 Craftsman GT3000 "MUTT" Part II
Hammernco
BairleaFarm
PizzaKitty26
Adventurewagen
Rustbucket Garage
Budget_gokart
Dr Bob
mh434
BlakeGroce
Hillbilly Offroading
mowerjunkie03
29 posters
Go to page : Previous  1 ... 7 ... 11, 12, 13 ... 17 ... 22  Next
Craftsman GT3000 "MUTT" Part II - Page 12 Empty
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 15th 2023, 11:17 pm
Think I might have to admit defeat on this one. I’ve probably doubled the leverage on this caliper and still barely have workable brakes.
Craftsman GT3000 "MUTT" Part II - Page 12 4e11aa10
I didn’t want to go to hydraulic brakes but it’s sort of looking like that might be the way to go. I might still see if there’s anything I can get out of this caliper tomorrow.
I hear ya man.  I had to admit defeat on my drum I had on Red at one time.  Mostly, due to oil getting on the drum at the time which I figured out.  Never went back to it.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 16th 2023, 9:26 am
That is another thought. This brake disc is right on the end of a leaking axle seal lol. Or, lack of axle seal, however you will. I will definitely reuse this disc with a hydraulic brake if I can though.
Mutt needs a new oppy. This one just burns too much oil. I have another pressure lube here but I might just stick with a regular splash lube so I’m not worried about killing a nice engine.
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 16th 2023, 11:29 am
I dunno where you get all these parts-820s-pressure lube oppys-but hey man, share the genie eh? Lol
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 16th 2023, 11:40 am
Yeah, I've seen 1 pressure lube oppy in the faceplace in the past 4 years.  They wanted $500 for it.  Yeah... NO.  I do see 820's here time to time.
As for the leaky 820.  I run a couple washers at the end of the trans shaft.  That and running just enough oil to lube everything and not much more.
Craftsman GT3000 "MUTT" Part II - Page 12 Sig115PROJECTS:
Craftsman GT3000 "MUTT" Part II - Page 12 Sig214Craftsman GT3000 "MUTT" Part II - Page 12 Sig314
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 16th 2023, 2:50 pm
I think I’ve had like four 820s and three pressure lube oppys, one of which being a horizontal. Not to brag or anything lol! I shouldn’t even mention the sub $2000 CNC mill…
Looking at hydraulic brakes on eBay, seeing some pretty cheap pull offs.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 16th 2023, 3:24 pm
Creepycrawler recommended this setup to me, I think it’ll do pretty good. I think it wound up being cheaper than the dang go kart caliper!
Craftsman GT3000 "MUTT" Part II - Page 12 2bcc9a10
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 18th 2023, 9:12 pm
Love all the updates to this thing, really hope I get to see it out on the trail some day
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 19th 2023, 9:21 am
Plan this year is to head to Haspin with her, at least
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 20th 2023, 1:07 am
Went and did some trading with a fellow forum member for these 5 lug rims. Gotta get a tire on one and see about where I need to put the flanges on the new hubs. These wheels are a bit wider so I’m not 100% sure I’ll keep them but they’ll be just fine for the moment.
Craftsman GT3000 "MUTT" Part II - Page 12 7998b710
New brake setup should be here in the next day or two. That should be fun.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 21st 2023, 7:22 pm
Shift keys and brake caliper all got here today. I figured out all my measurements for the 5 lug hubs today so I'm working on them.
I decided to use the rims from the GT6K for Mutt and put the wider rims back on the GT6K. I mounted one of the Executioners on the wider rim and didn't like how it flattened out the top of the tire, I prefer the crown shape a narrower rim gives.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 21st 2023, 11:50 pm
Here’s that brake setup. I think it should work pretty well.
Craftsman GT3000 "MUTT" Part II - Page 12 19150110
Started on hubs. Hogging material out of the hole with a 15/16 drill bit after facing and turning the part.
Craftsman GT3000 "MUTT" Part II - Page 12 6f6d2810
Before and after for the first op.. I left .025” in the bore of the hub. I’ll bore it to finished size after welding the flange on, as the weld is likely to distort the bore.
Craftsman GT3000 "MUTT" Part II - Page 12 2f2ae410
Update I did a few days ago
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 24th 2023, 10:20 am
Hogged out the step in the hubs on the CNC mill, as well as milled the center hole.
Craftsman GT3000 "MUTT" Part II - Page 12 C7d21a10
Craftsman GT3000 "MUTT" Part II - Page 12 7887a410
I’m thinking I will weld the flanges to the hubs then set them in the 3 jaw chuck on the mill and cut down the OD. The mill will cut it round enough, I don’t think I’ll go back and true that on the lathe. Then the chuck will also be on the mill for when I drill the holes for the studs. I got some 7/16 fine thread press in studs and lug nuts from NAPA yesterday.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 25th 2023, 9:58 pm
While waiting for a program to run on the Prototrak I went and zapped these together with the old tombstone. When I was done with that job I took the vises off the Trak, slapped an extra 3 jaw on, and milled off the OD of the hubs. This way is faster than nibbling the corners off on the lathe.
Craftsman GT3000 "MUTT" Part II - Page 12 7a939910
Before/After finishing the face, step, and bore on the lathe. The plates didn’t actually warp too bad, maybe .02” runout at the outer edge of the face.
Craftsman GT3000 "MUTT" Part II - Page 12 59eea610
Back at the mill, I picked up the center of the hub with an indicator and walked off the bolt circle with a 1/2” drill bit, then took them up to size with a 3/8” end mill, using one pocket event rotated 4 times at 72 degrees per step. The press in studs I bought needed a wonky hole size, something I didn’t have a drill bit for, so I had to do it like this.
Craftsman GT3000 "MUTT" Part II - Page 12 F9946010
All I have left now is to use the shaper to cut the keyway, and drill and tap for a bunch for a bunch of set screws, and press the studs in. I already pressed in two though to check if the holes were big enough.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 25th 2023, 10:23 pm
You've built skill and have access to machinery that is so awesome!  Those are looking great!
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 26th 2023, 5:41 pm
Thanks, machining seemed like a natural step for me, I don’t know anyone else my age that does it as well as me.
Whittling out the keyways now. I would take these hubs to work and just use a push broach, but they’re too long and would likely break the broach.
I made this boring bar a while back for cutting some ACME threads for a vise nut. It wound up being about the right size for this job. I hand ground the little tool bit. It’s a little under 1/4” so once I’m too depth I just walk it side to side a bit to get the width right. I’m always looking for an excuse to hand grind little tool bits like this, can never get enough practice.
Craftsman GT3000 "MUTT" Part II - Page 12 0b5dfe10
Broaching keyways in the shaper always makes for goofy setups. Vise on a mill table in a vise on the shaper table.
Craftsman GT3000 "MUTT" Part II - Page 12 A9583910
Finished product. The bolt holes make the keyway look more crooked than it actually is lol.
Craftsman GT3000 "MUTT" Part II - Page 12 528b9210
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 26th 2023, 10:06 pm
After cutting both keyways I pressed in the studs and drilled and tapped four holes in each of them for set screws. Two over the keyway and two 90* from the other two. Think that might hold everything on. If not I’ll just drill and tap the ends of the axles for a bolt and washer.
Craftsman GT3000 "MUTT" Part II - Page 12 D1b4df10
A nice sloppy coat of cheap pant with no prep and no primer, just like old times.
Craftsman GT3000 "MUTT" Part II - Page 12 F4b77810
Gotta clean and paint the rims and mount the executioners on them. Brakes are also next in line. Should have gaskets for an oppy coming soon as well.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 27th 2023, 11:11 am
Killer work as usual man!
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeFebruary 28th 2023, 12:11 am
Looking at about 44” across the rear tires. She’s wide. Will probably move them back in an inch or so
Craftsman GT3000 "MUTT" Part II - Page 12 9436e810
It’s a new look for sure.
Craftsman GT3000 "MUTT" Part II - Page 12 8e37a810
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 2nd 2023, 2:11 pm
I ran a compression check on this oppy just for fun. Spinning forwards, 60psi. Spinning backwards, 90-100. Must be the oil retention ring is wore out, because the compression rings seem fine. Unless the oil is coming through the intake valves or something, which I don’t think is very likely.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 2nd 2023, 3:27 pm
Interesting. Never thought to spin the engine backwards. Hmm...
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 2nd 2023, 4:33 pm
These engines have the easy start camshaft grind, intake valve stays open well into the compression stroke. Spinning it backwards uses the exhaust valve as the intake, negating the compression release.
Just bought stuff to lap the valves on the next oppy. May as well go all in. I may do some mods concerning lubrication and porting as well.
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 2nd 2023, 5:18 pm
I've always noticed that with these engines. I figured it would catch on the second round. Good to know.
BlakeGroce
BlakeGroce
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 3rd 2023, 6:38 pm
Nice work! Makes me want to get my junk goin again lol!
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 10th 2023, 8:16 am
While I keep getting sent more work to run across my machines, I have been putting a bit of money into this oppy build.
-28mm mikuni clone (34mm is too much)
-.042” copper head gaskets
-Valve lapping stuff
-Autolite 458 spark plugs
-Oil cooler
-Piston rings
Planning on pretty much doing a captain315 type of build. ( @Wheelinhorse )
And I still have brakes and a transaxle to put together!
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 12th 2023, 11:07 pm
Glad to hear it, you might look at doing a mild port job, these castings are so terrible you can gain a ton with very little effort, even just knocking the casting defects out makes a noticeable difference. Plus I think it’s kinda fun
PostSubject: Re: Craftsman GT3000 "MUTT" Part II   Craftsman GT3000 "MUTT" Part II - Page 12 Icon_minitimeMarch 13th 2023, 9:47 am
Port job is definitely on the list, I’ve got a little die grinder bit on the way for it. If I’m lucky I might get some work done on her this weekend. I think the trans and brakes are definitely first in line though.
Page 12 of 22Go to page : Previous  1 ... 7 ... 11, 12, 13 ... 17 ... 22  Next
» Craftsman GT3000 "MUTT" Part I
» mtd craftsman mutt
» Craftsman GT6K
» 1990's Craftsman GT3000 utility mower.
» My first build 2003 craftsman gt3000 23hp v-twin
