My dad was a Ferris dealer. I build my front ends out of Ferris solid front axles. They fit perfectly in AYP craftsman front ends. Just trim the ends down and make spindles for them. Super heavy duty
fbisurveilancevan Member
Age : 38 Join date : 2022-05-20 Points : 1134 Posts : 220
Haven't really been working on it since iam waiting on the belt. However I have been thinking about future plans.
One of them includes this Walbro carb I found lying around in the shop. I will more than likely just rebuild it and put an ec jet in. Some light engine mods are taken into consideration but require some more thought.
Front suspension is also still a touchy subject. I have the parts for the front worked out but not the suspension. If possible ireally want a 4 link system but I don't have any idea on the geometry and what to order. Maybe someone here will be willing to help me out?
Meanwhile things moved up the priority list. I'll be opening the engine today and remove the camshaft and governor.
A customer of ours needs a second hand camshaft and I really want to get rid of the compression release so I call that a win win.
Also I decided to do away with the Walbro and whent for a nibbi that I found for sale on Amazon. These are really good D slide clones
I only went with a 30mm as there was a special discount on those. Looking at the Walbro it's 30mm aswell but really necked down at the Venturi so effectively more like 26. In the end I don't need a huge carb just better throttle response.
MightyRaze, diddie and TechnoChicken like this post
Removed the governor and tapped the hole with a 9/16 fine thread. Put it in with Loctite, rtv and a copper washer so if that'll ever leak I'll be surprised And while we're at it I pulled the head as well to have it decked Found a spare metal pushrod in the trash pile
diddie and Brianator like this post
Age : 37 Join date : 2013-07-02 Points : 4996 Posts : 731 Location : Logan Ohio
Should run really strong ! Nice work on the governer delete
Thanks
Meanwhile I went looking in our old stock and found a nos water pump manifold for kubota So I'll cut it off at the red line and use that as an intake manifold together with a 90 degree hose
The holes on the head almost line up perfectly, just need to file it a little I could also add the pcv hose if I want or block the secondary pipe
Also, starter...
Intake, looking very sharp. I still have to take some paint off and polish it
Inside diameter is 30mm which lines up perfectly with the head and the carb is also 30mm so that is really nice. The original manifold had about a 26mm id.
The Bolt holes I filed out and i had just barely had a smidge left but it worked out fine.
Iam also thinking about perhaps scrounging in the scrap pile if I can maybe find some other rockers from a Kawasaki Kohler or Briggs vanguard that I could make work
MightyRaze, diddie and Rustbucket Garage like this post
Iam an absolute menace with a cutting wheel. I was modifying the pan for the hd starter and nicked the pan.
I could see a tiny pinprick whent trough so for now I put some JB weld on. Next time I'll open it I'll have it fixed or put another pan
Supplier also dropped by so I asked him if he could get me 2 bolts for the hd starter Going to guess that they are 5/16x4 inch but that's simply an educated guess as I have no access to Imperial bolts at work and neither Briggs or JD state a size
MightyRaze and diddie like this post
I have been going back and forth on the front suspension for a while but already decided to use Ferris spindles whatever happens.
Now another challenger entered the ring. I have thought about ripping two of these arms off of a used machine and welding some Dom sleeves and bushings on. That would basically get me 70% without too much effort. The right side would basically move into the location where the front arm is now and the left would basically be somewhere where the engine is mounted.
And plumbed in the pcv, I actually have a really good catch can that came from my car but as I might use the port for a vacuum pump in the future I might as well leave it be for now
So I got lucky again. When I ordered the belt i ordered it with priority shipping but it arrived a week late Amazon however refunded me the full price and shipping.
So I ordered some nice things for 1 dollar
Especially love the form factor on the muffler. It's 2 inch od and 12 inch long Also some exhaust wrap as iam going to stick weld it together and am most likely to cover up some crimes
diddie Member
Age : 57 Join date : 2016-10-02 Points : 3407 Posts : 411 Location : Indiana
Yes, this is a heavy duty starter. They come standard on some John Deere gators. With the compression release removed and the head milled I kind of have to use one or else it'll be a pain to start
Iam not replacing the flywheel as the shipping and import charges would simply be astronomical. If I ever find a used one I might reconsider
The bolts were like a hair too long so I cut a bit off. Also modified the cover already, haven't tested the starter yet but iam just going full send
that's Shure a good reason, the cost of shipping is absolute bonkers, looking forward to that full send for Shure!
It's off day Friday again. Messing around with some pulleys so you guys know what's happening now. Out with the plastic Punching out some sleeves for reuse and measurements.
That's one done, two more to go
JittyJat likes this post
