 belt lenght 90 or 90 1/2??
2 posters
DiGiacomo
DiGiacomo
belt lenght 90 or 90 1/2?? Empty
PostSubject: belt lenght 90 or 90 1/2??   belt lenght 90 or 90 1/2?? Icon_minitimeApril 14th 2024, 7:12 pm
I need a drive belt for an old toro...... jack"s recommends 5/8 x 901/2...tracter supply has 5/8 x 90........can i go short a half in????......or can someone recommend another seller........Jack is OUT OF STOCK.......and I have not bought from anywhere else.......
thanks for any ideas......
TechnoChicken
TechnoChicken
PostSubject: Re: belt lenght 90 or 90 1/2??   belt lenght 90 or 90 1/2?? Icon_minitimeApril 14th 2024, 9:25 pm
If it's a hydro I would go for it, there is probably some kinda adjustment if it's old enough, other option (And what I usually do) is get a 90 and a 91 and return whichever one doesn't fit.
Hope that helps? if you are in the US "Vbelts4less" has a really good selection and pretty reasonable prices, you might want to check them out?
DiGiacomo
DiGiacomo
PostSubject: Re: belt lenght 90 or 90 1/2??   belt lenght 90 or 90 1/2?? Icon_minitimeApril 14th 2024, 9:52 pm
thanks a lot techno....that's just what i needed to hear........the old belt is so loose now that i can pull it off of any one of the pulleys.....I would imagine a 91 would work......I think tractor supply had the 90"s I'll go check again in the morning......I'll go over to "Vbelts4less" now to check them out
thanks again.......
RichieRichOverdrive and TechnoChicken like this post
» need help with belt
» In need of some belt help?!
» Belt questions?
» Prancstaman's X1 Scorpion
