| [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry] | |
+14Double W Cross Ranch Buck mrshaft696 MightyRaze RichieRichOverdrive Thunderdivine Dave 007 AllisKidD21 Offroad MudMowers Doug biggasmowers prancstaman Crazy_Carl RCG 18 posters |
| Subject: Re: [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry] July 25th 2018, 2:00 pm | |
| - MightyRaze wrote:
- SebastianAlbrecht wrote:
- Ahh. Looks interesting. I just do'nt think the connection between the box steel and the stock axle is the sturdiest, it could break probably.
The Front Tire Upgrade is cool! Is the ride smooth, or really rough with them? Probably will buy the same tires Inspect a little closer... That pic he showed you from early on showing the dual I beam I believe the stock axle ends were just stuck on at that time. Not welded. If you look at the more recent image.
- Quote :
You can see the 2 square tubes welded together make up the whole opening to the stock axle giving more surface welding making it stronger than that first images appears. Ohh. I'm sure if anything breaks @Maine Mud Mower will show it us in his Vids. I will go for a reinforced stock axle in my build. | |
Crazy_Carl Veteran Member
RCG Member
2016 Build-Off Finalist
| Subject: Re: [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry] July 25th 2018, 10:49 pm | |
| Hey looking good Neil! The upper coilover mounts might work better turned 90° so the beams won't be trying to bend the coilovers, but it should still work fine. Have you tried to see how much travel the setup has yet? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15676 Posts : 10987 Location : Oklahoma
RCG Member
| Subject: Re: [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry] July 26th 2018, 8:37 am | |
| - AllisKidD21 wrote:
- Hey looking good Neil! The upper coilover mounts might work better turned 90° so the beams won't be trying to bend the coilovers, but it should still work fine. Have you tried to see how much travel the setup has yet?
At this point all the parts are sitting in paint. My goal for now is to get the rest of it slung together into a test drive state over the next 2 weeks. I'm going on another vacation soon so and need to get back onto farm work soon. The flex on each side should be around 6 inches stock flex is 4 so anything above that is better. | |
MatthewD Veteran Member
Age : 22 Join date : 2016-10-29 Points : 7223 Posts : 4021 Location : Lewisburg, KY
RCG Member
Age : 23 Join date : 2018-02-27 Points : 3847 Posts : 1299
RCG Member
| Subject: Re: [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry] August 5th 2018, 4:22 pm | |
| Solid progress on the build. I can't see the sterring issue though. A drag link with a tie rod is no good because the toe in/out will constantly change. I think you either need a dual drag link setup but I'm unfamiliar with fords lol.
Bummer about your wrists. I fell hands first onto a concrete pier years ago and it put my wrists in a huge amount of pain and set me back work wise for a little bit but it healed up and nothing was broken. | |
RCG Member
RCG Member
| Subject: Re: [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry] September 14th 2018, 10:03 am | |
| - MightyRaze wrote:
- Definitely a colorful one! Looks good. Curious what it looks like from the front.
Front at this point still looks the same. I want to get it out and test drive it a bit and flex it first then decide on the front skid plate setup. | |
| Subject: Re: [Complete] Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry] September 14th 2018, 10:26 pm | |
| So, curiosity is getting the better of me. Your shock mounts are 90* from each other. I was wondering your thoughts on that. Part of me is thinking that will be hard on the shock, while another part of me is thinking it can travel 2 directions. Should not have any if very little backward bend. It should all work up/down. | |
RCG Member
RCG Member
