| Need help to identify this gearbox? 3-speed something | |
+2redlinemotorsportts Thunderdivine 6 posters | Author | Message |
Thunderdivine Veteran Member
| | | | redlinemotorsportts Moderator
| | | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5371 Posts : 1135 Location : Southern Florida
| | | | TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
| Subject: Re: Need help to identify this gearbox? 3-speed something November 15th 2013, 6:24 pm | |
| - TheRainbowBoxer wrote:
- We used to run 600 series trannys like those... they worked ok until we started upping the HP to the 16 - 20 range... with a 20 HP, you'll likely break things.
ok thank you, might choose live axle then, ugg idk. | |
Age : 49 Join date : 2012-04-05 Points : 5701 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Need help to identify this gearbox? 3-speed something November 15th 2013, 6:47 pm | |
| They are fairly beefy, but a spinning gear will weld itself to the shaft at higher horsepower and input rpm. With a 4/3 ratio, and 18.5 tires, top speed was around 35mph.
If it was geared to 25 or less, it would last forever. | |
| | | crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4893 Posts : 412 Location : livingston texas
| | | | Sponsored content
| Who is online? | In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests
