 MTD Double Pulley System
5 posters
akcender
akcender
MTD Double Pulley System Empty
PostSubject: MTD Double Pulley System   MTD Double Pulley System Icon_minitimeJune 19th 2012, 8:04 pm
Has anyone had problems with mtd's double pulley system? i have visions of it failing miserably
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: MTD Double Pulley System   MTD Double Pulley System Icon_minitimeAugust 13th 2012, 11:36 pm
the mtd double pulley system is terrible if you get an mtd either replace the tranns, have only forward neutral and revers or just dont get an mtd
PostSubject: Re: MTD Double Pulley System   MTD Double Pulley System Icon_minitimeAugust 18th 2012, 10:51 am
it has its advantages and disadvantages - it gives a variety of speeds , but can easily rust up - when i made a mild mod out of a MTD - i had some belt allignment issues ( turned out to be with the trans pulley).
Sometimes they can be a pain to adjust - sometimes the belts are a pain to get the right length ( due to being a 5/8" wider belt) .
ive never had an MTD in the mud- not sure how itd perform - i know the stock tires are terrible in mud, so those would need to be changed.
Its worth running till you can locate a manual trans.
idlorah
idlorah
PostSubject: mtd   MTD Double Pulley System Icon_minitimeAugust 21st 2012, 9:34 am
i have an mtd with the double pully it works fine for me
moremorelawnmowers
moremorelawnmowers
PostSubject: Re: MTD Double Pulley System   MTD Double Pulley System Icon_minitimeSeptember 30th 2012, 8:23 am
My mtd has the double pulley system. It does 24 mph and pulls whatever i want to pull. It never slips even under water. Just get tighter belts thats what i did on mine. The only problem is that it creeps a little when its in park. I like the double pulley system because i can just put it in 6th and the further i let the clutch ou the faster i go! Very Happy
https://www.youtube.com/user/moremorelawnmowers?feature=mhee
PostSubject: Re: MTD Double Pulley System   MTD Double Pulley System Icon_minitimeOctober 5th 2012, 8:43 pm
More speed can be gained from adjusting the speed control linkage - its possible to adjust the neutral position of the variable pulley ( dont have my MTD manual here) - my 91mastercut was 'tweeked ' by a former owner - wouldnt stop and ran almost too fast to mow safely.
I looked at adjusting the neutral - i readjusted it and it stopped like normal - the speed is still there , havent gotten around to adjusting that part yet.
» Double pulley clutch
» Stock clutch vs double pulley. Opinions, pros/cons
» MTD Variable Speed Pulley system: GOOD OR BAD?
» Double barrel or single ??
» Prancstaman's X1 Scorpion
