 Will Hydraulic brakes from ATVs and pit bikes work on a tractor?
ncredleg
ncredleg
Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Empty
PostSubject: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 22nd 2010, 3:05 am
I have been looking at parts for pit bikes. They are inexpensive.This is a setup for an ATV , all 4 wheels only about $70.Something for a two wheeler is about half that. http://www.pocketbikeparts.com/Hydraulic_Brake_s/45.htm
Webmaster
Webmaster
Webmaster
Webmaster
PostSubject: Re: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 22nd 2010, 8:25 am
Good find! I was going to use the brakes off of a pocketbike, but they are mechanical... I like the hydraulic ones! I bet they work well, and they're cheap!
http://ww.atltf.com
Chunk
Chunk
PostSubject: Re: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 22nd 2010, 8:29 am
Im looking at mini moto brakes too. Cheapest way I can think of stopping. Really cant afford anything fanc. Wanting to spend maybe £20 total for a good setup
ncredleg
ncredleg
PostSubject: Pocket-minimoto bikes.   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 22nd 2010, 9:50 am
There are probably more options for you in Europe, for parts sources, with the vast numbers of the smaller bikes on the road over there. There may be salvage/junkyards that specialize in just that. I know we have places here just for the bigger bikes ,atvs and personal watercraft(PWC).
ncredleg
ncredleg
PostSubject: Re: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 22nd 2010, 10:19 am
Here is another link for an ATV set-up that has the rod for the brake pedal.A little more but, I have a young daughter and nieces and nephews who will be riding it .
Embarassed Oh, By the way this will be for my ATLT not my UTV that I am working on right now.
I am going to reuse the band brake on that cause it won`t be faster than stock, about 4.6 mph tops. Smile
They do make longer lines for the smaller brake set-ups.
http://www.motopartsmax.com/index.php/main_page/popup_image/pID/8655&f=5-l.jpgWill Hydraulic brakes from ATVs and pit bikes work on a tractor? 50010
ncredleg
ncredleg
PostSubject: Re: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 22nd 2010, 10:59 am
Here is another link .I know that this is a hand brake but it should not be too hard to remove the lever and connect it to a rod and pedal. You would only have to figure out how to mount the cylinder to the frame and that should be easy to mount to a tube.
http://www.scooterpart.net/products.php?id=1469[img]Will Hydraulic brakes from ATVs and pit bikes work on a tractor? 50cc_a10[/img]
arild365
arild365
PostSubject: Re: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 28th 2010, 11:32 am
Im thinking il get these ones. they look pretty decent. Do they fit any disc brake?
Chunk
Chunk
PostSubject: Re: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 28th 2010, 12:55 pm
There arent many scrapy yards locally to me anyway, and those that are only really deal in cars mostly. I'll just have to keep a look out everywhere. SHouldnt be hard to make a good setup for cheap!
ncredleg
ncredleg
PostSubject: Re: Will Hydraulic brakes from ATVs and pit bikes work on a tractor?   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 28th 2010, 3:05 pm
That is complete minus the pads.They have those as well .You would need to get the rotor and mount it on the axle ,then mount the caliper to a bracket on the frame. You can use a rotor from a go-kart set-up or buy it from http://www.northerntool.com .
ncredleg
ncredleg
PostSubject: Here is another link for info on brake set-up. great pictures.   Will Hydraulic brakes from ATVs and pit bikes work on a tractor? Icon_minitimeMay 28th 2010, 4:36 pm
http://www.bsatroop251.com/Brakes/brakes.html
» New brakes for tractor axle?
» This.. Is how you work on a tractor :D
» new mudder/work tractor
» Ford YT 16 Work Tractor
» Monster work tractor
