 [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO
torgo
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Empty
PostSubject: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeAugust 16th 2024, 12:07 pm
#Buildoff2024
It’s a little late but I want to throw in my entry for the 2024 Build-Off.
I'm building it for the wife and she is a huge Chiefs Fan so it will be named CHIEF
Here is my Entry Form and a picture of what I started with, an old MURRAY.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240815-184433308
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240711-203811626
It was only a 2speed so I am going to add 1 gear to make it a 3sp.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240711-203822949
Also a centrifugal clutch so it will act like an automatic for her.  Locked MST-203 with Doc Locker 2.0 upgrade to new bearings, all hubs will be 4x4 pattern and paint it Red and Gold Chiefs colors.
Approved -MR 08-17-24
RichieRichOverdrive, JB_4x4 and hadjiikong like this post
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeAugust 17th 2024, 11:32 pm
Welcome to the buildoff! Sorry for the delay I am on travel right now.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Sig115PROJECTS:
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Sig214[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Sig314
torgo
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeAugust 28th 2024, 12:39 pm
Ok, time to update the build.
I started with this
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240720-123029212-HDR
Found this in the engine
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240720-124104544-HDR
Then it became a pile of parts
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240720-123033728-HDR
Welded up the front axle to make it stronger
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240728-134916433-HDR
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240728-134853785-HDR
Then I Doc Locked/live axle and added a gear to the MST202 that came in this mower
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240720-143620004-HDR
Then installed it in the frame that I stripped and painted black.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240810-201014179-HDR
Installed the centrifugal clutch I had on hand
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240728-161922639-HDR
And the trans pulley.  4" on the motor and 3-1/2" on the trans
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240810-201007115-HDR
torgo
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeAugust 28th 2024, 12:51 pm
Test run to see if my belt idler system works and the belt will stay on.
torgo
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeAugust 30th 2024, 7:41 am
I've started in on the painting and getting tires mounted.
Fronts:
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240828-200934464
Rears:
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240828-200952497
Up next will be rear hyd brakes.  Stay tuned.  bounce
torgo
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeSeptember 3rd 2024, 1:24 pm
Almost finished the brakes, a cheap disc for mini bike off of Amazon and a brass gear I had laying around that I bored out the center to 3/4" and turned a little off the outside.  I just need to broach a new keyway for the axle.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240831-182106961
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240831-182113878-HDR
Then I ran into a setback.  The engine that came on the mower smoked so bad that it was spitting oil out the exhaust, so off it came.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240831-192652315-HDR
Luckly I had another Briggs Model 31 out of my LT2000 that it freely donated.  (I have an OPPY to re-install in the Craftsman).
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240901-174857975
torgo
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeSeptember 5th 2024, 9:17 pm
No pictures today, but I did get the keyway broached in the disc brake hub I built, mounted the rotor, rear wheel hubs and started modifying the shifter because I lifted the rear end 2" so now it is not a bolt on.
Going to a swap meet tomorrow. Happy Tractor Hunting!!!! cheers cheers
torgo
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeSeptember 11th 2024, 7:18 am
I didn't find much at the swap meet, only picked up some 1.5" 5 on 4.5" wheel spacers for my Sears.
Continued working on the Chief last night.
I got the master cylinder mounted in location and modified part of the old brake rod/pedal to switch the brake from the right side to the left as I plan on mounting gas pedal on the right.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240910-194700579
I cut and fabbed a new tab for the brake pedal and then cut a new slot in the fender pan for the brake as it did not have one on the right. (the master cylinder is getting another bolt)
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240910-194523012
I got the master cylinder off Amazon and it came with a remote reservoir that I need to mount yet.  You can also see I have been doing some painting.
[24] CHIEF - ATLTF 2024 Build Off Entry by TORGO IMG-20240910-194532361
I try to do something every night after work as the deadline is fast approaching.
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeSeptember 11th 2024, 12:55 pm
Probably will have to bench bleed that master cylinder with it upside down like that. Hopefully it won’t give you much trouble. The one i have on mutt did take a good amount of bleeding after i put it on.
torgo
PostSubject: Re: [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO   [24] CHIEF - ATLTF 2024 Build Off Entry by TORGO Icon_minitimeSeptember 11th 2024, 4:17 pm
I noticed that when I uploaded the pictures that the master cylinder was upside down.
No reason I can't turn it over so I will tonight.
Thx for the catch.
MightyRaze and RichieRichOverdrive like this post
» 2024 ATLTF Build-Off RULES!
» 2018 ATLTF Build off The ATM [2018 Build-Off Entry]
» [DNF][2020 Build-Off Entry] loggers gogert build off entry !!!!
» Torgo First Build/Rebuild Mini Oliver
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Competition Topics-
