| Has anyone fitted an electric cluch to their tractor yet? | |
+9AcreFarm dked41 TheRainbowBoxer W1ldyOvvnZ cumminsbayou F150F250F350 Chunk dangeroustoys56 Farmster 13 posters |
Farmster Member
Age : 29 Join date : 2010-08-06 Points : 5269 Posts : 46 Location : Frankfort,Indiana
| Subject: Has anyone used an electronic clutch for a mud bogger? August 6th 2010, 6:42 pm | |
| I was scrolling down Craigslist looking for mowers today and came across a electronic clutch for a Craftsman mower deck. A idea struck me. Has any one ever used this as a drive pulley and it you could engage drive with a button. I think when I find a mower, Ill try this sounds fun for like a mud bogger or wheelies. Let me know what you guys think | |
Age : 54 Join date : 2010-02-10 Points : 7070 Posts : 1726 Location : Florida, USA
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? August 7th 2010, 1:19 pm | |
| Depends if the clutch works or not and how much it is ( a new one goes for $400) - a way to check is hook a normal 12 volt battery to the plug ( pos and neg ) - one to each terminal on the plug- it should lock 'on' and release when disconnected.
I planned on using one when i build my true 4x4 gt6000 ( some year) - would use a wheelhorse trans in front ( its a 3 hi/3 low trans - like the GT's) - a horizontal shaft motor, and run all 4 rear tires of my GT's on it.
Id mount the motor sideways, have the original drive pulley run the rear trans, while the clutch would be hooked to the front trans- i figure youd be able to shift the trans, and lock the trans into a 4x4 as well as a 2 wheel drive setups with a shift of the lever and a flip of a switch.
Theory would be to use 2 wheel drive to get to the offroad site ( faster driving- shift the front trans into neutral and leave the clutch off) and turn the clutch on and shift into one of the 6 gears for full traction.
Best thing about a trans in front is the built in differential, while the rear could be locked . | |
Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6214 Posts : 779 Location : Angus, Scotland
Farmster Member
Farmster Member
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? August 8th 2010, 4:28 pm | |
| - dangeroustoys56 wrote:
- Depends if the clutch works or not and how much it is ( a new one goes for $400) - a way to check is hook a normal 12 volt battery to the plug ( pos and neg ) - one to each terminal on the plug- it should lock 'on' and release when disconnected.
Best thing about a trans in front is the built in differential, while the rear could be locked . Gota be carfull with some wheelhorse trannys my old 1 i shucked the pin that held the right side axle in 2 times but i was rockcralwin with it but i figured out you can take the axe out and drive it on 3 wheels hahha good times | |
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? August 8th 2010, 6:48 pm | |
| The trans actually needs work anyway- the input shaft seals are gone. I had it moving last year, ran it about 10 feet then the trans locked- i tore it apart to build a super mod hot rod from the sheetmetal and a 2003 bolens chassis- ill paint the chassis and leave the sheetmetal alone, itll be low, fast and hopefully look cool when its done.
I planned on using 1" heavy duty ujoints on the front trans to steer and a steering knuckle setup as well- luckily the wheelhorse hubs are the same pattern/size as my GT6000 rear rims - just a fine thread setup.
Only issues id see setting that up would be modding the shift levers to be able to reach them.
Ill run the stock tires at first and save up for some AG tires. | |
Farmster Member
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? August 8th 2010, 8:42 pm | |
| sounds great man btw i just found this site watchin fearless's videos on youtube i wtahced all them then wanted more haha found the fourm its great ....
I used a disengage level off my wheelhorse for a shifter on my rat rod mower but then broke it shiftin thru the gears haha It was a simplicty yeoman great mower for off roading it pivited in the middle | |
Farmster Member
Farmster Member
F150F250F350 Member
Age : 29 Join date : 2011-09-28 Points : 4859 Posts : 52 Location : Oskaloosa Iowa
| Subject: I have one October 20th 2011, 12:34 pm | |
| I have one just never thought about that the only reson I do have it is because I know what it is worth sell it to you! | |
F150F250F350 Member
| Subject: I have one October 20th 2011, 12:37 pm | |
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5015 Posts : 232 Location : fairhope Al.
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? November 30th 2011, 9:35 pm | |
| i think ill do this on my 96 john deer with a hydrostatic transmision in it and put in a old 3 speed i have all i need to do is lift the transmision to line up with the eletric clutch it all ready has on it | |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5245 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? December 8th 2011, 9:25 am | |
| I had though of doing it but it would break you wouldnt go anywhere. What happens if the clutch goes under water? I have one on my mower(for cutting grass) but im not willing to risk $300 to see if it works underwater. | |
F150F250F350 Member
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5695 Posts : 1091 Location : Galion, OH
dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4802 Posts : 141 Location : central Wisconsin
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4930 Posts : 208 Location : Tennessee
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? September 12th 2012, 7:16 pm | |
| - TheRainbowBoxer wrote:
- I would think that would be a very rough all or nothing clutch for the drive. Might be interesting for popping wheelies though...
That's exactly what it would be... no slipping at all. Right up until it burns out. | |
Junkstarbuilds Administrator
Age : 48 Join date : 2012-07-03 Points : 4837 Posts : 236 Location : Fort Stewart Georgia
| Subject: I have two of those.. September 13th 2012, 1:12 am | |
| I have two of those electric pulley clutches..
I been thinking of something to do with them....I think If you come across them the best thing is to sell on ebay if you can.. | |
F150F250F350 Member
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? October 5th 2012, 10:17 pm | |
| Yall mightve herd it, but again a plan for my GT6000 was to use a horizontal twin mounted sideways to run the stock 3 speed hi/low trans in back and a wheelhorse 3 speed hi /low up front - i planned on using the electric clutch to drive the front trans in mud and shut it off for normal use ( 2 wheel drive) - i figure the clutch wont have a whole lot of pressure on it while active , unless it was either in thick mud or a higher gear - the trans should take most of the stress.
Using a electric clutch would give me all kinds of options , in all the gears or shut it off and shift into neutral up front and plain two wheel drive, altho id be running two rear tires up front as well as in the back - monster truck style, with a mild lift to fit them correctly.
Thinking it out it sounds like it would work, altho i havent even tried building it , mainly because one of my two horizontal engines run, and thats already in a mower.
The other thing is i really dont have anywhere to drive something that big around - no nearby mud - so its been in limbo, but still thinking about it. | |
moremorelawnmowers Member
Age : 27 Join date : 2012-08-04 Points : 4623 Posts : 86 Location : New York, Amsterdam
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? October 9th 2012, 2:31 pm | |
| I have always wanted to use one as a clutch for the drive belt. My concerns are will they work under water, will it hold up(there expensive to replace), and i think you would do a wheelie every time you hit the switch wich would be rough on the trans. | |
| Subject: Re: Has anyone fitted an electric cluch to their tractor yet? October 18th 2012, 7:11 am | |
| I wouldnt use an electric clutch in water situations - its basically an electrical coil and would short out.
Even tho the 4x4 idea of mine would use one, the clutch would be mounted up under the hood, id also make some sort of deflector for it to keep it clean/dry.
Its a good point that it might jolt the trans - its either on or off , no clutching - itd be possible to make an additional hand clutch to slowly engage the belt . | |
| Subject: Maybe it could be rigged October 18th 2012, 1:47 pm | |
| There has to be someone out there that has used them in some creative way. I personally have the two, and they sit in a box probly going on ebay or craigslist soon..
