| 17hp tecumseh carb adjustment/ governor | |
rchammer New Member
Join date : 2013-07-20 Points : 4146 Posts : 2 Location : Colorado
| Subject: 17hp tecumseh carb adjustment/ governor July 20th 2013, 12:02 pm | |
| When I bought my dream machine the engine was cycling every 2-3 sec. hi then lo and wouldn't go into lo idle without dying. I cleaned the carb but lost o-ring that seats at bottom of jet (blew it out while drying carb) I replaced it but not sure if I used the rite size. It doesn't cycle and it has hi and lo idles but it doesn't feel right. Can the governor be bad or be adjusted. Could I remove it? | |
| | | Doc Sprocket Site VIP
| Subject: Re: 17hp tecumseh carb adjustment/ governor July 21st 2013, 9:24 am | |
| The governor certainly can be adjusted, but what do you mean by "it doesn't feel right"?
The governor can be removed, too. It would require you do make a new throttle connection directly to the carb.
| Who is online? | In total there are 31 users online :: 0 Registered, 0 Hidden and 31 Guests
