 820 pulley speed?
LJHunter429
LJHunter429
820 pulley speed? Empty
PostSubject: 820 pulley speed?   820 pulley speed? Icon_minitimeNovember 21st 2021, 8:28 pm
I currently am runninga peerless 820 with a 3.5 in the front and a 4 in the rear.  I want to change the front to a 5.5 or 6 inch, but i didn't know if that is too hard on the transaxle.  Any advice?
PostSubject: Re: 820 pulley speed?   820 pulley speed? Icon_minitimeNovember 21st 2021, 8:49 pm
Belt tension and like you mentioned shaft speed.  One thing many people have done is drill and tap a hole into a good solid part of the case that contains that shaft.  Tap it for a grease zerk and grease it time to time.  That should help.
820 pulley speed? Sig115PROJECTS:
820 pulley speed? Sig214820 pulley speed? Sig314
LJHunter429
LJHunter429
PostSubject: Re: 820 pulley speed?   820 pulley speed? Icon_minitimeNovember 21st 2021, 8:53 pm
Will keep that in mind.  Thanks!
Dr Bob
Dr Bob
PostSubject: Re: 820 pulley speed?   820 pulley speed? Icon_minitimeNovember 23rd 2021, 11:15 pm
Here's where I put the grease zerk in my MST. Be sure it will clear where the bearings are.
820 pulley speed? 20200510
If you want to spin that 820 at high speed, I suggest converting it to oil and add a vent. The grease flings off the gears at high speed, where the oil will drain and re-coat better than the grease. Don't forget an oil seal on the inner side of input shaft to keep the oil in. The vent keeps the transaxle from building pressure when it gets hot.
Nevadablue and JB_4x4 like this post
820 pulley speed?
» Calculate Your Pulley Sizes And Speed!
» MTD Variable Speed Pulley system: GOOD OR BAD?
» tranny ? 5 speed or 6 speed
