| Gutbrod 1032 | |
ErikTheGerman New Member
Age : 27 Join date : 2018-07-22 Points : 2310 Posts : 12 Location : Dortmund
| | | | MightyRaze Administrator
Age : 49 Join date : 2016-09-06 Points : 15597 Posts : 10945 Location : Oklahoma
| Subject: Re: Gutbrod 1032 August 2nd 2018, 12:45 pm | |
| Interesting tractor. Should be a fun build. | |
| | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5730 Posts : 1993 Location : Northern Ireland
| Subject: Re: Gutbrod 1032 August 2nd 2018, 2:42 pm | |
| Really cool tractor! Is that a Gutbord engine? The exhaust/inlet manifold thing is neat. Do you have most of the parts for the engine except for the piston and con rod? If you do then it might be more cost effective to buy a second hand/new rod and piston, depending on how easily available parts are for those engines. The shaft adaptor might not fit another engine, depending on the size/type of shaft it has. Interesting project, looking forward to seeing it running and driving. | |
| Subject: Re: Gutbrod 1032 August 5th 2018, 11:03 am | |
| - MatthewD wrote:
- Really cool tractor! Is that a Gutbord engine? The exhaust/inlet manifold thing is neat. Do you have most of the parts for the engine except for the piston and con rod? If you do then it might be more cost effective to buy a second hand/new rod and piston, depending on how easily available parts are for those engines. The shaft adaptor might not fit another engine, depending on the size/type of shaft it has. Interesting project, looking forward to seeing it running and driving.
It is a 10hp gutbrod engine. the thing with the parts is that the brand doesnt exist anymore. The factory is now working under the name MTD. But there are some forums for gutbrod fans and i will try to get the parts or the same engine in better shape. | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8564 Posts : 5190 Location : Ontario Canada
| Subject: Re: Gutbrod 1032 August 5th 2018, 11:51 am | |
| Super neat looking tractor! I agree it'd be cool if you could get the parts to get the original engine running and put it back in the tractor. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 35 Join date : 2017-10-30 Points : 5310 Posts : 2561 Location : Rochester, New York
| Subject: Re: Gutbrod 1032 August 5th 2018, 2:56 pm | |
| With the design of the driveline here, I agree keep the engine original. I would clone swap it as a last resort. | |
| Subject: Re: Gutbrod 1032 August 9th 2018, 4:22 pm | |
| Looking greatso far! Definitely a very interesting tractor, I'd love to know more about the transaxle. The front axle is neat looking too, the tie-rod ends are more automotive style it looks like. Looking forward to seeing more pictures! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | | | Gutbrod 1032 | |
| Who is online? | In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests
