| Dynamark Tractor | |
dagr8tim Member
Age : 48 Join date : 2012-01-01 Points : 4944 Posts : 194 Location : Columbus, Oh
TennesseeCowboy Member
Age : 29 Join date : 2012-08-05 Points : 4629 Posts : 124 Location : TEN-A-SAYY
| Subject: Re: Dynamark Tractor December 17th 2012, 12:04 pm | |
| I have a parts tractor i'm going to pick up that looks kinda like that, it has no engine but i think the transmissions still good. I love old Dynamarks, they're built like tanks lol. | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 17th 2012, 12:20 pm | |
| - TennesseeCowboy wrote:
- I have a parts tractor i'm going to pick up that looks kinda like that, it has no engine but i think the transmissions still good. I love old Dynamarks, they're built like tanks lol.
So the frames would be stronger than say my 2002 Craftsman LT1000 that I use as a offroad tractor? I'm leaning towards fixing the rust on the back and swapping in the drivetrain from the LT1000. I need a front axle and the tie rod from the steering gear. Any chance you'd part with that, if you have a spare? | |
| Subject: Re: Dynamark Tractor December 17th 2012, 11:16 pm | |
| Well it definitley has more metal in it than plastic unlike some newer tractors. And probably not, most of the front end of this one is rusted solid. | |
BlackMountian88 Member
Age : 25 Join date : 2012-09-08 Points : 4896 Posts : 399 Location : NH
| Subject: Re: Dynamark Tractor December 18th 2012, 9:00 am | |
| I have one of them that's very similar. I think it's a bit older. But the rear ends are very good. And fast too, if you look down under there, the rear spindle is even larger than average! | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 9:29 am | |
| - BlackMountian88 wrote:
- I have one of them that's very similar. I think it's a bit older. But the rear ends are very good. And fast too, if you look down under there, the rear spindle is even larger than average!
The axle shafts were cut where they exit the transaxle. I'd need a new set of axle shafts if I wanted to use the rear end. The transaxle shifts really nice. I'd sorta like to rebuild the rear axle, and get a replacement front axle for it and then throw the 17HP OHV Briggs I have in it. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 9:43 am | |
| Ok sure! Ya know, I was looking to sell mine. If you're in my area and you need parts you can but it. | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 11:01 am | |
- Ok sure! Ya know, I was looking to sell mine. If you're in my area and you need parts you can but it.
I'm in Columbus, Ohio. Shipping would be a bit of a pain, but if you've got some spares, I'd like to see what you had. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 1:47 pm | |
| Ya, I was just thinking if you where local.(I'm up and over in NH) I would really like to keep it whole too, like doing a restoration job. The original color is orange, but someone had painted green over it. Seems kinda like what you've got. But the dash is really similar. That's something I haven't seen. Does yours have a lighter on it? | |
| Subject: Re: Dynamark Tractor December 18th 2012, 2:12 pm | |
| Haha so I'm not the only one! and the was light switch is a push/pull knob too. Very unique. | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 2:42 pm | |
| Mine has the push pull switch too. It has no resistance when you pull it, so I figure it's toast. If I repower it, I'll probably replace the switch. Currently the potential donor has the headlight switch as part of the ignition switch.
If I can get some time, I'll have to get afew more pics. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 2:49 pm | |
| Are you putting in a new ignition switch? I believe the stock one is only three positional. One thing that I do waits my mudder because I just don't care is hooked up the lights(actualy only one works) right to the power source. Bypassing the switch. So now they're always on! | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 2:54 pm | |
- Are you putting in a new ignition switch? I believe the stock one is only three positional. One thing that I do waits my mudder because I just don't care is hooked up the lights(actualy only one works) right to the power source. Bypassing the switch. So now they're always on!
I don't know how I'm going to do it. I'm not sure if I'm even going to keep it in one piece. If the hood and grill fits my LT1000, I may just graft them on and call it a day. I'd like to try to use the frame of the dynamark because it seems stronger. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 3:32 pm | |
| Oh yep. If you have the parts and tools to get it going I would keep the dynamark together. They have a good history. And I just plain like 'em! | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 3:42 pm | |
- Oh yep. If you have the parts and tools to get it going I would keep the dynamark together. They have a good history. And I just plain like 'em!
The frame seems alot heavier than my LT1000. That's the big draw. Plus the retro style and the ratrod feel. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 3:51 pm | |
| Ha ha yes! If you want a tough stout little rat-rod thing, try a Sears LT10 from the '80s. I looove the look of mine, because it's rusted out. But this summer it's going to get chopped and channeled! I'm thinking about putting the front down, but I did this on my profile tractor and it gets caught on even the smallest rocks. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 3:52 pm | |
| I agree, if you have the parts I'd stick with the Dynamark. The tractor thats in my profile picture is also a fairly old Dynamark that i've fixed up. I've had no problems with it and i'm pretty sure it has the engine and transmission it came with still on it and i use it all the time. Very reliable. | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 3:53 pm | |
| Nice. I don't know where I'll end up, but I figure I can do something cool on the cheap.
I originally snagged it because I thought it was an old cub cadet or sears suburban. | |
| Fairly old you say, what year is it? Older than '90s? I'm trying to figure out how old mine is. I was thinking 1960 something. | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 3:55 pm | |
- Fairly old you say, what year is it? Older than '90s? I'm trying to figure out how old mine is. I was thinking 1960 something.
I havn't found a date plate, but best guess would be mid 80's and possibly as new as 97. There's not much out there and the original decals have been painted over. I'm hoping I can find a data plate somewhere. The odd thing is that most that I saw online have the fuel cap through the hood, this doesn't. I also need to figure out how to release those goofy wing nut clips to get the hood open. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 3:57 pm | |
| I'm wanting to say maybe '73? I know my papaw bought it new when my mom was younger. I would've kept it stock but the decals were tore apart so I just repainted it lol | |
dagr8tim Member
| Subject: Re: Dynamark Tractor December 18th 2012, 3:58 pm | |
- I'm wanting to say maybe '73? I know my papaw bought it new when my mom was younger. I would've kept it stock but the decals were tore apart so I just repainted it lol
I'm leaning towards industrial satin black and maybe finding a sign painter who wants to do some custom graphics. | |
| Subject: Re: Dynamark Tractor December 18th 2012, 4:02 pm | |
| Cool! I have a plate right between the battery and the gas tank. Try red on black, or neon green on black! | |
