| Custom Craftsman Rock-Crawler build | |
+26nathan wilson Moose the craftsman mudder Krawler86 simplicity14twin tractor_guy Thecrazyoldcraftman TheRainbowBoxer truckin42 redlinemotorsportts Doug mudmonkey06 johndeeremad19 Ford Boi Viking1980 welder1991 MSteele323 Thevinnieman92 indianaboy93 motorhead45102 arild365 Mississippi1313 Yamaharules163 Chunk dangeroustoys56 Webmaster 30 posters |
motorhead45102 Member
| Subject: Re: Custom Craftsman Rock-Crawler build Sun Mar 28, 2010 12:51 pm | |
| man that sucks, the only camera i have that records SOUND is my cell phone, the cheap vivitar cameras don't record sound its just a pic cam. which is stupid. so don't get vivitar unless ya don't like sound. | |
| Subject: Re: Custom Craftsman Rock-Crawler build Sun Mar 28, 2010 2:12 pm | |
| Not to get off topic too much- i use an Aiptek HD handheld video camera ( small enough to put in my jeans pocket)- was like $90 at Target - best things about it is it uses a SD disc for extra storage AND i can take still pictures with it as well .
Ive had it around 3 years or so, makes pretty good videos - only issue lately is it seems the mic is too sensitive - loud noises make it crackle n almost screech .
Id definitly buy another one like it . | |
Webmaster Webmaster
Age : 14 Join date : 2010-02-09 Points : 5735 Posts : 332 Location : Here!
| Subject: Re: Custom Craftsman Rock-Crawler build Mon Mar 29, 2010 7:57 am | |
| - motorhead45102 wrote:
- man that sucks, the only camera i have that records SOUND is my cell phone, the cheap vivitar cameras don't record sound its just a pic cam. which is stupid. so don't get vivitar unless ya don't like sound.
Yeah, I had a vivitar video camera, I used it twice and took it back... It did sound (poorly) but the worst part was the vid quality. It claimed it was HD, but it only recorded at 720p @ 20 frames per second. HD is usally 60 fps. It looked like a slide show of pictures when you would play it back. They're junk! - dangeroustoys56 wrote:
- Not to get off topic too much- i use an Aiptek HD handheld video camera ( small enough to put in my jeans pocket)- was like $90 at Target - best things about it is it uses a SD disc for extra storage AND i can take still pictures with it as well .
Id definitly buy another one like it . Is that a digital camera or a camcorder? I might look into that one... I'll look it up on the target website when I get a chance. | |
Yamaharules163 Member
Age : 30 Join date : 2010-02-12 Points : 5471 Posts : 60 Location : Winnipeg Manitoba
| Subject: Re: Custom Craftsman Rock-Crawler build Mon Mar 29, 2010 8:14 am | |
Id definitly buy another one like it . Is that a digital camera or a camcorder? I might look into that one... I'll look it up on the target website when I get a chance. Get a Kodak ZI6. Thats what I use now, its a pocket camcorder. Can take 720p videos and saves to a sdcard. Although its not the best for movie maker editing because it saves in the wrong format, but i downloaded a awesome video converter! | |
Join date : 2010-03-07 Points : 5703 Posts : 244 Location : Ohio
| Subject: Re: Custom Craftsman Rock-Crawler build Mon Mar 29, 2010 6:50 pm | |
| Yeah its digital - i like the dual purpose of it- so i dont have to drag two cameras around . It was a good deal at the time and its still a good camera. | |
Webmaster Webmaster
| Subject: Re: Custom Craftsman Rock-Crawler build Tue Mar 30, 2010 3:31 pm | |
| No, no luck on the camera... Looking a the kodak playsport 5.0. It's waterproof which sounds like a good thinfor me to have. I did however get a new grinder. It's a Hitachi 4". It came with a case and 5 wheels. It was a damn good deal for $40. The wheels alone are around $5 each. NONE of the other grinders came with a case. | |
Webmaster Webmaster
| Subject: Re: Custom Craftsman Rock-Crawler build Tue Mar 30, 2010 4:19 pm | |
| *** UPDATE*** Finally, got some shop time, not alot, but something! Decided not to weld the hubs to the axles. Instead, I welded the hubs to the honda wheels, and I'll use the keyway as a fuse point. So, Hopfully, that would break before I blow the trans. If it did blow it's not a big deal, I have another foote, and a peerless that could got into it's place... Anyway, on with the pics! The wheel, with the hub welded on... The tire size is 155/80/13 The smallest I could find. I got it perfectly centered and straight... If I could take a vid, I would show you! lol! Mounted... (Kinda funny looking, I know!) Put a block of wood under the rear tire to level it out a bit. So that is one side done. It should hold up well, only the test of time will tell So, I didn't feel like doing the other side because it took me so long to get that one centered and welded, I decided to mess around with some other stuff...So In my quest to find a home for a battery, I decided to try to jam it back under the seat.. Gotta raise the seat up a tad to get it to clear though. So I finished the day out by trimming the front hood so it clears the suspention and tires. Hood all done! Did somebody say GROUND CLEARANCE?! lol! | |
arild365 Member
Age : 29 Join date : 2010-02-11 Points : 5813 Posts : 320 Location : Canada, BC
| Subject: Re: Custom Craftsman Rock-Crawler build Tue Mar 30, 2010 5:50 pm | |
| wow soooooo jelous Great job. I think you should find a plastic case like a flower pot to put the battery in to keep it save. they cost alot! | |
Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6220 Posts : 779 Location : Angus, Scotland
| Subject: Re: Custom Craftsman Rock-Crawler build Wed Mar 31, 2010 11:50 am | |
| It's looks good. The rear fenders will help hide the gap between the wheels and the chassis. It should be awesome now! Glad you found a place for a battery, Im still lost about mine! Those wheels look great on there now. Cant wait until more | |
Webmaster Webmaster
| Subject: Re: Custom Craftsman Rock-Crawler build Wed Mar 31, 2010 4:26 pm | |
| - Chunk wrote:
- It's looks good. The rear fenders will help hide the gap between the wheels and the chassis. It should be awesome now!
Glad you found a place for a battery, Im still lost about mine! Those wheels look great on there now. Cant wait until more I was thinking that too, I messed around with the fenders a bit, but not too much. I think the wheels look a little funny, I wish they were a little shorter and a tiny bit wider. If it handles these tires well, then I'll opt for something more aggresive. But if the trans lets go, then I'll have to step it down a tad. | |
| Subject: Re: Custom Craftsman Rock-Crawler build Wed Mar 31, 2010 5:02 pm | |
| Dang- thats pretty cool looking - i bet some large AG wheels would look sharp on there - Id see about some large GT tires - ill look up n see what size mine are.
Its comming along pretty good- lil bit more work n itll be ready to rock n roll. | |
| Subject: Re: Custom Craftsman Rock-Crawler build Wed Mar 31, 2010 8:59 pm | |
| no fair i wanna get mine done so i can ride but its best to take time and not rush. all i need to really do some mods iS MY OWN WELDER THAT I CAN USE ANYTIME AND A GRINDER, AND FLAT STOCK OF VARIETY OF SIZES AND TUBE METAL AS WELL AND I CAN GET SOME STUFF DONE. the only thing closest to a grinder i have is a dremel it would work if i can find a good size disc that wont burn up in 20 sec. but the dremel is nice for those hard to reach places. | |
| Subject: Re: Custom Craftsman Rock-Crawler build Wed Mar 31, 2010 9:00 pm | |
| oh and forgot, your beast is looking great i wish i could come up were you live cause you have AWSOME TRAILS, but i know where some good places are in ohio. | |
Guest Guest
| Subject: Craftsman rock clawler Thu Apr 01, 2010 11:47 pm | |
| Man i was giggling like a little girl when i saw them pics, that thing is the best off road mower i ever seen. Can't wait to see a vid of it going off road. |
Guest Guest
| Subject: Re: Custom Craftsman Rock-Crawler build Sun Apr 04, 2010 8:27 pm | |
Id definitly buy another one like it . Is that a digital camera or a camcorder? I might look into that one... I'll look it up on the target website when I get a chance. Get a Kodak ZI6. Thats what I use now, its a pocket camcorder. Can take 720p videos and saves to a sdcard. Although its not the best for movie maker editing because it saves in the wrong format, but i downloaded a awesome video converter! +1 for the Zi6, It recording to a SD card is really convenient because you can just pop it out and plug it into the computer. Editing is a bit of a pain in the ass tho lol. |
| Subject: Re: Custom Craftsman Rock-Crawler build Mon Apr 05, 2010 7:25 am | |
| Memphis : Thats why i like my vid camera- cause of the SD card - my folks have one with both a CD and SD- its just so much easier to use the SD card. | |
Guest Guest
Webmaster Webmaster
| Subject: Re: Custom Craftsman Rock-Crawler build Sun May 02, 2010 7:57 am | |
| - bigbleuboy wrote:
- any updates fearless? been watching your you tube and im so interested in what's happening now!!!
I should be doing an update today, even if it is a small one. I've been working on the bumpers for now. Theres some other stuff I gotta change around that I'm not looking foward to.. | |
Guest Guest
Webmaster Webmaster
Guest Guest
Webmaster Webmaster
indianaboy93 Member
Age : 31 Join date : 2010-03-14 Points : 5575 Posts : 195
| Subject: Re: Custom Craftsman Rock-Crawler build Sun May 02, 2010 9:28 am | |
I should be doing an update today, even if it is a small one. I've been working on the bumpers for now. Theres some other stuff I gotta change around that I'm not looking foward to.. awesome!! we'll both have bumper updates today. lol | |
