| | Briggs or Kohler? | |
gimpyrobb Member
![gimpyrobb](https://2img.net/u/2812/37/66/46/avatars/3434-70.jpg)
Join date : 2019-06-02 Points : 1984 Posts : 47 Location : Cincinnati Ohio
![Briggs or Kohler? Empty](https://2img.net/i/empty.gif) | Subject: Briggs or Kohler? June 28th 2019, 6:33 pm | |
| So ive got a single cyl briggs on my Gimp Horse, I got a craftsman vtwin briggs on the GFs tractor, I'm working on a buddy's single cyl Kohler and started wondering which is better? I dont like the fuel tube on the Kohler my buddy has. The guy it came from let water in the tank and now has rust issues. It wasn't horrible pulling the carb off the vtwin, but not as easy as the oppys the Mowrons run.
What are your opinions on the motors? | |
| ![Go down](https://2img.net/i/empty.gif) | | CraftsmanQuad19 Veteran Member
![CraftsmanQuad19](https://2img.net/u/2812/37/66/46/avatars/2588-88.jpg)
![Briggs or Kohler? Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs or Kohler? June 28th 2019, 6:36 pm | |
| I like Briggs because they’re simple, cheap, common, rugged, etc
Kohler is super smooth but a little more touchy in my experience. Parts are more expensive and somewhat less common.
Ether one is fine, just as long as it’s not a courage!!! | |
| ![Go down](https://2img.net/i/empty.gif) | | AllisKidD21 Moderator
![Briggs or Kohler? Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs or Kohler? June 28th 2019, 6:53 pm | |
| CQ's right, basically any engine but a Kohler Courage, haha.
Kohler Command single and V-twins are great engines thar feature pressure lubrication, and the Magnum singles and opposed twins are very good engines as well. Oh and of course the legendary K Series hardly even need a mention! Hahaha.
The Briggs model 25 and 28 flattys are super simple, reliable and common engines, as with the 40, 42, and 46 opposed twins. I don't have a whole lot of experience with the newer Intek series, but I'm not a huge fan of them. The Vangaurds however are great engines.
Pretty much anything will work though. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| ![Go down](https://2img.net/i/empty.gif) | | Murraymountain Veteran Member
![Murraymountain](https://2img.net/u/2812/37/66/46/avatars/3368-77.jpg)
Join date : 2019-02-04 Points : 4357 Posts : 2177 Location : North Carolina
![Briggs or Kohler? Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs or Kohler? June 28th 2019, 8:02 pm | |
| Yep, CQ pretty much gave you everything you need to know. Kohler runs super smooth, but is complicated and expensive. Briggs are simple, tough, cheap parts, and for the most part reliable, but they don't always run good. In my opinion Briggs are better, but I've never worked on a Kohler so I got some learning to do ![lol!](https://2img.net/i/fa/i/smiles/lol.gif) | |
![Briggs or Kohler? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Briggs or Kohler? | |
| Who is online? | In total there are 138 users online :: 1 Registered, 0 Hidden and 137 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
