| Identify This dynamark | |
dynamarknewbie New Member
| Subject: Identify This dynamark September 10th 2011, 10:56 pm | |
| Alright im a newbie here and need some help. i want to know more about this lawn tractor(picture below). Sorry for the bad quality picture the mower is in a shed that had a tree come through it(tree missed mower by a hair) and im suppose to pick it up after we are able to remove it. Any help will be greatly appreciated so thanks in advance. also really didnt know where to post so im guessing here was the best place. | |
| | | Guest Guest
| Subject: Identify This dynamark September 11th 2011, 2:29 pm | |
| looks like late '70s . 8 hp briggs and a peerless 3 speed tranny. front end can get sloppy and rack gears will strip out. plan on soaking the front end good before you try to force the steering, if it has been sitting for very long light weight and easy to make go fast |
| | | redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6376 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: Identify This dynamark September 11th 2011, 4:31 pm | |
| olllll gimmie gimmie gimmie i have a love hate relationship with dynamarks i want it haha | |
| Subject: Re: Identify This dynamark September 11th 2011, 8:29 pm | |
| Thanks for the replies it appears to be in pretty good condition turns over, steering works, shifts in gear. Only things i noticed wrong were a busted gas cap and the deck has rusted through in one spot(fixable). Next will be trying to get it running. I cleaned it up today so heres a better picture. | |
| | | MSteele323 Member
Age : 50 Join date : 2010-04-09 Points : 5704 Posts : 267 Location : Little Rock Arkansas
| Subject: Re: Identify This dynamark September 12th 2011, 7:56 am | |
| Looks similar to a couple i had - one was black, red and white- had the same white plastic grille - had a 10HP teccy , i knew that one was early because it didnt have posts for a magneto, had a 'brain box' and points.
I also had a blue one similar to yours, cept that had been pretty much stripped tho - had these huge rear tires and trans pulley - thing had a cigarette lighter also .
Im not sure if its one of those rare ' Richard Petty ' blue ones - reguardless, id restore it to original . i dont think that seat is original either - i have an original 82 dynamark , along with the the 10HP teccy one- they both had lowback black seats.
After a certain point, dynamark went to black grilles - so its probably an early one- if it has a briggs motor- check the 1st two digits of the code on the flywheel shroud - thats the year of the motor | |
| Subject: Re: Identify This dynamark September 12th 2011, 3:10 pm | |
| - dangeroustoys56 wrote:
- Looks similar to a couple i had - one was black, red and white- had the same white plastic grille - had a 10HP teccy , i knew that one was early because it didnt have posts for a magneto, had a 'brain box' and points.
After a certain point, dynamark went to black grilles - so its probably an early one- if it has a briggs motor- check the 1st two digits of the code on the flywheel shroud - thats the year of the motor the first 2 digits of the code are 77. as for the seat no its not original it appears to be off a boat but it is pretty comfy haha | |
| Who is online? | In total there are 71 users online :: 0 Registered, 0 Hidden and 71 Guests
