 [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]
tater195
diddie
muddstir
Hillbilly Homer
Hillbilly Offroading
21 posters
Go to page : Previous  1 ... 7 ... 11, 12, 13, 14, 15  Next
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Empty
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 16th 2019, 11:20 pm
That trans is going to be rock solid!  Great job fixing it!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 17th 2019, 8:29 pm
Haha, it better be or he's in trouble.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Eat_my10
Hahaha, I'm just kidding. Nice job Allis!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 17th 2019, 11:10 pm
Haha, thanks.
Well anyhow the rat rod went up on the stands today:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190870
I had to swap axle sleeves because the axle sleeve bearings in the replacement trans were bad. That's when I noticed a bolt was actually broke off flush in there. Bugger...
Luckily I was able to get a nut welded to it and she backed out easy!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190871
The replacement transaxle bolted up the same, so that went pretty smooth. I filled the the oil through the shifter hole and before I bolted the shifter up, I added a fitting for a breather:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190872
Figured it would be a good idea for the higher speeds and oil level.
Then of course, the test drive.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190873
Which went very well! I burned 'er through all the gears and everything seems just as it should be. I never fully maxed it out, (still no brakes) but I got it up to 21mph by my GPS app and it seemed to handle quite well.
So that's very good to have done. I think tomorrow I'm gonna try fabbing up a foot throttle for it so it's little safer to drive, haha. Been meaning to do that for a bit anyhow.
Hopefully that goes well!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 18th 2019, 12:11 am
Nice jobAllis, now get those brakes done too!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Sig115PROJECTS:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Sig214[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Sig314
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 18th 2019, 10:39 am
20+ mph thats enough to have fun with for sure.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 19th 2019, 12:25 am
Thanks fellas! Yeah it should be a fun ride for sure.
Found a nice shady spot to do some fab work today, so I went ahead and tackled the new throttle setup.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190874
I rigged up the carb end of the setup first. Pretty simple as you can see:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190875
Then the pedal end. Had to use some rebar in true rat rod fashion!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190876
Probably gonna add a bit to the pedal later, but it works great!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190877
I did a bunch of ripping around afterwards and man, is it ever fun to drive now that I got the foot throttle on 'er! A lot safer too, haha.
After that I decided I wanted the hood to hinge at the rear more like a car, so I got an old hinge mounted up to the hood and dash.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190878
Works great! You wouldn't think it would work so well with only one hinge, but the hood doesn't weigh anything really so it doesn't seem like an issue.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190879
I didn't get a prop rod rigged up yet, but you can see how it works. I was happy to have the hood secured so I could drive around without it falling off, but of course that's when the rain decided to show up:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190880
Haha, oh well. Eventually it subsided and I got 'er back outside for a little bit:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190881
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190882
She's working great!! I'm getting happier with this rig everytime I tinker with it, haha.
Let me know what ya think!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 24th 2019, 4:46 pm
Okay so we had a bit of a driveshaft catastrophe today, she came apart on me when I was flying down the laneway. Broke the front coupler and it fell apart from there. I was able to make up a new one, but now I need to work on the U-joint at the rear.
Hopefully I can get it fixed again....
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 24th 2019, 9:41 pm
Yikes!  Knowing you, it will be better.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 24th 2019, 10:56 pm
Sorry to hear that Allis. Sounds like you could benefit from a lathe and some driveshaft hoops. Hope you get it back together soon.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 24th 2019, 11:19 pm
Thanks fellas. Haha, I guess you were right Mighty cuz I ended up getting 'er all back together and working good.
Here's the new coupler at the front:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190890
Took a ton of measuring and screwing around to get it right, but it's good to go now.
Took 'er for a test drive and all went well!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190892
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190891
Then I figured it was time to figure out some seatage because I was getting tired of almost flying off every time I took a turn at speed.
I used that neat padded pan seat from my 710 cuz I thought it would look better on this tractor. It feels much better to drive now, but part of me thinks it doesn't quite look right. Looks too high, kinda like I need to cut the fenders to allow it to sit down lower:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190894
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190893
Opinions?
Also a couple decorative items to finish things off:
I completed my foot throttle, looks pretty neat to me, haha.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190895
Then the good ol' Castrol Motor Oil driveshaft cover, because safety is a top concern on this particular build! [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 1098998679
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190896
It's a lot less unnerving to drive it when you can't see the driveshaft spinning at 4500 RPMs right below you, haha.
Gonna maybe try and see what I can figure out for brakes tomorrow, I decided to go back to my pinion brake idea, so I'll see what I can get done to make that work.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 24th 2019, 11:45 pm
Nice scatter shield Allis. I'm sure it'll look cool with a few dents pushed up from the other side. Although let's hope that doesn't happen lol.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 24th 2019, 11:49 pm
Haha, thanks Rich. It just supposed to be more of a guard so nothing gets caught in the the shaft while it's running.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 25th 2019, 4:17 am
I think the seat goes well. Especially with the black rims. Nice little rat touches.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 25th 2019, 11:08 am
I was wondering if you were going to lower it any. I think it would look good.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 25th 2019, 12:57 pm
I second that!
It actually looks a little uncomfortable to drive being that it's so high up. You did remove the old seat mount right?
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 25th 2019, 1:36 pm
Of course I removed the old seat mount, the seat is just bolted right down to the fenders. It's actually quite comfortable to drive as it is now, but I think it looks too high so I'm gonna see if I can drop it into the fenders a little bit.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 25th 2019, 10:18 pm
Totally stealing some of your Ideas for a future build. Angel
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 25th 2019, 10:25 pm
Haha, no problem!
Well unfortunately I didn't do any brake work today, go figure, haha. But I managed to knock another important item of the list..
The final front rims and tires!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190289
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190290
Now we're talking!! I'm loving the look for sure!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190291
The rims are from my old parts B-110 and use tapered roller bearings, which is why I wanted to use them. Definitely should hold up nicely!
Also I got a couple neat screenshots front a short video I made earlier:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Screen20
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Screen21
Kinda cool, haha. Let me know what ya think!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 25th 2019, 11:06 pm
Video? Ooooo when ya uploading? Smile
TheCollector
TheCollector
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 26th 2019, 12:59 am
I like that top pic of it in the dirt. 👍👍
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 26th 2019, 2:38 am
This looks really cool! I like the front end setup. Turned out nice.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 26th 2019, 1:45 pm
Looks like a true rat rod! Question is... Does it do true rat rod donuts??? [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 1098998679
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 26th 2019, 3:09 pm
Thanks everybody!
I was gonna upload the video but it didn't turn out quite as good as I was hoping, so I'll have to try again another day.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 28th 2019, 2:27 pm
looks awesome man, love all the hard work, so many cool details
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeAugust 28th 2019, 5:01 pm
Thanks! Much appreciated!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 Icon_minitimeSeptember 5th 2019, 8:46 pm
Still tinkering away on the Build-Off rig. I decided to take a shot at dropping the seat down a bit:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190911
I didn't wanna drop it too low, but just a couple inches or so.
Marked out and made the first cut:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190912
End result:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190913
Then I made up some bracketry to support the seat:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190917
All bolted up!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190915
Not a crazy difference, but I think it looks better than before for sure.
After that I took the fenders off again to start working out some brakes.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 12 20190916
Didn't get a whole lot done in that area, but that'll be a project for the weekend, haha.
Page 12 of 15Go to page : Previous  1 ... 7 ... 11, 12, 13, 14, 15  Next
» [FINALIST] - Father Daughter project 2019 Build Off [2019 Build-Off Entry]
» [FINALIST] - Murraymountain's Mountain Murray [2019 Build-Off Entry]
» [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry]
» [FINALIST] - mrshaft696's The Real Horse [2019 Build-Off Entry]
» [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2019 Archive :: Finalist Archive-
