 1969 Wheel Horse 700 WORKHORSE
Rustbucket Garage
murphyslaw
SteamNut247
yeethaw
Kyracer13
BlakeGroce
20 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
1969 Wheel Horse 700 WORKHORSE - Page 8 Empty
PostSubject: Re: 1969 Wheel Horse 700 WORKHORSE   1969 Wheel Horse 700 WORKHORSE - Page 8 Icon_minitimeMarch 18th 2023, 12:15 am
Ah!  The good ole chocolate milk.
BlakeGroce likes this post
BlakeGroce
BlakeGroce
PostSubject: Re: 1969 Wheel Horse 700 WORKHORSE   1969 Wheel Horse 700 WORKHORSE - Page 8 Icon_minitimeMarch 18th 2023, 10:13 am
So that's where chocolate milk comes from! Wonder if it taste as good as it smells? lol!
Anyways I went ahead and filled the trans up with some good used 15w40 diesel oil I had saved from my trucks last oil change, I normally keep about 5 quarts of it kicking around for stuff like this instead of wasting new oil on it.
1969 Wheel Horse 700 WORKHORSE - Page 8 20230314
Jacked it up on some jack stands, fired it up and ran it through all the gears for about 15 minutes, then drained it back out.
1969 Wheel Horse 700 WORKHORSE - Page 8 20230313
1969 Wheel Horse 700 WORKHORSE - Page 8 20230315
Looks a whole lot better than what it did before.
BlakeGroce
BlakeGroce
PostSubject: Re: 1969 Wheel Horse 700 WORKHORSE   1969 Wheel Horse 700 WORKHORSE - Page 8 Icon_minitimeMarch 18th 2023, 11:38 am
Filled er back up with some regular 90 weight GL1 rated gear oil that's supposed to be yellow metal safe. These 3 speeds take 2 quarts and it's a lot easier to take the shifter out and fill it through the shifter hole.
1969 Wheel Horse 700 WORKHORSE - Page 8 20230317
1969 Wheel Horse 700 WORKHORSE - Page 8 20230318
Here's a good look a what is most likely the culprit to the water getting in, Mr. Shifter Boot (pretty common issue on these wheel horses). There is also a hole in the front these transaxles that gets butted up against the frame but I plugged it off when I installed it.
PostSubject: Re: 1969 Wheel Horse 700 WORKHORSE   1969 Wheel Horse 700 WORKHORSE - Page 8 Icon_minitimeMarch 18th 2023, 9:27 pm
I remember the shifter in the peerless 2300 on budgie was super loose, I’m sure it let a bunch of water in. Wish I had a wheel horse lol
BlakeGroce
BlakeGroce
PostSubject: Re: 1969 Wheel Horse 700 WORKHORSE   1969 Wheel Horse 700 WORKHORSE - Page 8 Icon_minitimeMarch 18th 2023, 9:57 pm
Got tired of these little farts falling apart on me! Dang ol tell u wut man can't have nuttin nice round here! 1969 Wheel Horse 700 WORKHORSE - Page 8 2664539216
1969 Wheel Horse 700 WORKHORSE - Page 8 20230319
These vacuum caps must be made out of that good California rubber cause they fall apart within a few months. Had this happen with the vacuum advance on my truck too and got tired of replacing them so I just did the ole put a hose on it and shove something in the end trick. Style points for finding a black screw with a head the size of the hose! Cool Got a little too fancy and decided to tie it out of the way using one of these little plastic holder inner things.
1969 Wheel Horse 700 WORKHORSE - Page 8 20230321
1969 Wheel Horse 700 WORKHORSE - Page 8 20230320
BlakeGroce
BlakeGroce
PostSubject: Re: 1969 Wheel Horse 700 WORKHORSE   1969 Wheel Horse 700 WORKHORSE - Page 8 Icon_minitimeMarch 18th 2023, 10:38 pm
Also got me a new throttle cable.
1969 Wheel Horse 700 WORKHORSE - Page 8 20230324
1969 Wheel Horse 700 WORKHORSE - Page 8 20230325
Page 8 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8
» 74 Wheel Horse C-100
» Destructive's 1973 Wheel Horse 12 (Wheelin Horse)
» Wheel horse work horse mud rig
» 90s? wheel horse offroader
» My wheel horse- needs a little fix
