| Yanmar L100 and clone diesel information | |
| Subject: Yanmar L100 and clone diesel information July 6th 2018, 11:15 pm | |
| Hey guys, I picked up this generator with a 10 horse Chinese clone of a yanmar L100. I was told the generator works, and the engine kinda runs but I think the injector timing is a little off. Anyway, I’d like to get this thing running and I know quite a few of you have messed with these things a lot, so I figured we could pool information here on these engines. Here are the symptoms of this particular engine. It turns over fine but will not run with the compression release open. While it’s turning over I flip the compression release closed an it fires once but it almost fires backwards because it kicks so hard. My hypothesis is that the injector timing is advanced a little and it’s trying to ignite too early. Am I on the right track? Pic! | |
| | | | CraftsmanQuad19 Veteran Member
| Subject: Re: Yanmar L100 and clone diesel information July 7th 2018, 12:12 am | |
| I know where it’s posted. I was hoping that there would be lots of good information on these engines as well as the solution to this problem, that’s all | |
| Subject: Re: Yanmar L100 and clone diesel information July 7th 2018, 12:52 am | |
| Oh ok. Did someone reply or were you saying ahead of time? I only saw yours. Feel free to delete this one once you’ve seen it to save space in this tech thread.
Anyway, lots of pictures and information welcome. What does everyone know about these things? | |
| | | AllisKidD21 Moderator
| Subject: Re: Yanmar L100 and clone diesel information July 7th 2018, 1:06 am | |
| Hmmm, your theory on the timing being too advanced makes sense, but I would think the only way that could happen was if someone had the little pump out and removed a shim or what have you. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Yanmar L100 and clone diesel information July 7th 2018, 9:25 am | |
| Yeah I believe they are. Also I wouldn't think they would wear down as they just simply go between the pump and the block sorta like a gasket would. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | MatthewD Veteran Member
| Subject: Re: Yanmar L100 and clone diesel information July 8th 2018, 7:58 pm | |
| Here's a pic of mine. 6hp Lifan Diesel. Are you sure the kicking back is not just the high compression of these engines? If you push the de compression lever down, the pull it over, it should release once it hits TDC. You need to pull it over really hard to get it past that point or it will kick back and take your arm back with it. Maybe try spraying WD 40 or similar in the air intake to see if it fires properly. | |
| Subject: Re: Yanmar L100 and clone diesel information July 8th 2018, 8:14 pm | |
| It has electric start, and even that wouldn’t do it. Eventually we got it kinda running but it ran really rough and smoked a bunch. Not sure if that’s because it sat for so long or what. I’ll update it once I play with it a little | |
| Who is online? | In total there are 24 users online :: 1 Registered, 0 Hidden and 23 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
