 Lockable differerential
dylansrockinrigs
dylansrockinrigs
Lockable differerential Empty
PostSubject: Lockable differerential   Lockable differerential Icon_minitimeJuly 20th 2012, 4:33 pm
I have an idea. Build/Modify a standard tranny so that if your stuck you can flip a switch or pull a lever and then it locks the tranny. Anybody got any ideas?
matthew sidor
matthew sidor
PostSubject: Re: Lockable differerential   Lockable differerential Icon_minitimeJuly 20th 2012, 4:50 pm
the only way i can think that would work is if u got an atv transmission and an engine so u could lock up the rear with a push of a button and im sure that not what u meant
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Lockable differerential   Lockable differerential Icon_minitimeJuly 20th 2012, 4:57 pm
i was thinking about having a chain run off of each side of the tranny to two axles each with a tire and in the middle a larger round piece that the other axle fits into and then drill a bunch of holes in it so that you can drive with a differential but if you get stuck you can stick a lawnmower hitch pin with a cotter pin on the end through the axle and presto its locked
PostSubject: Re: Lockable differerential   Lockable differerential Icon_minitimeJuly 20th 2012, 7:03 pm
Older bolens tractors have locking diffs - just like on a 4x4's front axle - twist the knobs and its locked.
Thing is about the locking pin is what if its underwater or burried in mud?
Be easier to make something you wouldnt need to leave the seat for - like air or electric powered lock for the diff- be something to experement with.
CornishMorgan
PostSubject: Re: Lockable differerential   Lockable differerential Icon_minitimeSeptember 3rd 2012, 4:33 pm
A lockable diff would be really useful but complex to make i think.
Swim away or start digging lol!
