 Old tiller project
Mrbrucie22
Mrbrucie22
Old tiller project Empty
PostSubject: Old tiller project   Old tiller project Icon_minitimeJanuary 23rd 2023, 12:48 pm
Got this old tiller from a buddy for my garden. Believe it's a 5hp briggs and I'm assuming these carbs are cheap enough to just buy a new one than rrebuilding. but I'm stumped on the pull start. Anyone happen to know what type of recoil starter would work with this? It's the very first thing I want to address because I know I. Going to be pulling that string alot and I dont want to have to fight manually rewinding it every time. Seen it run few years ago so hopefully I can get her going.
Old tiller project 20230116
Old tiller project 20230115
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 23rd 2023, 1:46 pm
Looks like it got pulled off.  It looks to be one of the dog-eared style cups.
Right there on the housing should be a model, type codes.  We can use that to narrow your part.
It looks to be this style, but without the info, it's just a guess.
Amazon.com: Recoil Starter Pull Start Assembly Replacement for Briggs & Stratton Engine 497680 : Patio, Lawn & Garden
Old tiller project Sig115PROJECTS:
Old tiller project Sig214Old tiller project Sig314
Mrbrucie22
Mrbrucie22
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 23rd 2023, 2:23 pm
135292 is the model so that one may work.
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 23rd 2023, 2:34 pm
A ratchet adapter used for breaker bars on a drill also works good for these. Just be careful of kickback.
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 23rd 2023, 3:12 pm
Looks like part#
Briggs & Stratton 497830
Wherever you would like to find that is cheaper. I saw some on Ebay in the $20-$30 range. New on parts sites can range up to $120.
Mrbrucie22
Mrbrucie22
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 25th 2023, 4:33 pm
Pull start came in today and fits and works perfectly. Only cost 17 bucks after tax. Now its to find a couple bolts that fit and possibly throw the carb in the ultrasonic cleaner before i buy a new one. Snow storm coming in so all projects at a hault til the weekend at least. But it gives me time to start selecting seed varieties and get my grow room up to par. Will update wwhewwhen i get it into the shop aand assess the repairs needed!
Old tiller project 20230118
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 25th 2023, 6:26 pm
You look to have enough provisions to clock that pull start a one left or turn it to pull from the tank side. That will help you avoid that hole. I riveted one I had several years back when I clocked mine almost 180 to the other side.
Mrbrucie22
Mrbrucie22
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 25th 2023, 6:33 pm
Yea I been worried about the one hole that seems to have been yanked out. But the other 3 holes are still there and un damaged.
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 25th 2023, 10:49 pm
Those carbs are usually pretty easy to clean. Usually the tanks are dirtier than the carbs. Thing is, the throttle will wallow out the hole in the carb and make them run lean. Also the tanks will warp and leak around the carb. I fought with a 5hp on a go kart for a long time lol.
Looks like a couple of 10-32 bolts would bolt that up fine. I would just take the cowl to TSC and try some botls lol. I sold a pile of those 5hp for nothing last year.
Mrbrucie22
Mrbrucie22
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 27th 2023, 8:24 am
Fortunately the hardware that came with it fits the factory mounts on the engine cover. But the one hole is bent as if someone ripped out the metal insert while trying to start it. So i figured i would just haller it back flat and just put a nut and washer on the backside of the cover for that hole. Hoping to get this thing running this weekend so it's ready to go when we get a warm day to get the gardens tilled. Should have done this in the fall but I'm a bit of a procrastinator lol
Mrbrucie22
Mrbrucie22
PostSubject: Re: Old tiller project   Old tiller project Icon_minitimeJanuary 29th 2023, 6:40 pm
Got it running decent without even cleaning the carb. Drained old gas, put fresh fuel in the tank, installed the recoil and let er rip! Prob just going to get a new carb and will need a new throttle cable but its good enough to get my tilling done for now!
Old tiller project
» first project
» Project UTV
» Project Big Cat
» A NEW project...
» new project soon
