I'd love to see one of these old MTDs built as a resto mod off roader like Ol' Red. I'd find an old flathead to put in there before a predator. I don't think the slanted jug on the predator would look right under the hood because the crank is inline with the tractor.
SteamNut247 Member
Age : 28 Join date : 2016-12-14 Points : 2944 Posts : 70 Location : Duluth Minnesota
The predator would be only for moving the tractor around, it wouldn't stay in there.
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5719 Posts : 1993 Location : Northern Ireland
Yeah, while I like the idea, I would be careful with swapping the diesel into it. You have a 2317, I have a 2372, and at least on the 2372 each forward gear comes in as counterclockwise, but leaves as clockwise (forward). My diesel turns clockwise, which would effectively give me 4 reverses and 1 forward.
SteamNut247 Member
Nah a diesel clone spins the same way as almost all small engines. You'll be fine, hundreds of people have put those diesels in tractors without issues.
Thanks.
Age : 37 Join date : 2013-07-02 Points : 4985 Posts : 731 Location : Logan Ohio
Thanks.
No problemo! Looking forward to seeing the build, these old MTD GT's are pretty neat old tractors. Don't see too many of them being modded either so it should be cool to see.
