| 1993 Craftsman LT4000 heavy mud build. | |
+7richie thomas mrshaft696 RichieRichOverdrive Crazy_Carl MightyRaze Double W Cross Ranch biggasmowers 11 posters |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4931 Posts : 1944 Location : Kansas
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 16th 2018, 5:54 pm | |
| Gonna convert it to oil filled? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 16th 2018, 8:19 pm | |
| So wpuld welding the spiders the way fearless front uses be ok for this thing? I mean that diff is super heavy duty. But doc locking it is more expensive but gives me some more width and the ability to put on axle supports. | |
Age : 24 Join date : 2016-04-12 Points : 5982 Posts : 2645 Location : Indiana
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 16th 2018, 8:21 pm | |
| Doc lock is worth it IMO. Just collect all the scrap frames and other steel you got and take a load in. Should be a couple hundred worth with all the stuff you got lol. | |
Age : 49 Join date : 2016-09-06 Points : 15677 Posts : 10988 Location : Oklahoma
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 18th 2018, 8:22 pm | |
| Yeah lol. Cleaned up all the gears and the clusters are back together but I have an extra washer...... I think it goes somewhere in the front cluster . | |
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 18th 2018, 8:55 pm | |
| Just put that washer in your pocket for safe keeping. Haven't you ever heard of pocket screws? With you reputation I would give some serious thought to replacing or removing the reverse chain. | |
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 18th 2018, 9:27 pm | |
| The chain is almost brand new, it's out of the 930 , the o e I this case was way to rusted to use. I found where the washer went , it's all good now lol. If anybody has a spare set of the input bearings I could use them !!! Now all I need to do Is get a drill bit set and a solid axle for it after I replace the bearings . It's all together but not bolted up to just keep the gears clean as I sprayed it down with wd40 to get the water out of it and prevent rust till I lock it. Do you guys think a step down drill bit wpuld work for enlarging the diff carrier holes? | |
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 25th 2018, 10:33 am | |
| anybody know the part numbers for the little needle bearing thats under the ball bearing on the input shaft hole? the temptation of putting it all back together and running it unlocked is very great. but now since i sold the engine( it runs really well and i put tons of work into getting it running and putting it on, now the guy says its leaking some oil from the crank gasket. yay.) i need to order a live axle and find out about boreing out the diff carrier. i am considering welding some 3/4 inch plate to the axle shaft instead of using a hub with welding keys to it and having the weak point of the keyway in the axle. basically a doc locker version one on an 820. what do yall think about that?
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 25th 2018, 12:33 pm | |
| Sounds like a stronger way to do the locker. I had a go kart axle where the sprocket hub was welded to the axle. It wasn’t going anywhere. | |
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 25th 2018, 12:38 pm | |
| Well I ordered a bearing for the bottom, and I have a top bearing in the cart with a 36 inch axle. The little needle bearing wasn't the exact part number as it was foreign but it is the correct size in every spec. The top bearing I am ordering is a 6203 RS 3/4" . It's also slightly different numbers than the 6203 RS that's the original bearing but the specs are also right on the dot. The parts came out to 35 bucks and the shipping is 20. So yeah . | |
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 26th 2018, 12:42 pm | |
| Well. Since the parents aren't letting me order the axle until school is over it's not going to go together for a couple weeks if not months. Unless I pull the axle out of the snapper and use it!!! Ha! Lol I still need to drillbout the bores but I did take it all apart last night . | |
Age : 20 Join date : 2017-06-09 Points : 5493 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: 1993 Craftsman LT4000 heavy mud build. April 26th 2018, 3:33 pm | |
| NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!! | |
