| dually mud mower | |
greener179 Member
| Subject: dually mud mower August 8th 2012, 10:46 pm | |
| im going to make my mower a dually just because i like the look does duallys do anything else besides looks? | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6366 Posts : 1434 Location : east dublin georgia
| Subject: Re: dually mud mower August 9th 2012, 12:43 am | |
| there used to spread the weight out more in tractors so they dont mess up the grown after planting and used in trucks to evenly distribute the weight for safety and allows more weight to be pulled
greener179 Member
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5217 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: dually mud mower August 9th 2012, 8:37 pm | |
| - greener179 wrote:
- so are they worth running
I would put a pillow block bearing on your axle to support the majority of the weight because the Transaxle casing will really take a beating, I was thinking of doing it, Its only worth it if you have the spare tires to fit on. But the Reason I thought of doing it was because I would have a harder time getting stuck into ruts | |
greener179 Member
| Subject: Re: dually mud mower August 9th 2012, 10:08 pm | |
| how would you mount the pillow block bearing and i all ready got the duals almost done | |
W1ldyOvvnZ Member
| Subject: Re: dually mud mower August 10th 2012, 6:26 pm | |
| - greener179 wrote:
- how would you mount the pillow block bearing and i all ready got the duals almost done
get a bearing that will fit onto the axle then slide it close to the Tires then fab up a frame that will attach to your original frame, do that on both sides. | |
greener179 Member
| Subject: Re: dually mud mower August 10th 2012, 6:31 pm | |
| thats the only problem im have is making a frame to bolt the bearings to i dont have a welder | |
W1ldyOvvnZ Member
| Subject: Re: dually mud mower August 10th 2012, 8:36 pm | |
| - greener179 wrote:
- thats the only problem im have is making a frame to bolt the bearings to i dont have a welder
do you know anyone with a welder willing to let you use it or have them weld it up for them? I would do it of you lived a little closer:P(Shipping over the boarder is the expensive part). you could try buying some 1X2X1/8th wall square tubing then drilling holes and bolting it together that way | |
greener179 Member
| Subject: Re: dually mud mower August 10th 2012, 9:31 pm | |
| that what i was thinking just get some square tubing and bolting it to the frame but right now one side of the dually is not wanting to go on | |
MurrayMudderr Member
Age : 28 Join date : 2012-11-24 Points : 4389 Posts : 38 Location : Iowa
| Subject: Re: dually mud mower November 25th 2012, 5:24 pm | |
| I had an old Huskee race mower that i put duals on and i had no problem with the rear end at all it slowed it down a little but it still ran about 20mph | |
greener179 Member
| Subject: Re: dually mud mower November 25th 2012, 5:38 pm | |
| ya i ran them on that mower for a long time unfortantly that mower caught on fire | |
lt1000 New Member
| Subject: Re: dually mud mower November 28th 2012, 10:20 am | |
| - greener179 wrote:
- ya i ran them on that mower for a long time unfortantly that mower caught on fire
how? | |
greener179 Member
| Subject: Re: dually mud mower November 28th 2012, 12:17 pm | |
| i didnt realize the gas tank had a small hole in it and when i went to start it something sparked and blam got a fire | |
lt1000 New Member
| Subject: Re: dually mud mower December 10th 2012, 8:29 am | |
| is duals better then tandem axle or tandem better the duals traction wise | |
greener179 Member
| Subject: Re: dually mud mower December 10th 2012, 12:23 pm | |
| duals are easyer but im not sure which is better all i know is i never got stuck with duallys | |
lt1000 New Member
| Subject: Re: dually mud mower December 10th 2012, 1:42 pm | |
| well im using turfmasters with chains but duallys cheaper but a tandom looks better so anyone know which is better
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7745 Posts : 3044 Location : Lebanon County, PA
| Subject: Re: dually mud mower December 24th 2012, 8:35 pm | |
| Duallys are good if youre pulling or dont want to rip up turf as, like someone else said, they distribute weight more evenly. They also help with stability because you are widening the wheelbase technically. You will have problems getting stuck in mud because of the weight distribution, but you might have issues getting around stuff in the woods/ creek/ mudhole because of your width. Youll also have more resistance if you go through water.
A tandem axle is good too because youll have more traction on the rear end. It will help with stability a little bit. Youll be thinner to fit around stuff, but the added length could impair your turning radius. Its a lot more fabrication work beacaue you have to link up everything to both axles and extend the frame. You also wont really be able to lock up the axles because of the turning thing like I said earlier, all the tires will want to spin different speeds so turning will again be impaired.
Either way, your steering is screwed. Unless youre going to be pulling, I would say stay with a single axle with a single tire on each side. If you want better traction, get some better tires or even chains. | |
