 RichieRichOverdrive's Bikes
11 posters
RichieRichOverdrive's Bikes - Page 3 Empty
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJuly 12th 2019, 11:28 pm
So i went out to go get the mail on the minibike, on the way back the rod let go and locked her up. Whooooops. I think I'll get another 3hp with a good rotating assembly and do some mods and put her back together. I'd go bigger but I'm not in the mood to buy a ¾" clutch
RichieRichOverdrive's Bikes - Page 3 20190744
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJuly 13th 2019, 4:45 pm
Picked this up for $30 yesterday, guess it fits into this thread...
85 Suzuki LT250F. Previous owner said it needed a coil or something ignition related. Supposedly it shuts down when it gets hot.
RichieRichOverdrive's Bikes - Page 3 20190745
RichieRichOverdrive's Bikes - Page 3 20190746
First thing i did was rewind the pull start. Pulls over fine, feels like it has compression.
RichieRichOverdrive's Bikes - Page 3 20190747
I pulled it over and checked spark. Seems to have some. I haven't checked compression yet. I sprayed some carb cleaner down the carb but still didn't get a fire. Guess I'm gonna check valve lash next
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJuly 13th 2019, 5:11 pm
That looks pretty good for 30 bucks!
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJuly 13th 2019, 5:33 pm
speaking of clutches, you can get centrifugal clutches pretty cheap if you look. I forget where I got one, amazon or BMI karts maybe. But it was way less than the $40-50 they are normally priced at. Looked decent enough too. 5hp and 3.5hp briggs have the same crankshaft I think. 5hp is a big improvement. Same mounting bolt pattern also.
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeOctober 10th 2019, 8:30 pm
So I ended up selling the ATV for $150. Couldn't ever get it to run, or even pop really. Good riddance anyways.
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeMay 7th 2020, 12:17 am
So i got the F11 out yesterday, realized the other side of the fuel tank is leaking now. Woo. Patched it with the welder as best i could, it's not bad now.
Today i took her for a good ride, even accidentally buried her in a foot of mud. That sucked, a lot. I noticed my headlight wasn't working, thought that a wire came loose. Turns out both filaments are broken. Just put it back together for now.
RichieRichOverdrive's Bikes - Page 3 Kimg1824
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJuly 1st 2020, 8:30 pm
Got the minibike out a week or two ago. Broke the 3hp loose, definitely broke the rod. Whoops lol!
I've collected 3 5hp engines in the past few weeks, not really on purpose. But that is what it is. I didn't have a 3/4 shaft clutch so i decided to go belt drive.
Smallest pulley i have on the front, gt6000/633 pulley on the back. Clutch in the middle is just a flat idler, with a foot pedal on the right side. Push down to engage the clutch.
RichieRichOverdrive's Bikes - Page 3 Kimg2016
Put the newest 5hp on, hooked up the throttle ungoverned, and that was about it. Didn't take the extra fuel tank off, could use it as a spare.
RichieRichOverdrive's Bikes - Page 3 Kimg2017
Geared too fast, gotta be creative with the clutch to start it on a hill.
Top speed? 48mph. I don't stay up that high too long lol.
BlakeGroce
BlakeGroce
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJuly 5th 2020, 12:42 pm
I guess you could put a jack shaft on it if you have the room.
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeSeptember 28th 2020, 6:25 pm
I could, but once I get on the road the extra speed is really nice for cruising backroads for a long time with just a little bit of fuel. I think a killswitch on the handlebars would be nice so i can engine brake on hills. A good brake would be nice too, lol
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJanuary 15th 2024, 11:23 am
So the F11 still sees some occasional riding but it's kind of a pain having to drain the fuel out of the tank after every ride so it doesn't wind up on the floor under the bike. Hopefully this will fix it. Looks pretty clean in the pictures.
RichieRichOverdrive's Bikes - Page 3 Screen12
MightyRaze, Brianator and ranch king pro 08 like this post
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJanuary 15th 2024, 5:36 pm
This thread makes me want to get one of my minibikes going.
PostSubject: Re: RichieRichOverdrive's Bikes   RichieRichOverdrive's Bikes - Page 3 Icon_minitimeJanuary 16th 2024, 1:11 am
I’ve been thinking about building the 5hp in the same style as the oppy in mutt, just hot on stock parts with a big carb, and getting a torque converter for it. That would be pretty nice. The belt clutch is sucky.
» bikes id like to own
» show us your bikes :D
» Some of my project bikes
» Will Hydraulic brakes from ATVs and pit bikes work on a tractor?
» Cool Bikes Found on Craigslist
