 [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]
tater195
diddie
muddstir
Hillbilly Homer
Hillbilly Offroading
21 posters
Go to page : Previous  1 ... 6, 7, 8 ... 11 ... 15  Next
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Empty
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 18th 2019, 11:58 pm
Thanks a lot fellas!!
I actually managed to work at it and get the clutch pretty much done today.
I didn't take as many pictures as I should've... but basically I used sort of a bell-crank setup to transfer the motion from the clutch pedal rock shaft to the clutch idler arm.
This is the upper portion of it:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190363
The pivot point is an automotive flat idler clamped to the inside of the frame with a U-bolt, so the whole thing pivots on a bearings.
Had to make a special bolt for the upper arm so it would lock in place but still be removable:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190365
Simple clutch spring setup:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190364
And the lower arm and linkage:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190366
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190367
Finally, the function!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190368
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190369
It works!! Hahaha. Ran out of time to do a test with the engine running, but that should be pretty soon now. The clutch needs a couple things as well like a stronger spring and possibly a lower linkage mount on the idler arm so I get a bit more throw out of it. But as it is now it fully engages and disengages, so I'm happy!
Let me know what ya think!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 12:10 am
Very nice... Definitely unique looking.
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Sig115PROJECTS:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Sig214[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Sig314
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 12:17 am
Not sure if you mean unique looking in a good or bad sense.. but either way, thanks Mighty! lol!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 6:55 am
That’s built to last verses using a bike cable. Nice job!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 9:43 am
Haha, thanks Carl!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 2:44 pm
He was talking about testing the drive system soon when he jacks it up.  As for driving.... we have to wait for a new fabuloso front end suspension build from Mr Suspension Aficionado himself!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 3:00 pm
Yep, pretty much like Mighty said. Gonna raise the whole deal off the ground and test the drivetrain once it's ready, but we're still quite a ways away from driving the thing, haha.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 6:50 pm
Well I think "nasty" is the wrong word to use, but this is a hand-built rat rod!
Where something has been chopped or cut, you will be able to see it. Where something has been welded together, you will be able to see it. Where some parts have been scavanged from another piece of equipment, you will be able to see it.
You get the idea, haha. Basically I'm sorta going for that old school rat rod build look, (with safety in mind of course) when guys with less money would just take old junky cars and engines that were lying around and build a hot rod out of em!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 19th 2019, 11:07 pm
Sometimes I think things get lost in translation.  So many English words mean the same or similar.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 21st 2019, 5:42 pm
SebastianAlbrecht wrote:
Nice!! Like that Idea!
Thanks. Hopefully it looks alright in the end.
tater195
tater195
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 21st 2019, 10:51 pm
getting caught up on the build. Looks good. I like the shaft drive idea. Nice execution on that. Looks like you will need a real stiff spring on the clutch. Move it to the "slack" side of the belt and it will work better.
tater195
tater195
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 21st 2019, 11:16 pm
well crap. looks like you got it right. been awhile since I had to think this hard on OPE stuff
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMarch 21st 2019, 11:18 pm
Hahaha, no worries. Thanks for the compliments!! You're right about needing a heavier spring though, haha. Luckily I've got one that should do the trick!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeApril 9th 2019, 6:51 pm
Unfortunately not much has been done recently, been real nice outside so I've just been driving all my tractors around and working on other stuff, haha. However on the weekend I did get a couple minor things done.
Got another hole drilled and tapped for a bolt to hold the front universal on a bit more solid:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190429
Then got a much stronger clutch spring put in place:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190430
Only minor stuff, but it puts me that much closer to testing out the drivetrain!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeApril 9th 2019, 7:40 pm
WHAT?!?!  You are not driving yet?!
LOL  Just kidding.  I'm not driving yet either.  HAHA.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeApril 11th 2019, 11:59 am
Just about actually, as soon as I can get someone to pick up the front end and pull me around on it while I make motor sounds. [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 1098998679
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeApril 13th 2019, 9:36 pm
Well, big day today fellas. I got the engine spaced up a bit and  bolted down in all four corners:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190431
Got a hole drilled and tapped for the set screw in the rear universal (the last one), and then it was finally ready to test the driveline!!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190435
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190434
Happy to say the clutch worked nicley, and the wheels drove just fine. However, there is a very major vibration being caused by the rear universal. Not good.... Upon further inspection the adapter I welded into it wasn't perfectly true and goes a hair crooked when I tighten the set screw down.
So that sucks, haha. I did find out that everything works though, so I suppose that's good. I'm thinking I'll just get a different half shaft for the rear and find a better way to adapt it to the transaxle pinion shaft. I have a couple ideas, so hopefully I'll get 'er figured out and working good soon!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeApril 13th 2019, 9:45 pm
Nice job! U joint sucks, hope you can get that figured out without much trouble!
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeApril 14th 2019, 6:42 pm
Yeah hopefully I can come up with something to get it working. I'd like to get that part done finally...
Also no I wasn't gonna just let it vibrate that bad, haha. The pinion bearings would be toast before too long I imagine.
PostSubject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 Icon_minitimeMay 5th 2019, 9:09 pm
Yeah, I know. Been really slacking off with the Build-Off tractor here. Obviously the first drive shaft setup failing sorta threw a wrench into the gears, but I got a plan worked out using another shaft and joints, so I'l have to get around to that sometime soon.
In the meantime I decided to get the steering wheel all hooked up today, so I did do something!
As some of you know, these tractors used a rag joint that went between the steering shaft and the pinion steering gear. Mine was toast when I got this rig so I planned to use an automotive steering universal joint instead:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190515
Drilled a couple holes and tapped them to 1/4- 20:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190516
Bolted down all nice:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190517
Then I cut an old steering shaft to length and cut a square into the end to fit in the universal:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190518
Pinch bolt installled:
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190519
Then BAM! We have steering!
[FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 7 20190520
Well.. some of the steering anyways, hahaha. Nice to have that part done!
Page 7 of 15Go to page : Previous  1 ... 6, 7, 8 ... 11 ... 15  Next
» [FINALIST] - Father Daughter project 2019 Build Off [2019 Build-Off Entry]
» [FINALIST] - Murraymountain's Mountain Murray [2019 Build-Off Entry]
» [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry]
» [FINALIST] - mrshaft696's The Real Horse [2019 Build-Off Entry]
» [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2019 Archive :: Finalist Archive-
