| 17hp MTD Build turbo | |
+4CraftsmanQuad19 Murraymountain AllisKidD21 Kyracer13 8 posters |
Murraymountain Veteran Member
| Subject: Re: 17hp MTD Build turbo July 8th 2019, 9:42 pm | |
| I'm not sure, but to be honest, I think you should just leave it. It looks downright mean like that. Put some nice LED's in it and the cover back on and I'd call that good to go! | |
Kyracer13 Member
| Subject: Re: 17hp MTD Build turbo July 8th 2019, 9:46 pm | |
| I'm leaving the middel open I'm just going to cap the headlights off so the function like they should | |
diddie Member
Age : 57 Join date : 2016-10-02 Points : 3430 Posts : 411 Location : Indiana
| Subject: Re: 17hp MTD Build turbo July 8th 2019, 10:05 pm | |
| Nice looking setup with the Turbo cant wait to see how it preforms. | |
Join date : 2019-02-04 Points : 4432 Posts : 2178 Location : North Carolina
| Subject: Re: 17hp MTD Build turbo July 9th 2019, 9:13 am | |
| So your basically going to cut the lens in half, and somehow fuse sides to them to have two separate lens? | |
CosmicArkie New Member
Join date : 2019-02-24 Points : 2124 Posts : 22 Location : Texas
Kyracer13 Member
| Subject: Re: 17hp MTD Build turbo July 9th 2019, 5:10 pm | |
| Well some parts for the rear suspension came in today I'll try to do something with that tonight or tomorrow | |
Kyracer13 Member
Kyracer13 Member
| Subject: Re: 17hp MTD Build turbo July 11th 2019, 12:01 am | |
| Lol, you could've came and picked up a few of those bearings from me. I have an excess of them actually, came from a machine my dad's work was scrapping. What kind of clutch is that? Seems interesting. If you're using a chain off it make sure it has lots of support.
I work on stuff in the evenings too- just too hot and humid around here to work on them during the day. | |
Kyracer13 Member
| Subject: Re: 17hp MTD Build turbo July 11th 2019, 12:11 am | |
| The cluch is made by north American cluch out of Milwaukee, WI a buddy had it for another build but went a different route they clame it's good for 32hp I'm not sure about that but for free we will see how it does | |
Kyracer13 Member
Kyracer13 Member
| Subject: Re: 17hp MTD Build turbo July 14th 2019, 6:23 pm | |
| A little more work to the rear end thses are just temporary tires all I had that was same size | |
Kyracer13 Member
Kyracer13 Member
Kyracer13 Member
| Subject: Re: 17hp MTD Build turbo July 15th 2019, 10:48 am | |
| I'll probably end up with 18 inch tires in the front just because I have a good pair the one mounted is a 20 inch | |
