| Murray Widebody Lawn Tractor | |
+7Double W Cross Ranch prancstaman biggasmowers AllisKidD21 CraftsmanQuad19 MatthewD SebastianAlbrecht 11 posters | |
What should I do with it? | Build a Offroader | | 17% | [ 1 ] | Build a Racer | | 0% | [ 0 ] | Build a Trail Machine | | 67% | [ 4 ] | get the Deck working, replacement Engine, sell it | | 0% | [ 0 ] | Scrap it | | 16% | [ 1 ] |
| Total Votes : 6 | | Poll closed |
| Author | Message |
| Subject: Re: Murray Widebody Lawn Tractor October 14th 2018, 12:25 pm | |
| I would have pipes out the back personally, but that's just me. Otherwise, I love the plan! | |
| | | The author of this message was banned from the forum - See the message | SebastianAlbrecht Veteran Member
Age : 23 Join date : 2018-02-27 Points : 3840 Posts : 1299
| Subject: Re: Murray Widebody Lawn Tractor October 15th 2018, 12:03 pm | |
- I would have pipes out the back personally, but that's just me. Otherwise, I love the plan!
IMAO that would look kinda stupid and then I have to build tons of Exhaust pipes. What's about painting it like the K30 I showed U in our Chat? | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8581 Posts : 5190 Location : Ontario Canada
| Subject: Re: Murray Widebody Lawn Tractor October 15th 2018, 12:29 pm | |
| Hmm, number 6 on the list kinda jumped out at me. Haha.
Are you gonna be doing solid axle or independent? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Murray Widebody Lawn Tractor October 15th 2018, 2:32 pm | |
| - AllisKidD21 wrote:
- Hmm, number 6 on the list kinda jumped out at me. Haha.
Are you gonna be doing solid axle or independent? I just want to reinforce the stock front axle. I want to keep the stock pivoting point, but mod the axle mount, so I have a slot hole that has 2" travel up down or so. And I will put shocks from a old junky scooter I have since 3 years, trying to fix, but lost motivation and that POS isn't worth anything, so the parts are way more worth, when I can use them. Then putting the shocks on, so they have consistant downward pressure on the pivoting point, to keep the axle handling normal. When I now drive faster over stones and stuff, I still have the pivoting point, but still be able to have some travel. Or is that Idea 1000% JUNK? | |
| Subject: Re: Murray Widebody Lawn Tractor October 15th 2018, 3:37 pm | |
| It would work I suppose, but I bet it'd wear out pretty fast and be a pretty loose setup causing steering slop and what not.
Probably be better off fabbing up a nice multi-link setup. It'd be much more reliable. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 35 Join date : 2017-10-30 Points : 5327 Posts : 2561 Location : Rochester, New York
| Subject: Re: Murray Widebody Lawn Tractor October 16th 2018, 1:16 pm | |
- It would work I suppose, but I bet it'd wear out pretty fast and be a pretty loose setup causing steering slop and what not.
Probably be better off fabbing up a nice multi-link setup. It'd be much more reliable. Sounds like really much work.... - Crazy_Carl wrote:
- I agree doing that isn't going to last. I think the axle would flop back and forth some.
Ugggg! then I probably have lost! when no one can give me a idea how to build a suspension that uses the stock front axle so I dont need to mod the steering and stuff, it will stay as a regulyr just pivoting axle, whyt would be really boring and the Widebody deserves much more! I'm just too stupid to figure something out, and kinda bit allergic to work right now LOL | |
| | | | darkside0914 Established Member
2020 Build-Off Top 3 Winner
Age : 48 Join date : 2018-05-05 Points : 2980 Posts : 518 Location : S. Illinois
| Subject: Re: Murray Widebody Lawn Tractor October 19th 2018, 3:30 am | |
| have you thought about using a leaf spring? something off a small trailer or older snowmobile, you could mount them in either a transverse style or 2 parallel like on a truck, they would give you plenty of flex and still keep the axle solidly mounted, you could even use the shocks from that scooter on it maybe take off the springs if they have them, otherwise would probably be to stiff, and you shouldn't need to mod the steering much if at all. | |
| Subject: Re: Murray Widebody Lawn Tractor October 19th 2018, 6:42 pm | |
| - darkside0914 wrote:
- have you thought about using a leaf spring? something off a small trailer or older snowmobile, you could mount them in either a transverse style or 2 parallel like on a truck, they would give you plenty of flex and still keep the axle solidly mounted, you could even use the shocks from that scooter on it maybe take off the springs if they have them, otherwise would probably be to stiff, and you shouldn't need to mod the steering much if at all.
good idea | |
| Subject: Re: Murray Widebody Lawn Tractor October 19th 2018, 11:59 pm | |
good idea it just seems like the easiest solution to what you want to do, leaf springs have been on everything with a solid axle ever build, from horse drawn buggies to high power 4x4s and dragsters, and if it's to stiff you can remove some of the leaves to soften them up, the only mods you might have to make is lengthening you frame for the front mounts of the leaf spring if you use a parallel set, if you choose a transverse leaf look up the ford model T, it used one and it worked great. | |
| | | | RichieRichOverdrive Moderator
Age : 22 Join date : 2016-10-29 Points : 7208 Posts : 4013 Location : Lewisburg, KY
| Subject: Re: Murray Widebody Lawn Tractor November 21st 2018, 10:29 pm | |
| I plowed snow with my MTD a long long time ago with weight on the rear and it plowed quite a bit. Never hurt the frame, so I'm sure he'll be fine. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Murray Widebody Lawn Tractor November 21st 2018, 11:11 pm | |
- That frame is not sturdy enough to handle a plow, especially if you give it traction
That's why I want to reinforce the frame with some box steel, cuz I want this Widebody to last, even when I beat on it - AllisKidD21 wrote:
- I plowed snow with my MTD a long long time ago with weight on the rear and it plowed quite a bit. Never hurt the frame, so I'm sure he'll be fine.
I hope for my MTD, cuz I can't reinforce anything there, if I want to keep the deck stuff. | |
| Subject: Re: Murray Widebody Lawn Tractor January 1st 2019, 12:52 pm | |
| 2K19 should be the Year of this build!! I plan on building it this year, and maybe entering it into the Build-Off. It should be a reliable trail and work mower that can haul heavy Crap and plow, and makes lots of fun driving it and pissing off the neighbors with the Exhaust! Maybe a Engine Change will happen, not sure at this time! | |
| Subject: Re: Murray Widebody Lawn Tractor January 28th 2019, 12:09 pm | |
| Well, I plan on entering this Years Build-Off with this POS, but in the last few Years, Months, Weeks, Days, Hours, Minutes, Seconds,....... I got pissed off from the most work I did as my old hobbies, like botching on some old ****** push mowers, making dumb stuff,... wasting Money into useless parts,.... and it tries RN to kill the mower stuff too... With that being said IDK how the Future will go for my mower crap stuff, time will tell............ Just that nobody is wondering why the Threads R dead. | |
Age : 49 Join date : 2016-09-06 Points : 15653 Posts : 10975 Location : Oklahoma
| Subject: Re: Murray Widebody Lawn Tractor January 28th 2019, 12:44 pm | |
| All the treads are pretty dead right now. Plenty of time between now and Nov 30th. New build-off info will be uploaded Friday "Eastern Time- US" sometime.
Good luck man! | |
| Subject: Re: Murray Widebody Lawn Tractor January 28th 2019, 3:12 pm | |
| @SebastianAlbrechtJust some words of advice here. Build a tractor for YOU. Build a tractor the way you want and can reasonably do with your parts, skills, and money. Don't just build something because it's popular or other people are telling you to do it that way because your heart won't be in it. I love Ol' Red. I didn't start building it because of some specific internet video. I instantly fell in love with it at the scrap yard and I've been building it to my own vision with the support and guidance of ATLTF members. What kind of tractor do you dream of having? Maybe you're murray could turn into that. | |
| Subject: Re: Murray Widebody Lawn Tractor January 28th 2019, 7:32 pm | |
| - Crazy_Carl wrote:
- @SebastianAlbrechtJust some words of advice here. Build a tractor for YOU. Build a tractor the way you want and can reasonably do with your parts, skills, and money. Don't just build something because it's popular or other people are telling you to do it that way because your heart won't be in it. I love Ol' Red. I didn't start building it because of some specific internet video. I instantly fell in love with it at the scrap yard and I've been building it to my own vision with the support and guidance of ATLTF members. What kind of tractor do you dream of having? Maybe you're murray could turn into that.
Those are some VERY GOOD words of wisdom. Also, if you try to build what others like.... you will burn out faster and will just walk away. We like having you around. | |
| Subject: Re: Murray Widebody Lawn Tractor January 29th 2019, 6:43 am | |
| - MightyRaze wrote:
- All the treads are pretty dead right now. Plenty of time between now and Nov 30th. New build-off info will be uploaded Friday "Eastern Time- US" sometime.
Thank U for all your good Advices! I want a nice sounding, reliable, plenty fast Mower that can make lots of fun and handle the woods without problems, and will also be able to do good work in the garden (the Mud Murray 4X4) this thing I wanted to build to a Trail Mower that can also go plowing when it needs to... ATM my environment in Germany is pulling me down like crazy and the shop is a whole mess.... No Money to work with, missing some parts,.... I'm still hoping the Spring and Summer will give me some motivation back, so I wo'nt be pissed off right after entering the shop for 10 secs. - MightyRaze wrote:
Those are some VERY GOOD words of wisdom. Also, if you try to build what others like.... you will burn out faster and will just walk away. We like having you around. Thanks!!! Yeah, I kinda see that, work is piling up everywhere, running low on time, some people tell U to do this and that and this with your stuff,.... and the results R what happens since over 1 year and seems to elevate from week to week and has gotten this high RN... Pressure from all sides.... THANKS TO ALL YOU GUYS SUPPORT HERE!!! Would Prolly fell down way more without! | |
