| Looking to start a rock crawler project. | |
Duranate New Member
Age : 51 Join date : 2011-06-06 Points : 4935 Posts : 15 Location : Elk River, Mn
| Subject: Re: Looking to start a rock crawler project. Wed Jun 08, 2011 6:16 am | |
| I have one of those - for a few years it was a plain mower, then when i moved south i turned it into a 'stock mudder' - meaning it took a bath in the swamp everytime i visited the folks - it did pretty darn good for a stock tractor - only complaint was the stock rear tires didnt have a ton of traction . Ive since dragged it down here and did a 'few ' mods- ive went back n forth about wether keeping it stock or making a mud/trail runner - so far im making it the latter. Ive made a thread about it : http://atltf.forumotion.com/t146-agway-offroader-project but heres a pic of it as it sits: I welded some 3/4" bolts onto the ends of the spindles to fit the rear tires on the front - put some steering stops on the back side of the front axle - only real issue is the steering radius is dramatically reduced , has plenty of ground clearance tho and flex - itd probably work better if id bring either the stock axle lower down or swap it for a whole new one. The rear wheels came off a larger tractor with a 3/4" keyed hubs ( stock type trans) - fronts came off another murray . I did swap pulleys - because the stock 3 speed was toooo slow , i just wanted a bit more speed then it originally had, not racing fast tho. Front i think is a 4-5" and rear is a 6" (original was a 8-10") . Im planning on using a 11HP briggs, eventually id like to make a rack for the back , maybe a brush guard for the front - and places to mount my winch. For hard core offroad, youd want a sub chassis under the stock pan chassis - specially if youre gonna lift it at all . I did notice in the pic of the transmission- one of the transmission brackets ( ubolt) is broken/loose. I had the same issue with mine- i just used an old muffler clamp. For traction alot of people use ATV tires - id say those stock front tires would need to go ( i had those on mine- thing wouldnt turn hardly at all in the mud- replaced em with some turf tires) . looking forward to updates. | |
| | | Duranate New Member
| Subject: Re: Looking to start a rock crawler project. Wed Jun 08, 2011 3:52 pm | |
| Thanks for the reply. Yea, your tractor looks sweet, it gives me a great referance. well, i had a reality check today as i worked on my tractor. The thing is a piece of junk The carb is messed up, the governor has an internal problem, the belt has a deep gouge 3/4 threw, the thing wont crank sometimes-possible solenoid, leaks tons of oil, the positive on the battery is actually the negative, two tires are flat, etc etc etc. it was very frustrating. I couldn't find my tools or even walk around in the garage because there is junk everyplace. I needed to just walk away ( and i'm just starting this project, not good ) LOL I tried to put together a short video as well. youtube videoNext on the priority list is I'm going to need to figure out how to have a fool-proff throttle, get the brakes working, and also figure out why it wont let the belt go when the clutch is depressed. | |
| | | Duranate New Member
| Subject: Re: Looking to start a rock crawler project. Wed Jun 08, 2011 4:09 pm | |
| I don't know how I forgot but i just remembered i do have another engine in the shed someplace. It's a 12hp briggs. I think the carb is plugged but it's probably better than the one that's in the tractor now. I might try to swap engines as the gas leaking, oil leaking, govenor issues are a real bear. I wish i had another parts machine, right now, i'm trying to save all the parts from the deck for later "fabricating". | |
| Subject: Re: Looking to start a rock crawler project. Thu Jun 09, 2011 6:56 am | |
| The engine on mine was actually a replacement - originally had a 10HP teccy - my friend ( who i got it off) put a 10HP briggs on it - it was an ok motor, just never seemed to run right to me - i had bolted a 14.5HP OHV on it, but it barely fit under the hood ( a long motor) , plus had to take the motor plate out it originally had . Im thinking the smaller 11HP should do good enough. Ive made up a couple throttle setups - for a steering wheel type i used a ATV brake lever ( didnt like that) - that kind only needs a single spring on the carb - a foot pedal needs two usually - one to snap the pedal back and one on the carb - Arlid has a video on YT about setting one up - on my mod MTD i used parts i had laying around : I used a regular 10 speed bike derailer cable , springs i had around, made up some cable holders till i could get some small u clamps, pedal is a clutch pedal off my parts 69 wheelhorse - the air cleaner was a vacuum cleaner filter on clearance and a 4" PVC endcap- the filter was too restrictive tho- had to ditch it. | |
| Who is online? | In total there are 45 users online :: 1 Registered, 0 Hidden and 44 Guests torgoMost users ever online was 412 on Sat Jan 07, 2023 6:59 am |
