| [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] | |
+10CraftsmanQuad19 biggasmowers SebastianAlbrecht MightyRaze AllisKidD21 Creepycrawler Crazy_Carl Double W Cross Ranch MatthewD Doug 14 posters |
Crazy_Carl Veteran Member
Age : 34 Join date : 2013-11-02 Points : 7165 Posts : 2910 Location : New Jersey USA
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] May 24th 2018, 12:31 am | |
| Yeah after awhile real loud pipes get a bit annoying for me. bigasmowers the mud dobers tried to fix it for you. So, decided to get my exhaust done tonight. Mounted the glass pack. Held on with two bolts. One in a bracket and one through the frame. Frame bracket Bends from stock pipe welded in With the grill on Fit's nicely inside the grill. I think it turned out pretty good. Just needs some kind of tail pipe and some paint. | |
Age : 24 Join date : 2016-04-12 Points : 5977 Posts : 2645 Location : Indiana
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] May 24th 2018, 11:50 am | |
| Thanks guys! Tailpipe for now I'm thinking, more of an exit pipe right off the end of the glass pack. Maybe with a tight bent towards the outside if I can find one more. Rear tires are going to be those turf tires for haspin. But I'm leaving the extended length axles because I may put on the same AG treads like the front ones are. To do that I would need to put bearings on to support the axle, they would need to be spaced out to match up with the fronts. No time for all that now. If I get time I plan on cutting the tread a bit with the turfs for some grip. Leave the tire pressure low it'll be ok with the rear locked I think.
CraftmanQuad are you going this year? I can't keep track of what everyone's doing with my messed up memory lol | |
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] May 24th 2018, 10:43 pm | |
| Yeah that exhaust definitely turned out fantastic looking, fits along the frame pretty slick. Definitely interested to see how it sounds. Likin' the new profile picture too! haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2018-02-27 Points : 3842 Posts : 1299
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7778 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] May 26th 2018, 9:32 am | |
| Thanks, the exhaust bends are cut from the original factory pipe off that engine. It had 3 nice 90 degree bends. And yeah 2016 haspin had that one day where it was pretty tough. Getting from the camp area to the woods was the main problem, that's where the mud was the worst. I'd prefer things just stay dry, can't go anywhere when it's that wet. And Doug, your doc locked MST is dripping oil from both sides just sitting here lol. And that's with gear oil and STP oil treatment in it. Oh well I guess. When it gets low enough it'll stop. Here's a few quick progress pics. LED Headlights Mr.modified's official grip nuts installed Rear fenders didn't match the running boards too well, parts from different year tractors? I pulled them together with one bolt and also welded them for strength. | |
| Subject: Re: [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] May 26th 2018, 11:04 pm | |
| Yeah I have an idea in mind for a simple but cool front bumper and sort of skid plate. Just been trying to get the top priority things going first. This time the front bumper will be good to pick up the machine with. On the simplicity, there's not much room for your hands to lift it. This morning I got the exhaust tail pipe sorted out. Kept it tucked in fairly close to protect it. Simple and out of the way, nothing too flashy this time as far as where it exits. Clears the front tire no problem, and this time the front axle is solid so I don't have to worry about it moving. Painted with VHT exhaust paint, suppose to be red but looks orange to me. Still kind cool, something different. I was thinking, maybe paint the HE letters with high heat black but probably not before haspin. The galvanized may flake off in places anyway with the heat. Then I'll have to repaint. You can see the added washer and bracing around the mounting bolts to stop fatigue cracks. Shifter done. Had to rig one up using the shifter from the parts craftman. Hard to see the whole thing but I had to do a lot of cutting and welding. Works good enough I think. Shouldn't break. Made a simple brace to keep pressure off the shifter input shaft. That's the hose clamp you see on all the scrap metal welded together. HASPIN BRACING! I also plan on some minor frame bracing between the axle and just beyond where the dash stops. Seems that would be the most likely area to have problems. The dash and rear fenders/running boards kinda hold it together from there back. I put a couple of weld beads from the dash tin to the frame to keep things a bit stiffer than just the stock bolts. In this pic, you can see I welded the seam on the top of the axle for added strength. | |
Doug Site Owner
| Subject: Re: [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] May 27th 2018, 11:17 am | |
| So since most of the haspin machines seem to have locked front ends , is there more strain on the tranny and frame from not having some flex? On my LT 4000 the frame is fully two forced and the rear is solid axle with reinforcement, and the front end is solid tube welded to the frame and I wonder if it's abusing the tranny more than normal. | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5092 Posts : 1412 Location : Cleveland,Ohio
Doug Site Owner
| Subject: Re: [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry] May 28th 2018, 12:34 am | |
| - biggasmowers wrote:
- So since most of the haspin machines seem to have locked front ends , is there more strain on the tranny and frame from not having some flex? On my LT 4000 the frame is fully two forced and the rear is solid axle with reinforcement, and the front end is solid tube welded to the frame and I wonder if it's abusing the tranny more than normal.
Frame flex is terrible. Ideally you want only a small amount of axle pivot and decent frame bracing. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
