| 1969 Wheel Horse 700 WORKHORSE | |
+16Rustbucket Garage CraftsmanQuad19 murphyslaw SteamNut247 mr.modified Creepycrawler yeethaw Crazy_Carl Kyracer13 Murraymountain RichieRichOverdrive Double W Cross Ranch AllisKidD21 BlakeGroce MightyRaze mrshaft696 20 posters |
BlakeGroce Member
yeethaw Member
Age : 19 Join date : 2019-04-23 Points : 2265 Posts : 182 Location : beecher il
BlakeGroce Member
Age : 21 Join date : 2019-06-02 Points : 2518 Posts : 469 Location : Richmond Ky
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE February 3rd 2020, 1:19 pm | |
| Well I decided to break out Brutus today and go for a ride and I honestly forgot how much fun it was. But I ran out of gas.....again but this time we actually had some so I didnt have to push it back this time. Decided to take some pictures on the mound of grass cause why not? | |
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE February 3rd 2020, 1:24 pm | |
| Looks like fun! She's a good looking ol' Wheelie! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE February 3rd 2020, 2:27 pm | |
| One thing I'm gonna have to do is clean out my air filter. Luckily enough it has a drain hole in the bottom but still have to get the bigger chunks out. Might try to find an air filter that is higher. I dont think I need a snorkel or anything just something that doesnt stick way outside the hood and is fairly waterproof. | |
Age : 37 Join date : 2013-07-02 Points : 5019 Posts : 731 Location : Logan Ohio
BlakeGroce Member
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE February 6th 2020, 9:04 pm | |
| I know this page is for my wheel horse but I wanted to show something sentimental and pretty much this little guy got me into lawnmowers and garden tractors. This is a 80s john deere 312 that was built by my grandpa when I was a kid. Basically it was built as a utility/ride around/buggy thing that he called his hov-around/hov-along (his own homemade mobility scooter) The first time I heard it run I was on it riding around and I loved it cause it was so easy to drive (being a hydrostatic) I use to ride this thing everywhere. I think I killed the first couple engines that were in it. It never had the original engine but I remember it having a briggs in it at some point but I killed that one. But after going through a few motors my papaw got a honda gx200.....I think...idk its 5.5hp and its never quit which is why I love honda gx engines! the 2 seater bench seat is out of a jeep and the dump box is an old lawnmower trailer cut apart and shaped to fit. He was a crafty old man, and man did he build stuff to last too. What he did to put a different engine in there is he extended the driveshaft and welded in a plate so that he could mount the engine higher and mount a pillow block bearing underneath for the driveshaft support, and it just has a belt from the engine to the driveshaft, so its pretty simple. The grill XD is made from an old milk crate and I love it...john deere should have done that from factory! Unfortunately he's not around anymore but this thing is and alot of the stuff he made is so I'll always have memories. He's also the one who bought my john deere 110 from a guy just because I liked it, so he was really cool! Sorry for the long post but just though it was cool and just is another tractor we've got hanging around!
Last edited by BlakeGroce on July 16th 2020, 12:27 am; edited 2 times in total | |
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE February 6th 2020, 9:21 pm | |
| Great story! Glad to see you've held on to your Grandpa's old project. Thanks for sharing! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
BlakeGroce Member
BlakeGroce Member
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 21st 2020, 4:19 pm | |
| I've realized that I never have shown all the modifications that I've done so I've decided to start with the frame and I'll work my way around. I dont have pictures of the process but you get the point. Number one thing on wheel horses (especially the 60s models) is that the frame cracks on the back mounting plate right where the transmission mounts are. I'm not sure why but my guess is the weight of the transmission is alot of stress. But the backing plate was a weak point for these, From 1961 to 1965 these plates were completely flat and they cracked out quite easily so staring in 1966 wheel horse added in some ribs to give the backing plate some strength. Now mine has the ribs but was still cracked so I decided to not only weld up the cracks but also add in a 1/4 inch plate to the bottom bolt holes to give it some more strength and it's pretty easy to do as long as you make sure that everything is still flat. I had my dad weld this in because he's the better welder and I wanted it to be strong so thanks dad!
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 21st 2020, 4:34 pm | |
- Looks pretty stronk. I'm gonna come steal your front tires, hope you don't mind
I kinda need these but they would look good on Budgie! I dont think I paid alot for them they're sunF 18x7x8s on craftsman gt rims. | |
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 21st 2020, 4:51 pm | |
| Yeah, ATV tires around this size have really gone down in price, there's a surplus of them these days. I just don't have the money at the moment lol. | |
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 21st 2020, 5:31 pm | |
| Those bushings should do you well. At least you didn't have to deal with plastic ones like i did on budgie, lol.
The only real problem I've found with good tight bushings on offroad mowers is they'll dry out and almost seize from being dirty. Mutt's clutch is like that from when i drilled out the frame and put bushings in. Make sure to keep yours oiled or greased. | |
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4432 Posts : 2178 Location : North Carolina
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 21st 2020, 7:55 pm | |
| Oh yeah. One thing I'm taking very seriously on Ol' Blue is replacing crappy bushings with better stuff and keeping things greased. That'll always bite ya if you don't watch out. | |
BlakeGroce Member
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 22nd 2020, 5:47 pm | |
| My wheel horse didnt come with an engine which for a 700 is a 7 hp tecumseh. My papaw gave me the honda for free so one of my papaws gave me the tractor and the other gave me the engine so both are the coolest! Putting the honda engine on this thing was a pain and I couldnt have done it without my dads help. Basically we had to move the engine back because the cylinder leans over on hondas opposed to straight up and down on the original tecumseh. So the battery tray had to come out (this engine doesnt have electric start anyways) and we had to make an engine plate because the honda is skinnier than the frame rails so you would only have 2 bolts bolting the engine down. Plus it had to be raised up about an inch because the gas tank mounts on the engine block were hitting the upper dash....or something like that....dont really remember but it had to be done so we made a engine plate out of some 1/8 inch plate and some 1 by 2 C channel. We just used some holes that were already in the frame to mount it. Left side Right side | |
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 22nd 2020, 7:45 pm | |
| Looks like a really well done swap! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
BlakeGroce Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 26th 2020, 10:19 pm | |
| Update on the top speed. Went 9 mph to the floor and 15 mph when I hit the governor. Pretty good I think for having a 3.5 engine pulley and a 4 inch transmission pulley. | |
Crazy_Carl Veteran Member
| Subject: Re: 1969 Wheel Horse 700 WORKHORSE March 27th 2020, 5:18 pm | |
| I really like that engine mounting plate with the fuel pump to a remote tank. Yeah wheel horses are geared so low and slow but make great crawlers. | |
