-1.jpg)
Age : 60 Join date : 2012-01-31 Points : 4734 Posts : 141 Location : central Wisconsin
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Chopperhed Moderator
![Chopperhed](https://2img.net/u/2812/37/66/46/avatars/469-45.jpg)
Age : 58 Join date : 2012-10-14 Points : 5180 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | dangeroustoys56 Veteran Member
![dangeroustoys56](https://2img.net/u/2812/37/66/46/avatars/4-60.jpg)
Age : 53 Join date : 2010-02-10 Points : 7002 Posts : 1726 Location : Florida, USA
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | Subject: Re: How to swap engine pulley on a briggs? January 20th 2013, 4:46 pm | |
| Most motor pulley's ive encountered have come off fairly easy , remove the bolt - few taps with a hammer on the deck pulley part and nearly fall off on their own. One pulley on a 12HP teccy i have would fight me all the way , even after never seizing it.
I had one odd one on my 88 kleen kut - instead of a bolt, it had a metal 'slug' holding the pulley on - had to cut the pulley off - that was an 18HP twin briggs opposed.
If you plan on saving the pulley, be careful you dont bend the pulley trying to get it off. | |
| ![Go down](https://2img.net/i/empty.gif) | | tractorboy567 Member
![tractorboy567](https://2img.net/u/2812/37/66/46/avatars/562-12.jpg)
Age : 26 Join date : 2013-01-02 Points : 4383 Posts : 121 Location : PA
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Tuffy55 Member
Join date : 2013-01-07 Points : 4295 Posts : 31 Location : MI
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | Subject: Re: How to swap engine pulley on a briggs? January 21st 2013, 8:32 pm | |
| I welded a large nut to the bottom of the pulley then put a small bolt through the nut to act as like a push rod i threaded the larger bolt into the nut to push on the small bolt.
i switched to longer push bolts the farther i got the pulley off.
![How to swap engine pulley on a briggs? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | How to swap engine pulley on a briggs? | |
| Who is online? | In total there are 129 users online :: 1 Registered, 0 Hidden and 128 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
