| New brakes for tractor axle? | |
+3Ariens YT11 Chopperhed Doug 7 posters | Author | Message |
Doug Site Owner
| Subject: New brakes for tractor axle? January 8th 2013, 10:19 pm | |
| Well, ive been looking for a while now and im having a hell of a time finding a brake rotor or brake hub that will fit an standard 3/4" transaxle shaft. Anybody know where to find one, or at least a reducer? Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| | | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 5164 Posts : 745 Location : The Wyo-Braska Panhandle
| | | | Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5701 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: New brakes for tractor axle? January 9th 2013, 12:57 pm | |
| That hub won't fit that rotor, different bolt patterns. Didn't see a 3/4 hub with the right pattern on that site. | |
| | | Doug Site Owner
| Subject: Re: New brakes for tractor axle? January 9th 2013, 1:49 pm | |
| That hub might work. I could probably buy a rotor or two and try modding it to fit. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5251 Posts : 499 Location : Winchester, ON, Canada
| | | | Doug Site Owner
| | | | W1ldyOvvnZ Member
| Subject: Re: New brakes for tractor axle? January 9th 2013, 9:45 pm | |
| Good thing i posted it, i was debating on whether or not to post it because it was so similar to "Arens YT11". i remembered BMI karts having a 3/4" to 1" adapter but you needed to get a special bit of keystock. | |
| | | Doug Site Owner
| Subject: Re: New brakes for tractor axle? January 9th 2013, 10:03 pm | |
| - W1ldyOvvnZ wrote:
- Good thing i posted it, i was debating on whether or not to post it because it was so similar to "Arens YT11". i remembered BMI karts having a 3/4" to 1" adapter but you needed to get a special bit of keystock.
Honestly ill probably just end up welding the bushing to the axle and just key the hub. Be cheaper and easier than sending the axle off to be milled for a key slot. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | W1ldyOvvnZ Member
| Subject: Re: New brakes for tractor axle? January 9th 2013, 10:13 pm | |
| yeah that would work but the bushing from BMI karts is Billet Aluminum and isn't the axle steel?
i think the 3/4" to 1 1/4" adapter fits the normal keyway for a lawn tractor(i think the lawn tractor key way is 3/16") but the 3/4" to 1" adapter(the one i cant find a link to anymore) uses a 3/16"x3/8" Piece of Keystock. | |
| | | Doug Site Owner
| Subject: Re: New brakes for tractor axle? January 9th 2013, 10:29 pm | |
| - W1ldyOvvnZ wrote:
- yeah that would work but the bushing from BMI karts is Billet Aluminum and isn't the axle steel?
i think the 3/4" to 1 1/4" adapter fits the normal keyway for a lawn tractor(i think the lawn tractor key way is 3/16") but the 3/4" to 1" adapter(the one i cant find a link to anymore) uses a 3/16"x3/8" Piece of Keystock. Is it aluminum? I didnt check on that, I assumed it was steel. Doesnt realy matter if its 1" or 1 1/4" cause that hub is made in both sizes. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4419 Posts : 491 Location : Index, Washington
| Subject: Re: New brakes for tractor axle? August 6th 2014, 2:53 pm | |
| Why do they make adaptors like that? They know they are dealing with specific keyway sizes. Otherwise they wouldn't know what size slot to cast into the adaptor. Why not make the whole thing stronger, and easier to use by casting the keys into the adaptor? Like this: Brown being the rusty old axle, and red the nice shiny wheel, of course. LOL | |
| | | Doc Sprocket Site VIP
| Subject: Re: New brakes for tractor axle? August 6th 2014, 4:51 pm | |
| It's a manufacturing thing. Doing it as a casting, is not very dimensionally accurate. Machining would generally be required, and even then, still would not be as strong as a forging. Now- if they forged it (and subsequently broached the two keyways in line like that) you end up with a weak spot. | |
| | | Angchor Member
| Subject: Re: New brakes for tractor axle? August 6th 2014, 6:25 pm | |
| - Doc Sprocket wrote:
- It's a manufacturing thing. Doing it as a casting, is not very dimensionally accurate. Machining would generally be required, and even then, still would not be as strong as a forging. Now- if they forged it (and subsequently broached the two keyways in line like that) you end up with a weak spot.
True. Especially with the sharp angles like that. | |
| Who is online? | In total there are 67 users online :: 1 Registered, 0 Hidden and 66 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 6:59 am |
