 Craftsman GT3000 "MUTT" Part II
Hammernco
BairleaFarm
PizzaKitty26
Adventurewagen
Rustbucket Garage
Budget_gokart
Dr Bob
mh434
BlakeGroce
Hillbilly Offroading
mowerjunkie03
29 posters
Go to page : Previous  1 ... 10 ... 17, 18, 19, 20, 21, 22  Next
Craftsman GT3000 "MUTT" Part II - Page 18 Empty
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 3rd 2023, 1:09 pm
Oh don’t worry, I’ll find a way. I’ll take her out this afternoon and see how she handles but I’ll probably pull the wheels off and put them on the GT6k. I can already tell the mudlites are too old and stiff for my liking.
I found some carb mounting boots that use the same mounting spacing. Planning on switching to these so I can switch between the 34 and 28mm carbs easily. The maxxis sticker is for her too Smile
Craftsman GT3000 "MUTT" Part II - Page 18 83ac1510
Something else, I’ve been brainstorming on an auxiliary accelerator pump, with an injector over each intake port. We’ll see about that. Still very much in planning stages.
PostSubject: post title??? shadow wizard money gang    Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 8th 2023, 10:34 am
I got one of my carb boots in and immediately decided that I didn’t like how that kind of mounting was going to turn out. Just too big and bulky
What could this fool be up to now…
Craftsman GT3000 "MUTT" Part II - Page 18 77b0ec10
There wasn’t much of a groove for the set screws in my mount to catch so I made a nice bigger one.
Craftsman GT3000 "MUTT" Part II - Page 18 13dc3e10
I don’t think I spun the carb fast enough to hurt it, only 200rpm or so.
Adventurewagen
Adventurewagen
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 8th 2023, 4:00 pm
Running that same carb on a moped polini kit, sure it's gonna be enough carb?
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 8th 2023, 4:25 pm
In hindsight, going from the 34 to the 28 seems a bit extreme, but if it aids responsiveness and doesn’t hurt the high end too much it’ll be fine with me. It’s still more carb than stock and I can always swap back to the 34mm and save this one for another project.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 17th 2023, 2:39 pm
Here’s the cracked brake caliper mount.
Craftsman GT3000 "MUTT" Part II - Page 18 1c364710
Cut down a piece of 2x1/4” angle for a new mount.
Craftsman GT3000 "MUTT" Part II - Page 18 Bf957710
Measure hole spacing from the sides of the holes, it is much easier than eyeballing center.
Craftsman GT3000 "MUTT" Part II - Page 18 Cb09e110
Scribe the center of the first hole with calipers. I just use the readout on the mill to get to the second hole position, as I know the hole spacing from earlier.
Craftsman GT3000 "MUTT" Part II - Page 18 96807910
Using a pointer to find the intersection of the scribed lines.
Craftsman GT3000 "MUTT" Part II - Page 18 187e1010
All better, should be plenty rugged!
Craftsman GT3000 "MUTT" Part II - Page 18 8e8fc410
BUT WAIT!
Upon reassembly I realized there was something missing…I looked high and low in the shop and couldn’t find it…a whole brake pad was missing! Upon inspecting the pad I had left, I saw it was wore down to almost nothing. I think the cheap pads I had wore out quick and one of them fell out. I did have a few empty pushes of the brakes at LCQ, that must have been when they fell out. Luckily the brake pistons had little plastic pushers in them and didn’t score the rotor. I just reinstalled my old brake pads for now.
Craftsman GT3000 "MUTT" Part II - Page 18 33e93a10
Just for fun, here’s some measurements I came up with for mutt. I don’t fully believe that weight, it’s way off what I came up with last time.
Craftsman GT3000 "MUTT" Part II - Page 18 A6a97d10
And here’s some size comparisons on tires. Left is the 26x11-12 Bighorn 2.0s, center is 27x12-10 mud bugs, and right is my 26x10-12 executioners. The executioners really get kinda small when you run with no air in them.
Craftsman GT3000 "MUTT" Part II - Page 18 D7138d10
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 17th 2023, 2:58 pm
Interesting Stats! I need to get some for mine.
Craftsman GT3000 "MUTT" Part II - Page 18 Sig115PROJECTS:
Craftsman GT3000 "MUTT" Part II - Page 18 Sig214Craftsman GT3000 "MUTT" Part II - Page 18 Sig314
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 17th 2023, 6:11 pm
Wheelbase and weight distribution are the two most interesting stats to compare between tractors, in my opinion. Mutt is a short wheelbase tractor compared to a Sears or wheel horse, losing stability on hills, but has more weight distributed up front compared to most other tractors. Its a combination that has definitely worked out in my favor.
Adventurewagen
Adventurewagen
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 17th 2023, 7:51 pm
A machinist trick to hole spacing, measure outside of both holes then if holes are same size deduct the width of one hole and you'll be dead nutz center on both holes.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeAugust 18th 2023, 8:56 am
That way works good. I’ll also measure the shortest distance between the insides of the holes and the longest distance between the outsides and just average them. That’s if I don’t feel like measuring the size of the holes. Holes still have to be the same size though.
Mounted up these 25x11-10 mudlites. These rims are a bit narrow for them. Need beadlocks to add some extra width to the rims Razz
Craftsman GT3000 "MUTT" Part II - Page 18 C617d810
Went out and found some rocks to try these babies out.
Craftsman GT3000 "MUTT" Part II - Page 18 62176310
I have the mudlites at 3psi and they’re still just about to fall off the rim. Isn’t really any good safety bead on these rims. It is super impressive how the tires run at 3psi though. Seems the 10” rims make a nice difference. They don’t really beat my bighorns though.
Craftsman GT3000 "MUTT" Part II - Page 18 8c6e6610
Sadly it seems I’ve given my old exhaust one too many snap crackle pops. She let go on the drive home  Craftsman GT3000 "MUTT" Part II - Page 18 1098998679 Guess I’ll have to go find some welding gas
Craftsman GT3000 "MUTT" Part II - Page 18 45c57c10
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeSeptember 29th 2023, 9:16 pm
Welp, I screwed up.
The first thing I did was piss off a nest of yellow jackets in a tree stump. So naturally I was riding in the opposite direction. At quite a clip. Dropped the front end into a rut, she stopped hard for just a second but popped out and kept going. I didn’t think much of it but I thought the tractor felt real weird. Little later on I got to looking and saw this….the frame is bucked up in the center.
Craftsman GT3000 "MUTT" Part II - Page 18 A4dbd610
Check where the frame buckled from being shoved together. Looks just the same on both sides. Buckled right under the clutch pedal shaft.
Craftsman GT3000 "MUTT" Part II - Page 18 30ad1310
She’s still functional as is…but there’s some serious rehabilitation to be done
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeSeptember 30th 2023, 12:27 am
Holy Toledo! That's a pretty serious bend. Especially for that style frame. I've always thought the weakest part was where the side frames reduce down to the engine plate. You going to straighten and run some angle down the frame to stiffen?
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeSeptember 30th 2023, 12:36 am
That’s about the plan. Set it up on the big trailer and see if I can draw the frame back down with a chain hoist or something. I don’t think I can fit angle iron in there but some 1/4x2 flatstock should be doable.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 1st 2023, 8:38 pm
Looks great! More ground clearance so you're less likely to get high centered! Lol
My All Terrain Tractors:
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 9th 2023, 1:01 am
Pulled the running boards off so I could run a chain through the frame and use some screw binders to pull the frame back down. Worked pretty good. I had jack stands under the front axle, the binders had them pulled down about to the rims haha.
Craftsman GT3000 "MUTT" Part II - Page 18 F6678910
Somehow I got distracted screwing with the carb instead of bracing the frame. It just wasn’t acting right. I guess this might have something to do with it.
Craftsman GT3000 "MUTT" Part II - Page 18 F57f4c10
The needle has disassembled itself! Damn Chinese junk.
Craftsman GT3000 "MUTT" Part II - Page 18 76776b10
I fooled with that carb for a bit more after I crimped the needle back together. I just got fed up and decided to try something else.
What ever could I be 3D printing now?
Craftsman GT3000 "MUTT" Part II - Page 18 0f36d510
Oh look, what a nice little 28mm carb! With a 3D printed snorkel adapter!
Craftsman GT3000 "MUTT" Part II - Page 18 E79e9c10
Here I already have the two mounting holes tapped and am using my CNC mill to cut the bore for the carb to fit into.  Briggs oppy carb bolt spacing is 2-1/16” with two 1/4” bolts for whoever is interested.
Craftsman GT3000 "MUTT" Part II - Page 18 6d4e5a10
Same deal as my last adapter, just perhaps a little more refined. I took care to fit everything nicer this time. The set screws have a BB at the end of them, and are spaced to catch the groove in the stem of the carb and push the face of the carb against an O ring. Seems to seal fine.
Craftsman GT3000 "MUTT" Part II - Page 18 06db9610
Here it is mounted on the oppy without the snorkel tube.
Craftsman GT3000 "MUTT" Part II - Page 18 Cb469d10
She seems to run good! Seems more responsive. I will have to do more tuning when it’s not 11pm haha. Will upload a video soon.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 9th 2023, 1:09 am
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 10th 2023, 6:28 pm
Ok… @MightyRaze I think we need to give @RichieRichOverdrive the title of “Zip Ties N Bias Plies of Garden tractors. 🤣
I kid, that new carb looks good on there.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 11th 2023, 10:36 am
Hahaha, an honor to be compared to ol Peg cheers
Got my frame bolsters made up last night. They will run all the way from the front mounts of the transaxle to just behind the front axle mount, welded to the outside of the frame. This will move my running boards out 1/4” on either side. Not a big deal really. You can see in the centers of them where I had to notch where the clutch shaft is and dash bolts on.
Craftsman GT3000 "MUTT" Part II - Page 18 2b2a0e10
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 12th 2023, 10:26 am
She’s nakey!
Craftsman GT3000 "MUTT" Part II - Page 18 7e649610
The side plates that kind of make up the dash column didn’t leave much room for a weld without cutting out a bunch of material out of the bolsters, so I notched them around the bolts.
Craftsman GT3000 "MUTT" Part II - Page 18 F5578910
All welded up. Threw some black paint on after I took the pic
Craftsman GT3000 "MUTT" Part II - Page 18 1178c110
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 12th 2023, 11:02 pm
Nice fix and upgrade!
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 12th 2023, 11:33 pm
I added these extra brackets to the rear fender mount. Adds two extra mounting points for the fender instead of just having flimsy one in the middle.
Craftsman GT3000 "MUTT" Part II - Page 18 F5315510
Four bolts was probably overkill, but oh well lol
Craftsman GT3000 "MUTT" Part II - Page 18 11343810
With a little fooling with the running boards to accommodate for the extra frame width, most everything is back together.
Craftsman GT3000 "MUTT" Part II - Page 18 Aa61b910
MightyRaze, Brianator and Adventurewagen like this post
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 16th 2023, 8:39 am
Dude!  You OK?  I saw the carnage to MUTT from this past weekend.  You left quite the impression on the ground it looked.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 16th 2023, 10:51 am
It was a crazy weekend out with Giverthebeans!
Craftsman GT3000 "MUTT" Part II - Page 18 D162ab10
Hit some nice ones on powerline hill, should make some good video
Craftsman GT3000 "MUTT" Part II - Page 18 56aa5e10
I did get a little splattered on studabaker hill though. I caught the left side of a rut and it cocked my steering over, I rolled back and she went over.
Craftsman GT3000 "MUTT" Part II - Page 18 350e7410
Josh theiry said she went like 12ft before the hood hit the ground. It was a half backward half sideways roll. The hood and grille left a nice paint mark in the ground.
Craftsman GT3000 "MUTT" Part II - Page 18 B233ae10
She somehow rolled back into the wheels and idled down the hill. The steering was already hurt before the roll, so the only thing that was really hurt was the hood. Did knock my air filter off, but that went right back on. I had to unbolt the hood to open it too haha. I’ve got a few fresh hoods and grilles around, looks like an engine cage needs to be moved up the list.
My clutch hasn’t worked right all weekend with the new belt, i think I might have a dud belt. The carb doesn’t idle right, and I think I dropped a pad and blew out the brake piston coming out of spaas creek. Oh, and something in the belt system locked up right as I got her back on the truck. Go figure! Looks like I’ve got some work ahead of me
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 17th 2023, 4:19 pm
MightyRaze, Brianator and PizzaKitty26 like this post
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 19th 2023, 10:09 am
It looks like it would be a hoot riding with you guys! Keep them videos coming!
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 23rd 2023, 11:00 am
Some carnage. Missing part of a tooth here.
Craftsman GT3000 "MUTT" Part II - Page 18 397d9610
Steering shaft bent too
Craftsman GT3000 "MUTT" Part II - Page 18 578c0d10
Took the winch off so I can get an engine cage built before I cut the hood.
Craftsman GT3000 "MUTT" Part II - Page 18 22ad2910
Side plate off the dash…ignore the birds nest…working on getting rack and pinion steering in there. Trying to decide where to mount the dang thing. Gonna need to put the steering shaft in bearings too.
Craftsman GT3000 "MUTT" Part II - Page 18 7484cc10
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 18 Icon_minitimeOctober 23rd 2023, 11:53 am
Nice carnage. Just shows you were riding hard and having fun. Rack and Pinion will be nice. I don't think I can turn as sharp with mine. I have my geometry as close to the spindle as I can too. You going to use it as a push pull to the bell crank or across the axle?
Page 18 of 22Go to page : Previous  1 ... 10 ... 17, 18, 19, 20, 21, 22  Next
» Craftsman GT3000 "MUTT" Part I
» mtd craftsman mutt
» Craftsman GT6K
» 1990's Craftsman GT3000 utility mower.
» My first build 2003 craftsman gt3000 23hp v-twin
