 How do you remove a stripped spark plug?
canadianromper
canadianromper
How do you remove a stripped spark plug? Empty
PostSubject: How do you remove a stripped spark plug?   How do you remove a stripped spark plug? Icon_minitimeDecember 27th 2011, 3:53 pm
i was wondering on how can i get my spark plug out when it is stripped
AcreFarm
AcreFarm
PostSubject: Re: How do you remove a stripped spark plug?   How do you remove a stripped spark plug? Icon_minitimeDecember 27th 2011, 4:47 pm
I'd pull the head off and push the plug out while turning. Then you will need to use a helicoil to fix the head, or just replace it.
PostSubject: Re: How do you remove a stripped spark plug?   How do you remove a stripped spark plug? Icon_minitimeDecember 27th 2011, 5:06 pm
Actually, is it a flathead or OHV motor? Flathead is way easier - OHV will be a pain , as youd have to pull the rockers, change the headgasket, ect.
Usually a good rule of thumb for me is to put a tiny dab of never seize on the threads of the plug, to prevent cross threading- its best to hand tighten in, then use the ratchet to finish tightening.
canadianromper
canadianromper
PostSubject: Re: How do you remove a stripped spark plug?   How do you remove a stripped spark plug? Icon_minitimeDecember 27th 2011, 6:35 pm
ok ill try that thanks 4 the help guys
» briggs and stratton v-twin spark plug (confused)
» What is a hotter plug than a champion rj19lm?
» Converting lawnmower engine to run on diesel with a RC glow plug
» How do you remove carbon build up?
» How do I remove a seized flywheel?
