 Kohler to briggs help
Oldschoolaccord
Kohler to briggs help Empty
PostSubject: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 12th 2023, 7:09 pm
Looking to go from a 5 wire CV15 kohler to a 4 wire 28n707 15hp briggs on a LT1538 husqvarna  (similar to LT1000 craftsman) Does anyone know of a location for wiring diagrams online?
On the tractor I have yellow, black, orange, red, blue
On the motor I have yellow, red and black/red white.Kohler to briggs help 20230414
Kohler to briggs help 20230413
Kohler to briggs help 20230415
Oldschoolaccord
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 12th 2023, 7:11 pm
I also have a parts tractor that had a briggs
3 wire
Kohler to briggs help 20230416
Kohler to briggs help 20230417
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 12th 2023, 11:17 pm
I'll do my best to help, I've put a CV16S where a Briggs Flathead used to live and have a Toro with a 28q series Briggs, I gutted the whole interlock system from that tractor, I've also wired several from scratch.
Unfortunately I can't start digging too much tonight as it's late and I need to go to sleep but I'll look into it more tomorrow after work and see if I can find your tractor manual, we'll need it for the wiring diagram.
Keep in mind all the motor needs to run electrically is 12 volts to the fuel bowl solenoid if equipped (which it probably is) and the starter wire. It should have 1 wire (with inline diode) to charge the battery, 1 wire for the headlights if the tractor had them, 1 kill wire and I think that about covers it!
If this tractor is going to be strictly a toy I highly recommend removing all the wiring loom from the wires so you can trace them all, removing the complete interlock because it will cause you nothing but headaches. With the tractor I gutted the interlock from I had to add a wire from START to the starter solenoid and a 5 pin relay (NC/pin 87a) to keep the kill feature working at the key switch BUT that Toro had some silly kill relay system unlike anything I've ever seen plus a interlock "module".
Really hard to do this stuff without the tractor in front of me and a multimeter in hand but step by step you'll get there!
**Edit** I found the manual pretty quick (and from a trusted source) so I'll be able to review it tomorrow, here's a link to download it.
https://www.manualslib.com/manual/74421/Husqvarna-Lt1538.html
My All Terrain Tractors:
Oldschoolaccord
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 13th 2023, 8:01 am
Basic as possible is great. I can clip the solenoid and forget the safety /interlock
The engine i was told came from a white( mtd?) Older split harness
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 13th 2023, 10:42 am
Maybe this can help a bit?  Jump to 29 minutes in.
Kohler to briggs help Sig115PROJECTS:
Kohler to briggs help Sig214Kohler to briggs help Sig314
Oldschoolaccord
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 13th 2023, 3:34 pm
I have simplified the process since these tips
Negative battery terminal grounded to frame
Positive runs to factory relay with two prongs
Positive continues after relay to starter
Two wires from engine. Red with diod and black for kill.
Kohler to briggs help 20230419
Kohler to briggs help 20230420
Kohler to briggs help 20230422
Oldschoolaccord
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 13th 2023, 7:57 pm
This is what I came up with watching fearless fronts video
Kohler to briggs help 20230423
Kohler to briggs help 20230424
Oldschoolaccord
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 13th 2023, 9:06 pm
I made another edit. I'm gonna have to get a test light to see if the plug on the relay gets power. Then the second plug would be power beyond with the key on which I eliminated
Kohler to briggs help 20230425
Oldschoolaccord
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 14th 2023, 11:42 am
I used part of my husky harness and one wire from my LT1000 parts frame
Kohler to briggs help 20230428
Kohler to briggs help 20230429
Kohler to briggs help 20230430
Oldschoolaccord
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 14th 2023, 11:44 am
Still some work left
Kohler to briggs help 20230432
Kohler to briggs help 20230433
Kohler to briggs help 20230431
PostSubject: Re: Kohler to briggs help   Kohler to briggs help Icon_minitimeApril 14th 2023, 6:48 pm
Looks like you're moving along nicely, good work!
» Briggs or Kohler?
» How to: Hook up a Diesel tachometer to a Briggs Opposed Twin or any Briggs with AC out.
» 15 hp kohler
» kohler magnum 18
» Kohler engine
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Wiring Systems-
