 820 bearrings and seals
LJHunter429
LJHunter429
820 bearrings and seals Empty
PostSubject: 820 bearrings and seals   820 bearrings and seals Icon_minitimeSeptember 8th 2022, 11:04 am
I recently converted my Peerless 820 for oil lubrication instead of grease. However, oil has been leaking out of my axle bearings where I believe that my seals are going bad. Does anyone know where I could find replacement seals or bearings for it that are cheaper than the $40 a piece bearings on sears parts direct? Thanks!
fbisurveilancevan
PostSubject: Re: 820 bearrings and seals   820 bearrings and seals Icon_minitimeSeptember 8th 2022, 12:17 pm
Local bearing supplier or eBay.
Ask a tractor mechanic where they get theirs because those people always know a guy.
Atleast that's how it works in our shop, but then again iam a spoiled little mechanic.
My bearings cost about 20 USD total with shipping from Germany but that might be a pita for you.
PostSubject: Re: 820 bearrings and seals   820 bearrings and seals Icon_minitimeSeptember 8th 2022, 2:19 pm
820 and oil seals?  News to me.   820 bearrings and seals 1098998679
Seriously, 820's don't have them.  Some tips, oil is thinner than the grease.  Don't need as much oil.  As long as the gears can pick it up, it will sling it all over.  If you are going fast, you need a case vent of some sort.  That will help some.  Some people use grease packed washers to help seal it off.  In the end, the axles will leak due to the trans not being designed for Oil.
820 bearrings and seals Sig115PROJECTS:
820 bearrings and seals Sig214820 bearrings and seals Sig314
» Axle seals
» wheel horse seals
» 633a Axle Seals?
» Peerless MST-206 axle seals?
» 633a Family Oil Seals
