| yard king racing/offroad mower build. | |
+7Ariens YT11 tralme98 dangeroustoys56 AcreFarm CornishMorgan Craftsman Dude thatrandomguy 11 posters |
thatrandomguy Member
Age : 27 Join date : 2012-03-28 Points : 4693 Posts : 56 Location : netherlands
| Subject: yard king racing/offroad mower build. November 19th 2012, 10:20 am | |
| hi all. the yard king originally had a 11hp but it will be replaced with a 18 hp briggs twin. -transaxle is cleaned, locked, and packed with fresch grease. -tubes in rear tires. -front and rear bumper welded. To do list: -new steering setup. -lock front end in place. -plant 18 hp twin. -pulley swap. -new clutch setup. -seperate brake pedal. -gas pedal. Pictures: updates to come. with better pictures. Sander. | |
Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4612 Posts : 145 Location : MS
CornishMorgan Member
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4936 Posts : 208 Location : Tennessee
| Subject: Re: yard king racing/offroad mower build. November 20th 2012, 1:28 pm | |
| - AcreFarm wrote:
- From the pic I'd guess a Peerless 900, 920 or 930
I've got a locked 900 in my tractor; so far it's held up fine im hoping me weld holds, im not that good with electrodes. getting a little flux core welder soon. | |
| Subject: Re: yard king racing/offroad mower build. November 20th 2012, 1:40 pm | |
| some updates: welded the front end in locked. flipping front pulley: cut the long end off and welded it on to the other side. my welder, grinder and welding helmet: Sander. | |
AcreFarm Member
| Subject: Re: yard king racing/offroad mower build. November 20th 2012, 1:52 pm | |
| Wow, those are nice clean welds, I cant get welds to look that good with my arc welder. You must of had way more practice than I have. Keep up the great work . | |
| Subject: Re: yard king racing/offroad mower build. November 20th 2012, 4:04 pm | |
| - AcreFarm wrote:
- Good progress!
I did not weld mine, I used 2 extra spider gears. That is alot less cleaning or having the risk of the weld breaking. I dont have extra spider gears so i just like welding them. | |
| Subject: Re: yard king racing/offroad mower build. November 20th 2012, 4:15 pm | |
| - mlwinters wrote:
- Wow, those are nice clean welds, I cant get welds to look that good with my arc welder. You must of had way more practice than I have. Keep up the great work .
Thanks. I make nicer welds using mig. Getting a little mig soon. I do practise quite alot, but im still not happy with my arc welds. Sander. | |
| Subject: Re: yard king racing/offroad mower build. November 21st 2012, 1:23 pm | |
| updates: have been working on the briggs twin today: one of the intake manefolt ears broke off: does anybody have an idea how to fix this? is it possible to weld it or something? muffler off: my brother talkt me into doing stacks on the mower. im trying to figur out what size rear pulley i should get to get a top speed of about 30/35 mph? anybody have an idea? | |
| Subject: Re: yard king racing/offroad mower build. November 26th 2012, 1:18 am | |
| JB weld wouldve worked for the intake crack - ive used it to repair some small holes on a couple tractor decks as well.
Id probably go a lil longer on those exhaust tubes- i ran shorty pipes on my mod murray and the thing backfired /popped like crazy - it can eventually burn a valve - briggs motors like a little back pressure. | |
| Subject: Re: yard king racing/offroad mower build. November 26th 2012, 9:19 am | |
| - dangeroustoys56 wrote:
- JB weld wouldve worked for the intake crack - ive used it to repair some small holes on a couple tractor decks as well.
Id probably go a lil longer on those exhaust tubes- i ran shorty pipes on my mod murray and the thing backfired /popped like crazy - it can eventually burn a valve - briggs motors like a little back pressure. Im hoping this will hold up, but if it doesn't i will JB weld it. The straght pipes are going to be a bit longer, problably exiting underneath the runningboards. | |
| Subject: Re: yard king racing/offroad mower build. November 27th 2012, 9:41 am | |
| Cool - when i get around to building my rat rod wheelhorse i plan on putting pipes like this on it, cept a lil bit more under the foot rests : ( No this isnt my tractor) | |
tralme98 Member
Join date : 2012-11-29 Points : 4408 Posts : 26 Location : United States
| Subject: Sup December 1st 2012, 11:56 pm | |
| Hey awesome tractor man! I just started mine today and have some of the things your doing and doing them on mine but I dont think ill put stacks on mine. Awesome work, keep it up! - Trent | |
| Subject: Re: yard king racing/offroad mower build. December 10th 2012, 5:47 pm | |
- Cool - when i get around to building my rat rod wheelhorse i plan on putting pipes like this on it, cept a lil bit more under the foot rests :
( No this isnt my tractor) That is going to look slick, what engine is the rat rod getting? | |
| Subject: Re: yard king racing/offroad mower build. December 10th 2012, 5:53 pm | |
| - tralme98 wrote:
- Hey awesome tractor man! I just started mine today and have some of the things your doing and doing them on mine but I dont think ill put stacks on mine.
- Trent Thanks alot. Get some pics of your mower and post them on the forum. I would love to see it. Im not going with stacks anymore, because of the exhaust fumes getting in my face. Sander. | |
| Subject: Re: yard king racing/offroad mower build. December 10th 2012, 7:06 pm | |
| That was a pic i found on a racing tractor website - altho i have a couple stock tractors of the same model.
My rat rod is going to have a 03 bolens chassis ( MTD) , and original unpainted rusty sheetmetal off my 69 raider 10 wheelhorse - itll be lowered, 8" golf kart rims all around, straight rear axle, and a 18HP twin opposed briggs - debating on wether to use a peerless 700 or right angle gear box with go kart clutch.
| Subject: Re: yard king racing/offroad mower build. December 11th 2012, 4:58 pm | |
- That was a pic i found on a racing tractor website - altho i have a couple stock tractors of the same model.
That bolens frame is going to be very strong and the wheelhorse sheetmetal is going to look sweet. The 18 horse briggs are great engines. Are you going to do any mods to the engine? I have a peerles 700 laying around, pretty strong transmissions. Ive seen people put little needle bearings in them to replace the bushings. Its nice to be able to shift, and having lots of torque. Right angle gearbox is easy to install and setup. But its more exspensive. | |
| Subject: Re: yard king racing/offroad mower build. December 12th 2012, 1:27 am | |
| I have one thats stock that was on a mod murray, i ran it with the governer and it was scarey fast - i have another briggs 18HP that i was trying to set up dual carbs on to see if it even ran ( was missing carb and intake) , i bot a couple street scooter carbs at a flea market - i was thinking of hooking one up with a custom intake possibly. Its still up in the air what ill use on it.
I already have both - the 700 peerless and the RAGB - the 1:1 RAGB i bot off ebay for $25 because a pulley is stuck on it ( ill have to cut if off) .
Itll be a bit before i get working on it - i have a few other projects and stock mowers to work on first. | |
| Subject: Re: yard king racing/offroad mower build. December 12th 2012, 10:46 am | |
- I have one thats stock that was on a mod murray, i ran it with the governer and it was scarey fast - i have another briggs 18HP that i was trying to set up dual carbs on to see if it even ran ( was missing carb and intake) , i bot a couple street scooter carbs at a flea market - i was thinking of hooking one up with a custom intake possibly. Its still up in the air what ill use on it.
Itll be a bit before i get working on it - i have a few other projects and stock mowers to work on first. Dont think those scooter carbs will do. Ive seen people put snowmobile carbs on twins. Works great and gives them lots of power. I bought my 700 togheter with a little RER rear axle with ballbearings for 50 bucks. My toro groundmaster has a RAGB on the rotted out mowing deck. Im hoping i can save the deck, but if i cant save the deck i wil use the RAGB for a project or something. When you do start to build yout ratrod mower, be sure to put it up on the forum. | |
